Forums Migration
Please read this thread
2013 Toyota Highlander
by millerbl00 - 07/08/20 08:31 AM
Filled wrong spec oil in S55 motor
by nolube - 07/08/20 08:23 AM
Online dating
by Garrygb - 07/08/20 08:09 AM
Kia, Hyundai, Mazda - Used Car Candidates
by Wrenchturner44 - 07/08/20 07:52 AM
2002 Silverado sold in less than 24hrs
by Rat407 - 07/08/20 05:18 AM
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Ifried91, nolube, FilAx, T101, fatrap314
71880 Registered Users
114 registered members (97tbird, 4WD, 64bawagon, ABN_CBT_ENGR, 14Accent, 2015_PSD, 9 invisible), 1,608 guests, and 22 spiders.
Topics307,591
Posts5,313,738
Members71,880
2006 Audi A8 4.2 0W40 OR 5W40 OIL? #5342170 02/05/20 08:17 PM
B
boostedtsiawd Offline OP
B
Hey guys i just bought a 2006 Audi A8 4.2 with 129k miles and im wondering would 5w40 fully synthetic oil be ok to use? The previous owner used 0w40 but i got Castrol EDGE 5W-40 Advanced Full Synthetic Motor Oil with a Audi oem oil filter. I live in Chicago and temps now are between 20s-40s. I just thought 0w40 is a bit thin considering the miles plus i think Audi calls for 5w40. I wont be driving the car much in winter but in spring n summer more often so thats why i was thinking to put 5w-40.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342174 02/05/20 08:19 PM
Quattro Pete Offline
0W-40 is actually a better oil and not "thin," but Edge 5W-40 will be fine.
Edge 0W-40 is currently on sale at Amazon (and Walmart) for $19 per jug.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342176 02/05/20 08:25 PM
W
Wheel366 Offline
W
You are out of warranty so take this as it is but any oil that meets the spec should be fine. I have a 2001 S4 and had a 2004 A4 1.8t. Both called for 502.00/505.00. Most of the approved oils were 0W-40 and 5W-40 but there were a few that were 0W-30. A lot of people were using Rotella T6 5W-40 with good results. I even ran it once or twice. I also run Amsoil EFM and AFL and Mobil 1 0W-40. I also ran Total something or other 0W-30 that met the spec.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342192 02/05/20 08:47 PM
A
Audios Offline
A
Either is fine.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342204 02/05/20 09:03 PM
K
kschachn Online Content
Online Content
K
As usual with this type of question it isn't at all about the grade, it is about the approval. Use an oil with the correct Audi approval and ignore the grade unless your expected starting temperatures are far below 0F (then pick an appropriate winter rating). With Audi approvals grade is irrelevant since the oil must meet a minimum HTHS.
And again as usual with this type of question, 0W-40 is not thinner than 5W-40 unless it is -40F. At operating temperature and nearly everywhere else in between they are the same.
So what Audi approval is required for your engine?
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342281 02/05/20 10:50 PM
Snagglefoot Online Content
Online Content
To help the OP get a feel about what is happening at lower temperatures, I have this graph showing what happens to the kinematic viscosity as the temperatures drop. There is nothing thin about a 0W40 oil. It would still be over 10 times thicker at 0 degrees C than it's viscosity at an operating temperature of 100 C. This graph only goes down to 0 C. While I don't have a 0w40 shown, have a look at the 5W30. I agree with Mr. Kschachn, the difference between 0W40 and 5W40 would be negligible until you got down to -40 C and the kinematic viscosities were above 6000 cSt. However, it should be noted that some manufacturers are asking for 0W40 for year round use regardless of the area or ambient temperature. They aren't doing it because they expect you to be in a -40 C ambient temp. See how the lines converge at 100 C. They aren't actually identical. They would range from approx 8 to 14 CSt which is the difference between an xw20 and a xw40 motor oil at 100 C. Now look at the huge differences between a 15W and a 5W at low temps. You can scale in a 0W just below the 5W line. smile
If you want the job done right......do it yourself.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342297 02/05/20 11:28 PM
Online Content
And here is an example of a 5W40 and a 0W40 plotted together, but they aren't the same manufacturer. Although there is a difference in the kinematic viscosity at 0 C, it isn't large. Not sure what year these products were . At -40 C, all these kinematic viscosities would be over 6000 cSt.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342480 02/06/20 08:00 AM
T
Trav Offline
T
The Castrol 0w40 is one of the best Euro oils you can buy for that engine and priced right at Walmart.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342570 02/06/20 10:53 AM
U
umungus1122 Offline
U
Castrol 0w-40 is definitely not too "thin". Grab yourself 2 jugs for $19 a piece.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'04 Crown Vic 95k Maxlife full syn 5w-20
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5342642 02/06/20 12:43 PM
N
nthach Offline
N
It doesn't matter - M1 0W-40FS, Edge 0W-40/5W-40, Rotella 5W-40 or any Euro-speced A3/B4 with VW 50x certs works.
My vote is for the 0W-40, it will help with those Chicago mornings when you account for windchill.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5343175 02/06/20 11:24 PM
B
B
ok
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5344254 02/08/20 04:11 AM
B
B
I hope 5w40 gonna be ok i was told to change the oil every 10k miles and i know i wont put 10k miles until probably the middle of summer or end of it so that is why i rather have 5w40 because 5w is good in warmer weather.
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5344620 02/08/20 01:40 PM
K
Online Content
K
No clue what you're saying there. Whether it is a 0W-40 or a 5W-40 won't make a bit of difference in "warmer weather."
And once more, in this instance it isn't about the grade it's about the approval. Do you even know what approval is required for your engine?
1994 BMW 530i, 253K
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: boostedtsiawd] #5344689 02/08/20 02:58 PM
TiGeo Offline
Likely VW 502 00 approval required - I'd take the 0W40 for your colder "W" temps....plus it uses a more "synthetic" base than the 5W variants to get that 0W rating.
2018 VW Atlas SEL 4Motion 3.6 - Dealer Castrol 5W40 VW filter
2018 VW GSW S 4Motion 1.8 DSG Unitronic St2 IS20 - LiquiMoly Molygen 5W40 Mann filter
2013 Ford Focus SE HB 5-spd 2.0 - MC 5W20 MC filter
Re: 2006 Audi A8 4.2 0W40 OR 5W40 OIL? [Re: kschachn] #5344933 02/08/20 10:18 PM
B
B
yes it says Castrol Edge 5w40 MEETS OR EXCEEDS INDUSTRY STANDARDS: VW 502 00 / 505 00
