EV6 Injector.....GM# 15305086, Mouser Part# 829-15305086
MAF, 5-Pin Delphi.....GM# 15305555, Mouser Part# 829-15305555
MAP, 1-Bar.....GM# 12129946, Mouser Part# 829-12129946
CKP, 24x....GM# 15324165, Mouser Part# 829-15324165
CMP, 1x......GM# 12059595, Mouser Part# 829-12059595
ECT, ISS, OSS.....GM# 15336024, Mouser Part# 829-15336024
Bank 1 & 2 Coil Harness Jumper.....GM# 12047938, Mouser Part# 829-12047938
Knock Sensor Harness Jumper......GM# 12052641, Mouser Part# 829-12052641
TPS (Cable TB).....GM# 12078090, Mouser Part# 829-12078090
IAC (Cable TB).....GM# 12162190, Mouser Part# 829-12162190
Bank 1 & 2 (Upstream) O2 Sensors.....GM# 12176897, Mouser Part# 829-12176897
*Use GM# 12573005 or Denso# 234-4668 Oxygen Sensors
OE P01 & P59 PCM connectors are discontinued by GM & Aptiv (formerly Delphi), I recommend buying a Connector Kit from EFI Connection.
*'99-'02 P01 PCM (Blue/Red)
HERE
*'03-'07 P59 PCM (Blue/Green)
HERE
Probably cheaper solutions out there.....But these kits are very complete & high quality!!
4L60E & 4L80E connectors have been discontinued by GM & Aptiv (formerly Delphi), AC-Delco offers a repair kit that includes the connector....Part# 12154288, Here's one on E-bay for $65
HERE That's cheap as they retail for $100
*****Let me look around, I probably have one I can send you!
*****Use the leftover terminals from the PCM connector Kits for the Trans Connector as they're the same, Even if you buy the Delco repair kit.....You don't want all those splices in your harness!!!
Data Link W/Bolt tabs......GM# 12110250, Mouser Part# 829-12110250
