How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
116 registered members (1978elcamino, 2013ecof150, 2015_PSD, 28oz, Anduril, 750IX, 5 invisible), 2,457 guests, and 18 spiders.
Topics301,902
Posts5,205,064
Members70,798
Compatibility (again) #5341663 02/05/20 09:28 AM
Dieselanddogs Offline OP
I know this may be beating a dead horse, and there's a sticky, but maybe someone can put it into simple terms. Here's my issue. I have a 6x12 utility trailer that I use to haul a Polaris Ranger. I use it once or twice a week 100 miles each way, mostly highway speeds. A couple of weeks ago, I had a bearing failure and lost the wheel, hub and all on one side. Long story short, the trailer was towed to a shop where a new axle was installed. The old axle was Dexter EZ lube. Not exactly sure about the new one, but it does have the zerk on it. I'm also not exactly sure what type of grease is in it now, other than it's red. I have the "Green Grease" from Autozone in the gun now and an extra tube on the shelf. Not sure if I should use that to add to it or not. I do know that I don't want to send another wheel skipping down the highway. I had been using Mobil 1, but switched to the Green because I got tired of the leaking.
Re: Compatibility (again) [Re: Dieselanddogs] #5341669 02/05/20 09:33 AM
CT8 Offline
Call the company that installed the axle.
2015 F150 2.7
2018 F350 6.2
Re: Compatibility (again) [Re: Dieselanddogs] #5341673 02/05/20 09:36 AM
K
krismoriah72 Offline
K
I have a 6X12 and tow a Polaris RZR Turbo..
If you have a new axle and you see red grease.. its lubed.
Unless you see leaking you shouldnt have to add to it for a long while.
If you want to pump it full of grease just be careful not to blow the seals. I use Mystik JT6 in my rzr and my trailer.. its nearly impossible to wash off and is GC-LB rated for chassis and wheel bearings. Doesnt leak out of my gun either.
If i were you i would jack up your trailer every few hauls and test your wheel bearings for play.. your old failure was likely due to a worn out bearing that wasnt caught in time.
Re: Compatibility (again) [Re: Dieselanddogs] #5341737 02/05/20 11:11 AM
Ok, so after a few phone calls, I believe the grease that's in the bearings now is Red N Tacky.
Re: Compatibility (again) [Re: Dieselanddogs] #5341797 02/05/20 11:56 AM
CT8 Offline
I wondered what caused the failure?
2015 F150 2.7
2018 F350 6.2
Re: Compatibility (again) [Re: CT8] #5341872 02/05/20 01:07 PM
Me too! I greased them regularly (every 2-3 months). Jacked up the trailer, and spun the wheel while greasing them. Not a fun day, that's for sure. Just glad nobody got hurt as the wheel passed me and crossed 4 lanes and launched into the woods somewhere. I was doing about 65 when it cut loose. (Also learned that day, that none of the roadside assistance that I have covers towing a trailer.)
Re: Compatibility (again) [Re: Dieselanddogs] #5341931 02/05/20 02:09 PM
M
Miller88 Offline
M
A lot of the quick lube / bearing buddy systems seem to ONLY lube the outer bearings from what I have seen.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Compatibility (again) [Re: Dieselanddogs] #5342026 02/05/20 04:10 PM
sloinker Offline
Pull the hub off the axle. Clean all the grease out and use a moly based grease that is ropy/tacky to hand pack the bearings before re-assembly. Do this once a season on both sides. Buy a few extra seals and replace them once a year when you do this maintenance. I was under the impression that the zerk fittings on the hubs were for displacing water on trailers that get backed into lakes. You don't see them on any other applications such as front wheel bearing on cars etc.....
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
