Getting Film Off Wheels
by Nick1994 - 02/16/20 08:58 PM
Moog wheel bearing and knuckle assy
by Imp4 - 02/16/20 07:37 PM
Daytona 500 engine related question
by OilUzer - 02/16/20 07:37 PM
2006 Subaru Forester 2.5 NA
by 762fermeandyou - 02/16/20 07:29 PM
DIY Paintless Dent Removal....
by dblshock - 02/16/20 07:17 PM
Bad sports teams
by 53' Stude - 02/16/20 06:42 PM
Valvoline 20W-50 Baja 1000 Race oil
by kstanf150 - 02/16/20 06:21 PM
How to stand on the roof of a Saturn Vue?
by atikovi - 02/16/20 06:09 PM
Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
Castrol Edge 5w20 and 5w30 Costco
by nlife - 02/16/20 02:41 PM
Generator Hour Meter
by spasm3 - 02/16/20 01:44 PM
FlightRT, 74Widebody, mmmmmnnn, jjrockbush, eamerritt
70721 Registered Users
130 registered members (2015Corolla, 4WD, 2010Civic, AdmdeVilleneuve, Aero540T, 15 invisible), 2,097 guests, and 38 spiders.
Topics301,541
Posts5,197,621
Members70,721
Two Guns - Recommend Greases? #5341241 02/04/20 07:46 PM
A
Astro_Guy Offline OP
A
I bought my first gun in the early 80's and basically put grease in it. I recall it being black at the time. That was a time when cars and trucks had grease fittings for the suspension and steering. Chassis and steering points were what you greased back then; that time is gone.
Rolling the clock forward some 35 years, I've been using red Lithium complex grease for the lawn toys. The last fill on that gun was Lucas Red 'N Tacky. Maybe it was two tubes - I don't recall.
What I do know is that the Lucas RNT leaks a lot of oil from the gun, so I bought new gun and filled it with another grease, rather than toss a full load of RNT from the original gun. Now I have a NGLI #2 GC-LB High Temperature grease in the in the new gun. Should I just toss the old gun once the Lucas RNT is gone, or is there a different grease that a homeowner in the Northeast might consider?
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5341258 02/04/20 07:59 PM
T
tundraotto Offline
T
1- Any 'good spec' GC-LB rated grease (bearings etc)
2- Highest moly content (5%) grease (high load-low speed applications=tractor pins, mower spindles etc)
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5341265 02/04/20 08:04 PM
Snagglefoot Online Content
Online Content
The Chevy 2500 has 9 grease fittings in the front suspension at least to 2018. My 2008 3/4 ton has 11 fittings. Not sure about 2019 and 2020.
I’m thinking you have it covered with those two guns but Bittoggers are very finicky with their grease. Let the opinions flow in. coffee
If you want the job done right......do it yourself.
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5341532 02/05/20 06:18 AM
O
ofelas Offline
O
Ah. Grease guns.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5341533 02/05/20 06:19 AM
J
joekingcorvette Offline
J
Ha! I thought you were asking about firearms! LOL The only vehicle I have that needs grease is the Corvette and its on the rear end links of the suspension. I use marine grease on it because I use the same grease on the Lund boat motors and steering rods. It's probably not the best but it seems to work ok on the Corvette. Sorry I can't help you much.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5341798 02/05/20 11:57 AM
CT8 Online Content
Online Content
John Deere Polyurea.
2015 F150 2.7
2018 F350 6.2
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5341832 02/05/20 12:28 PM
P
PowerSurge Offline
P
CT8 has it. Mobil also has it in a blue tube.
Re: Two Guns - Recommend Greases? [Re: joekingcorvette] #5342224 02/05/20 08:22 PM
A
A
Originally Posted by ofelas
Ah. Grease guns.
Originally Posted by joekingcorvette
Ha! I thought you were asking about firearms! :LOL.
Sorry for the confusion. I should have known better considering the posts I've seen here involving grease and shotguns used in competitions. Is grease acceptable for the slides on semi auto pistols?
Re: Two Guns - Recommend Greases? [Re: PowerSurge] #5342256 02/05/20 08:57 PM
A
A
Okay - I am listening, but from what I understand, Lithium complex and Polyurea greases aren't compatible. Where would I use a Polyurea grease that wouldn't already have a Lithium complex grease is use? I am pretty sure that I've seen both blue and red grease on my various machines, but I've been using only red grease for the last year or two. Who knew that grease was so complicated?
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5342318 02/05/20 11:14 PM
P
PowerSurge Offline
P
Haha I hear ya. Then go with Mobil Polyrex EP 2 for lithium compatibility.
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5342648 02/06/20 11:56 AM
N
nthach Offline
N
Loctite C5-A, supposedly Glock's favorite. Oh wait.
I have WD-40 Specialist True Multi-Purpose Grease in my grease gun. Calcium-based on over-based calcium sulfonate but also claims compatibility with Li-complex greases and self-certified to NLGI GC-LB, since the rest of WD-40's greases are Li-complex.
Since I want to lube the slip yokes on a friend's GX460 soonish, I'm buying a small grease gun and packing it with Red Line CV-2. I have a needle-tipped gun for the bikes that was filled with Mobil Delvac Grease, but that has been since filled with Mobil 1. I really should be using Shimano's relabel of Agip Autol Top 2000/Motorex Bike Grease for the bikes.
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5342652 02/06/20 11:59 AM
J
Jddan Offline
J
Astroguy, I personally use texas refinery 880 crown and chassis... because it doesnt drip oil, it ran cooler in the variable speed in my combine than any others I had tested, and I dont work under water or in extreme heat (like 500 degrees, not like i stop working in the summer), so i felt their paragon 3000 was more money than i needed to spend given the applications. So far I have not been disappointed. Im sure theres other greases that would perform just as well, but when I found one that worked I stopped looking
Re: Two Guns - Recommend Greases? [Re: Astro_Guy] #5342941 02/06/20 06:07 PM
CT8 Online Content
Online Content
Shear stabilized polyurea grease is compatible with many greases,
2015 F150 2.7
2018 F350 6.2
