Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
67 registered members (AC1DD, apollo18, bdcardinal, Ag76, Avery4, ammolab, 3 invisible), 1,185 guests, and 23 spiders.
Topics303,465
Posts5,235,622
Members71,074
Page 1 of 3 1 2 3
Fuel economy worse in cold temperatures #5340883 02/04/20 02:26 PM
G
gj Offline OP
G
2019 Mitsubishi Mirage . Current mileage is 9700 miles .
Purchased new July 2019 .
1.2 -3 cylinder . CVT Auto transmission .
I've noticed the computer read out for MPG's in the winter is about 10 to 12 MPG's worse than in summer .
Warm weather I've seen as much as 56 MPGs sometimes more . I'd say average is 42 mpg .
Since it's turn colder i rarely see the read out in the 40s .
High 20s to 35 mpg .
If there happens to be a few warm days during winter , sure enough the MPG's will be in the 40 to 50 plus MPGs. So I figure tire pressure can be ruled out .
I've read on Mirage forums this is common . Never really heard any explanation to explain it . Not the end of the world but just curious what could be wrong if anything .
Maybe common with most vehicles and I'm just now noticing it due to the technology . Appreciate any information . Thanks
[Linked Image]
Re: Fuel economy worse in cold temperatures [Re: gj] #5340888 02/04/20 02:31 PM
Quattro Pete Offline
How long is your commute?
In general, it's quite normal for fuel economy to be worse in cold weather - engine takes longer to reach operating temp; air is denser; gasoline has winter additives, etc.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Fuel economy worse in cold temperatures [Re: gj] #5340900 02/04/20 02:51 PM
B
bullwinkle Offline
B
Get a whiff of your exhaust sometime on a cold start, it’ll smell like raw gas coming out of the tailpipe! Add in stiffness of anything greased or lubricated, and the lower energy content of winter fuel, (and lower cold tire pressure too)- it’s no surprise winter MPGs drop. Heater use before fully warming it up can hurt too, bundle up!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Fuel economy worse in cold temperatures [Re: gj] #5340908 02/04/20 03:09 PM
B
BigCahuna Offline
B
Three things can affect your mileage. 1- winter blended fuel, 2- your cars cpu adds extra fuel to make the motor run smooth and not cough , spit ,and backfire due to the cold, 3- the brand if gas you use. I know my car seems to run better on certain brands then others. Keeping your tires aired up also helps with mileage.,,,
Re: Fuel economy worse in cold temperatures [Re: gj] #5340921 02/04/20 03:28 PM
diyjake Offline
It is normal to get lower fuel mileage in the winter but usually a few MPG's not 10-20 MPG's lower. Are you spending any time warming up your car before you drive?
Re: Fuel economy worse in cold temperatures [Re: diyjake] #5340924 02/04/20 03:33 PM
Donald Offline
+1 - something else is going on here if more than a few MPG difference.
2015 Ford F-250 w/Powerstroke
Re: Fuel economy worse in cold temperatures [Re: gj] #5340927 02/04/20 03:37 PM
B
borgward Offline
B
You can turn on your air conditioner. That helps warm up the engine. The AC is now acting as a heat pump. It is taking heat out of the passenger compartment, releasing it through the condenser coil and passing it the the engines radiator. Once you begin to feel some heat turn off the AC. It works.
I had a car that had an add on AC unit under the dash. Because it was not installed at the factory I could turn on the heat and AC at the same time causing the engine to heat up rapidly.
Small efficient engines tend to warm up slower than big engines. There are just less BTU's to transfer into the cooling system.
Re: Fuel economy worse in cold temperatures [Re: gj] #5340931 02/04/20 03:41 PM
demarpaint Offline
Winter fuel, a richer fuel mix for a longer time when starting and until the engine starts to warm up a bit, the engine taking a longer time to reach operating temperature, all contribute to "Fuel economy worse in cold temperatures." Tire pressure drops too, quite a bit depending on how cold it gets.
God Bless Our Troops
Re: Fuel economy worse in cold temperatures [Re: gj] #5340936 02/04/20 03:47 PM
I
Imp4 Offline
I
Dear lord, only a masochist or a BITOG true believer would turn on the a/c in winter to heat the engine up faster.
Now I truly have heard it all...
duh
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Fuel economy worse in cold temperatures [Re: gj] #5340949 02/04/20 04:03 PM
R
ragtoplvr Offline
R
1. Cold air is more dense, so more wind resistance.
2. Cold tires are stiffer.
3. Try covering half the radiator with cardboard. Sometime cold water entering block cost efficiency.
4. Leave heater off for the first couple of minutes until temp is 150, then run fan on low speed until at full temp. You are not getting much heat anyway but running on high speed can delay warm up several miles. That small an engine might never warm up.
Rod
Re: Fuel economy worse in cold temperatures [Re: gj] #5340966 02/04/20 04:25 PM
L
Lolvoguy Offline
L
Originally Posted by gj
[Linked Image]
Those tires look grossly underinflated.
I'd get them to a few PSI over spec.
Ride might suffer a bit, but then again, nobody buys one of those rollerskates when ride quality is of any concern.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Fuel economy worse in cold temperatures [Re: gj] #5340989 02/04/20 04:55 PM
V
vw7674 Offline
V
Transmission fluid, auto or CVT, has a serious viscosity change from even 40C to 100C.
The extra drag inside the transaxle & final drive would add up too. : ( At least till it reaches stable temp. IF it reaches stable temp.
Re: Fuel economy worse in cold temperatures [Re: gj] #5341005 02/04/20 05:08 PM
Nick1994 Online Content
Online Content
Calculate it by hand. I’m not sure I’d trust the computer all that much.
2015 Hyundai Genesis 5.0L 58k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 238k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Fuel economy worse in cold temperatures [Re: Lolvoguy] #5341015 02/04/20 05:26 PM
2
2010Civic Offline
2
[Linked Image]
They don't look underinflated at all to me... The sidewall on the top and bottom of the tire looks equal.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Fuel economy worse in cold temperatures [Re: 2010Civic] #5341024 02/04/20 05:35 PM
L
Lolvoguy Offline
L
The fronts look especially underinflated.
This pic is also probably from months ago when nearly new (no snow/ice in pic).
Say "no" to Turbo!
Page 1 of 3 1 2 3
