Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
101 registered members (53' Stude, 28oz, alchargo, 928, Aichiguy, AandPDan, 5 invisible), 2,522 guests, and 18 spiders.
Topics301,748
Posts5,202,004
Members70,766
05 Acura TL, PUP 5w30, 6k miles, Particle Count #5341203 02/04/20 07:17 PM
Daverino Offline OP
[Linked Image]
[Linked Image]
The engine is a 3.2 liter V6, Honda J-series with a timing belt.
This interval was done on almost entirely interstate highway, very few heat cycles. But desert dust and wildfires were common.
The oil used was Pennzoil Ultra Platinum 5w30. My engine calls for 5w20. I tried this due to wondering about a slightly thicker oil for an old engine run hard in high temps.
The wear metals don't look that much different than before though. I think I will stick with 5w20 from now on.
The air filter is Honda OEM and was changed at 189,000 miles, so roughly 25,000 miles ago for this sample. Still running it now at 220,000 miles.
The oil filter was left over from the last oil change interval, it was a Fram Ultra XG 7317. I also run a few powerful but tiny magnets on the outside of the filter.
The short miles on this sample is due to my own timing and availability, I would preferred a longer run but that was when I had the time to change it.
-- Please help me to understand the particle count data. Is it good, bad, typical at 24/21/15? Should I be looking to improve it or leave it alone?
I was curious about the particle count so that is why I decided to try it this time. Thanks for any insight into this.
"Daverino has the direct Bat Phone line." -georgemiller
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5341255 02/04/20 07:58 PM
JohnnyJohnson Offline
Looks fantastic for a V6.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5341277 02/04/20 08:18 PM
ctechbob Offline
*yawn* another good Pre-VCM J series. grin2
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5341291 02/04/20 08:36 PM
T
tcp71 Offline
T
The insoluables may be from the smoke. Smoke particles can get through the air filter and then clump up to grow in size while circulating through the oil system. Similar to soot in a DI engine.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5341358 02/04/20 09:55 PM
R
rubberchicken Offline
R
What have you done in relation to the timing belt ? I think they call for 100k intervals ?
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: rubberchicken] #5341377 02/04/20 10:13 PM
Daverino Offline OP
The timing belt was done by a Honda specialist here in Texas. I try to do as much as I can myself but decided that potentially messing up the timing belt wasn't worth the risk for me. The shop uses OEM parts only, and they weren't interested in hearing about the well received Aisin kits. It was expensive but I like knowing that the car is ready to cross the country at any time.
I did change out the compliance bushings and the front struts with OEM parts, and its gotten a couple of compliments on the ride quality. That was at 189,000 miles, and just recently (at 220,000) I cleaned the EGR (didn't need it) and the throttle body to cure a rough idle. It worked and she idles like new now.
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5341560 02/05/20 06:48 AM
A
aquariuscsm Offline
A
Looks great!
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5344322 02/08/20 07:04 AM
DuckRyder Offline
Have a look at:
https://www.machinerylubrication.com/Read/28979/iso-cleanliness-code
Also we’ve had a bit of discussion about this in the UOA forum as well as the Filter forum. I've done a few on the Civic that I recently sold at similar mileage...
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 05 Acura TL, PUP 5w30, 6k miles, Particle Count [Re: Daverino] #5344499 02/08/20 10:27 AM
T
Triple_Se7en Offline
T
Next time you buy PUP, the additives will be differently dispersed, due to reformulated for SN Plus. Base oil may have a little difference also.
https://www.bobistheoilguy.com/foru.../pennzoil-ultra-platinum-voa#Post5241871
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
