Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
100 registered members (ARCOgraphite, Anduril, 28oz, 2009Edge, Alfred_B, aircooled, 8 invisible), 2,295 guests, and 17 spiders.
Topics301,901
Posts5,205,029
Members70,798
Page 1 of 5 1 2 5
Louvers VS Holes #5341386 02/04/20 10:26 PM
BlueOvalFitter Offline OP
Which flows oil better? I want to say holes but louvered filters seem to have more louvers than a filter with holes.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341388 02/04/20 10:27 PM
B
bbhero Offline
B
It's the holy war LOL
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341395 02/04/20 10:33 PM
Z
ZeeOSix Offline
Z
The one with the most area flows more. If louvers are barely opened up, then they won't flow as well. Always visually inspect louvers before buying. If louvers are opened up well, then there should be more flow area than the typical hole-y center tube
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341407 02/04/20 10:53 PM
slacktide_bitog Offline
The ecore plastic cage banana
It seems that louvers are harder to make properly than holes. There are many filters posted on BITOG where the louvers aren't completely opened up.
Hastings/Baldwin is the only one that seems to know how to properly make a slotted center tube, but their louvers are formed differently.So the Hastings/Baldwin louvers are better than round holes, but most other louvers are inferior.
Re: Louvers VS Holes [Re: slacktide_bitog] #5341408 02/04/20 10:54 PM
4WD Offline
They way I fixed mine was to cut it open - remove the media - flip over the tube and look into the well opened louvers from the other direction.
Re: Louvers VS Holes [Re: bbhero] #5341455 02/05/20 12:33 AM
Now this is a funny reply, unlike a sarcastic one.
crackmeup
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341456 02/05/20 12:40 AM
I had to go to WM earlier today to pick up some meds. I rode over into the filter section to look at a M1 209 and 211. There were no 211's. The 209A had louvers compared to the filter I cut open, which had holes. Also,, I couldn't tell if the 209A had a base end bypass. shrug.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341493 02/05/20 04:02 AM
T
tig1 Offline
T
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341495 02/05/20 04:12 AM
dlundblad Offline
I would argue they flow the same.
Use a quality brand and you’ll have no issues.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Louvers VS Holes [Re: dlundblad] #5341499 02/05/20 04:22 AM
Z
ZeeOSix Offline
Z
They will flow the same because of the PD oil pump.
But if louvers are closed up it can cause much more delta-p across the filter, which in turn can make the bypass valve open up. Ideally, you want a small delta-p as possible across the filter. When someone says it "flows better" when a PD pump is involved, it really means there's less delta-p due to flow.
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341540 02/05/20 06:25 AM
O
ofelas Offline
O
Interesting thread.
Now you've got me curious about whether the Donaldsons I use have louvers or holes.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341579 02/05/20 07:11 AM
B
BMWTurboDzl Offline
B
All else being equal,
Louvers = less turbulence = better flow ???
435i
Re: Louvers VS Holes [Re: ZeeOSix] #5341581 02/05/20 07:15 AM
But, how can you determine if the louvers are closed? I'm thinking an oil pressure gauge entering and leaving? But, how many people will have this set up? And, how many people stop to wonder if the louvers are closed? How many consumers know that an oil filter has louvers, holes, squares, triangles, etc., in an oil filter? shrug
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341695 02/05/20 10:06 AM
Snagglefoot Offline
Virginia is for Louvers.
If you want the job done right......do it yourself.
Re: Louvers VS Holes [Re: BlueOvalFitter] #5341803 02/05/20 11:59 AM
CT8 Offline
Depending uppon the quality of the louvers the flow will be adequate.
2015 F150 2.7
2018 F350 6.2
Page 1 of 5 1 2 5
