drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
104 registered members (53' Stude, antone, 1978elcamino, 928, Astro14, 2015_PSD, 8 invisible), 2,413 guests, and 21 spiders.
Topics301,750
Posts5,202,058
Members70,766
'99 Taurus power steering pump leak. Is this o-ring available? #5341207 02/04/20 07:20 PM
A
atikovi Online Content OP
OP Online Content
A
Got a bad leak at the bottom of the pump where the reservoir supply tube attaches to the pump.
[Linked Image from fototime.com]
Parts diagram from 2002 shows 2 o-rings with part number F6DZ-3C633-BB but nothing useful comes up in a search.
Anybody know a good number for those o-rings or an aftermarket alternative? I hate to spend $50-$80 on a pump if a $2 part will fix it.
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341217 02/04/20 07:27 PM
E
eljefino Offline
E
Measure their diameters, the numbering system is standardized. Or just get the monster 660 pc kit from HF.
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341237 02/04/20 07:44 PM
Chris142 Offline
Take them out and match them up.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341250 02/04/20 07:53 PM
H
hallstevenson Offline
H
As the two above alluded to, o-rings are typically standardized. No designer in their right mind creates a connection that requires a [censored] o-ring. The hole, counterbore, etc are made to fit existing o-ring sizes.
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341259 02/04/20 07:59 PM
A
OP Online Content
A
OK, but metric sizes?
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341300 02/04/20 08:47 PM
A
A_Harman Offline
A
Get on the Apple Rubber or Parker-Hannifin web sites. They have online catalogs. Metric or inch. There are other sizing systems, like for straight-thread o-ring boss fittings. If you have digital calipers, measure the section thickness of the o-ring, then use a ruler to measure the ID.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341352 02/04/20 09:44 PM
H
H
Yes. It's been around a few centuries and is in use throughout the globe. It's not really a new thing....
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341463 02/05/20 01:09 AM
W
Wolf359 Offline
W
Have you checked with the dealer? I seem to recall the same problem in my 2001. The dealers had the washers, but they were plastic ones. Didn't really work and I just ended up getting an aftermarket pump to fix the leak. The 2001 was a different generation though, 4th gen vs the 3rd gen of the 99.
Re: '99 Taurus power steering pump leak. Is this o-ring available? [Re: atikovi] #5341524 02/05/20 06:08 AM
K
krismoriah72 Offline
K
My local NAPA had about 10 Kits, plus they would bring out micrometers and match me up. One of the hardest to find took two guys about 35 mins to find the right one.. part was $1 or something.
