Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
49 registered members (antone, 2002 Maxima SE, Bailes1992, bbhero, Amkeer, 6 invisible), 1,292 guests, and 16 spiders.
Topics301,732
Posts5,201,612
Members70,763
'01 Ranger 4.0L Thermostat Housing Seal Leaking #5341216 02/04/20 07:27 PM
B
benjamming Offline OP
B
2001 Ford Ranger 4.0L SOHC with 150k miles
I replaced the thermostat & o-ring at 145k miles. It's been leaking since. Took it apart & saw that the upper thermostat housing was buggered up on the sealing surface. Installed a new Ford Motorcraft part (only $10 and made in Great Brittain!). Still leaks between the upper & lower thermostat housing. Took it back apart & the o-ring (Fel-Pro p/n 35617) doesn't fit tight around the thermostat, but I don't think it's supposed to as the housing does the sealing. Is that right? Also, o-ring looks a little flat but I torqued the 3 bolts to 89 in-lb per the factory service manual. Is there a trick that I'm missing? I've got another o-ring, but I wanted to check in to see if I'm not doing something correctly before installing & putting back together.
Thank you.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341224 02/04/20 07:37 PM
K
Kira Offline
K
I've read about the housing.
The PO of my Ranger had it replaced at a local garage and I have no details. I've never given the thing a long, hard look.
I did read about a metal one which is supposed to be the cat's meow.
Go here: simmonsautosportz.com Look up the SA9. I think you can call 'em about it.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341230 02/04/20 07:43 PM
Chris142 Offline
Replace the bottom housing. That's what goes bad. Rarely does the top.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341235 02/04/20 07:44 PM
K
Kruse Offline
K
The metal replacements SEEM to be a better replacement to the cheap plastic housings. They are available on ebay and RockAuto, at least, the last that I looked.
More expensive, but seem to be well worth it. If I ever have a thermostat leak, I'll use the metal replacement.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341245 02/04/20 07:50 PM
B
B
Yeah the top was gouged along the sealing surface. Maybe it was fine, but I don't see how it would've sealed.
The bottom doesn't look bad. What should I be looking for as the failure? I would like to know for sure before removing the intake and all the other stuff. This should've been a simple thermostat replacement. Argh!
$135 for the Simmons metal one. Another Ford plastic one is $45 from online Ford parts department.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341257 02/04/20 07:59 PM
K
Kruse Offline
K
There are cheaper alternatives to both the metal and the plastic replacements. The Ford plastic part will eventually leak just like the plastic aftermarket part will eventually leak.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341264 02/04/20 08:04 PM
Chris142 Offline
This is the sohc engine?
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341267 02/04/20 08:06 PM
B
B
Yes SOHC.
I just can't see how the lower is leaking as the sealing surface looks fine. Does it flex & cracks appear when under pressure that aren't visible when opened up?
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341281 02/04/20 08:22 PM
bdcardinal Offline
The whole thing leaks, you need to replace everything.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341293 02/04/20 08:37 PM
B
B
So, is 150k miles about normal replacement interval?
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341296 02/04/20 08:44 PM
01rangerxl Offline
Yeah, I think whole housing replacement is the way to go. My friend recently tried replacing just the t-stat with the same result. Ended up buying a Gates complete housing replacement with a lifetime warranty.
When I worked in a shop that saw a lot of SOHC 4.0s, we only qouted the whole housing.
The better aftermarket metal ones like Simmons are one piece below the thermostat, eliminating a large potential leak point.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341307 02/04/20 08:53 PM
G
GearJammer Offline
G
Do not get a Dorman lower housing whatever you do. Ask me how I know. This is one occasion where a genuine Ford part is worth every penny.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341327 02/04/20 09:14 PM
B
B
So, are the 2 sensors typically replaced at the same time?
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341364 02/04/20 10:01 PM
bdcardinal Offline
Ford does not sell the o-rings by themselves so we replace the sensors.
Re: '01 Ranger 4.0L Thermostat Housing Seal Leaking [Re: benjamming] #5341372 02/04/20 10:10 PM
N
nobb Offline
N
I'm not familiar with the 4.0, but on the 3.0 the housing is metal and there is no need to replace that. What I did notice is that the fiber gasket doesn't always seal perfectly even when you have everything cleaned up and torqued to spec. BUT over time (like a few months) the gasket expands and leak stops. Fel-Pro does make a top of the line gasket which has rubber ridges instead of the standard fiber gasket which should hold up much better. I think they should've designed the housing with more than the two bolts holding it which doesn't provide as strong/even of a clamping force.
