school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
104 registered members (53' Stude, 28oz, 92saturnsl2, AdditionalD, 6 invisible), 2,349 guests, and 27 spiders.
Topics301,661
Posts5,200,132
Members70,751
Grinding wheels #5342165 02/05/20 07:09 PM
E
Eddie Offline OP
E
I need a new grinding wheel 7X1 with a 5/8 arbor for my Dayton bench top grinder. I use it for sharpening mower blades, axes and similar but, no rough work. Present wheel is a reddish color and I don't know the material is . Please suggest a wheel manufacture you have had good service from and suggest a type of material and grit. Sincerely. Ed Hayes
2014 CX5 Touring 2.5L :-)
Re: Grinding wheels [Re: Eddie] #5342173 02/05/20 07:19 PM
F
Farnsworth Offline
F
If your wheel is not worn down it can be trued flat with a diamond point. Best to look up different kinds. A green silicon carbide and white aluminum oxide in 80 and 120 grit would be a choice.
Re: Grinding wheels [Re: Eddie] #5342184 02/05/20 07:32 PM
Skippy722 Offline
We use Norton aluminum oxide wheels at work. CBN or Diamond for carbide or very hard heat treated steels. 80-120 grit is a good range.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Grinding wheels [Re: Eddie] #5342205 02/05/20 08:03 PM
V
Vern_in_IL Offline
V
Radiac is USA made, but they do not offer in your size/application. They have options for a 7x1 x 1 1/4" arbor. Only one option for a 5/8, and it's some specialty wheel.
Re: Grinding wheels [Re: Eddie] #5342238 02/05/20 08:30 PM
I
Ihatetochangeoil Offline
I
Norton grinding wheels are Industry standard in weld shops and a lot of machine shops, grits have already been suggested. I am an independent and credentialed welding inspector and I'm in and out of major fabricators, power plants and heavy construction sites. As a grinding wheel manufacturer, Norton wheels are what you want. If your local hardware store doesn't have what you need, visit a supplier of welding products that sells welding filler wire and gases.
Peace Love & Jellybeans
Re: Grinding wheels [Re: Eddie] #5342248 02/05/20 08:43 PM
E
Eddie Offline OP
E
Thank you for the information. Ed
Re: Grinding wheels [Re: Skippy722] #5342463 02/06/20 06:41 AM
T
Trav Offline
T
Good wheels. I use the 120 mostly, it gives a nice finish.
Re: Grinding wheels [Re: Eddie] #5342637 02/06/20 11:35 AM
royesses Offline
I use Camel wheels, mad in Israel. They have many types but the brown and grey wheels work great for most steels. White and blue for high speed steel.
https://www.ebay.com/sch/i.html?_fr...;_nkw=camel+grinding+wheels&_sacat=0
Roy
Re: Grinding wheels [Re: Vern_in_IL] #5342749 02/06/20 02:26 PM
T
TMoto Offline
T
Be careful with that size if you find one and decide to use an arbor adaptor. This size is very common for vitrified wheels used on surface grinders. For your work OP, you want a resin bond wheel for a bench top grinder. You don't want one labeled as a toolroom wheel, you want one labeled as a bench and pedestal wheel. Also, you want aluminum oxide (A/O) unless you're grinding carbide, aluminum, or even cast iron, in which case green silicon carbide (S/C) would be used.
Nothing wrong with Radiac, Norton/St. Gobain, Carborundum (I think they're part of St. Gobain now?), Camel, etc.
Put 2 BITOGers together and you'll get 3 opinions
