Originally Posted by ZeeOSix
Originally Posted by dlundblad
I would argue they flow the same.
They will flow the same because of the PD oil pump.
But if louvers are closed up it can cause much more delta-p across the filter, which in turn can make the bypass valve open up. Ideally, you want a small delta-p as possible across the filter. When someone says it "flows better" when a PD pump is involved, it really means there's less delta-p due to flow.
But, how can you determine if the louvers are closed? I'm thinking an oil pressure gauge entering and leaving? But, how many people will have this set up? And, how many people stop to wonder if the louvers are closed? How many consumers know that an oil filter has louvers, holes, squares, triangles, etc., in an oil filter?
Use a flashlight and your eyes. There's been photos posted many times showing good vs bad formed louvers.
What you're saying is, EVERY oil filter buying consumer, including me, must now bring a flashlight with them to stores, oil change outlets, etc., to check their oil filter before it's installed on their vehicle? Is this what you do in the store? What kind of flashlight do you recommend.
SMH!
