Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
103 registered members (Anduril, 28oz, ARCOgraphite, 2009Edge, Alfred_B, aircooled, 8 invisible), 2,298 guests, and 17 spiders.
Topics301,901
Posts5,205,029
Members70,798
Don’t assume the ignition key will unlock the doors, or you may be locked out. #5340925 02/04/20 02:34 PM
A
atikovi Online Content OP
OP Online Content
A
Bought a nice ’99 Taurus at auction and locked it up by pressing down the knobs in each door. The battery was dead so the remote wouldn’t work. When I come back to pick it up, the keys wouldn’t work in any of the locks. [censored]! It took one of the guys there 20 minutes to get it unlocked by lifting the knob with a bent hook thing.
Anyway, I’m considering my DIY options for having a (hopefully all) locks working. No I’m not paying locksmith rates on a 20 year old car. The key works the ignition and folding 3rd seat lock (it’s a wagon) and not the two door or tailgate locks. If I had the key code for the door locks I could have a key cut for a few bucks but the Ford dealer said they only have codes back for 10 years. I guess the other option is to remove the door and tailgate locks and rearrange the tumblers to fit the ignition key. Any other low cost option I overlooked?
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5340928 02/04/20 02:37 PM
dishdude Offline
Pop the cylinder out of the driver's door and take it to a locksmith to have it keyed. My guess is the ignition was replaced and the door key didn't make it to the auction. I don't believe that lock in the seat is keyed.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5340940 02/04/20 02:53 PM
Donald Offline
Ford had 2 keys awhile ago. One with a squarish head for ignition and one with a roundish head for doors. Other car companies also. People can also get a replacement ignition lock and it will be different than doors.
You must be young. The old people know this.
2015 Ford F-250 w/Powerstroke
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5340945 02/04/20 02:55 PM
A
OP Online Content
A
I'll pull the door lock and report back.
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5340950 02/04/20 03:04 PM
G
getawheel Offline
G
Spray some penetrant in the locks and try the key a few times. Exterior Ford lock cylinders from that era tend to stick when not used often.
Almost every '90s Ranger/Explorer/F-series with power locks I have encountered, the lock cylinders are stuck. This always fixes it.
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: Donald] #5340953 02/04/20 03:04 PM
G
GSCJR Offline
G
Yes, but in '99 I doubt there were two different keys.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 156KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 176KM
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5340970 02/04/20 03:27 PM
B
Blkstanger Offline
B
Door locks are a breeze to pull out on those. Have it keyed.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: getawheel] #5340993 02/04/20 03:56 PM
A
OP Online Content
A
Guy is a genius. Sprayed WD40 into the locks and all three are working fine. Thanks!
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5341023 02/04/20 04:34 PM
1
1978elcamino Offline
1
Back in the day, Ford had a square ignition key and a round door key. Later on they went to the larger key with the black plastic portion where the ring goes into. Models with the larger black plastic key should have just one key. Its possible it was stolen and the ignition cylinder was replaced in the past.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5341045 02/04/20 04:51 PM
J
Jethro_Bob Offline
J
Good choice on WD40,on most fords of that era, the dome light switch is on the door hasp assembly, anything that doesn't evaporate quickly will gum up the switch causing the light to stay on.
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5341077 02/04/20 05:28 PM
sloinker Online Shocked
Online Shocked
I know the trucks were using two different keys into the 90's.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5341139 02/04/20 06:22 PM
01rangerxl Offline
I would bet it was originally equipped with keyless entry and they hardly ever used the key in the doors.
I have a friend who is a locksmith, primarily automotive, and he swears by WD40 in lock cylinders. I asked about graphite, and he said it gunks them up.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: sloinker] #5341149 02/04/20 06:30 PM
01rangerxl Offline
Only until about '91 or so, but a lot of them now have two keys because the cylinders were still janky until 96-97 or so.
My 94 Ranger was originally a single key, but the ignition cylinder has been replaced and the key codes are too far apart to make one key work. My 94 Explorer amazingly has all original cylinders and one key works all of them.
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: 01rangerxl] #5341185 02/04/20 06:59 PM
bdcardinal Offline
You also see 2 because some of the aftermarket ignition cylinders come with their own keys on the 8 cut ones. On the 10 cut keys, the new ignition cylinders come with keys half cut with 1 cut shared on the door keys. Then a competent parts person traces the other half. On the 8 cut keys, like OP, the ignition cylinders from Ford don't come with keys, you build the cylinder to the existing key. I have found a lot of times that a key cut by code instead of traced, will magically make a stuck cylinder work again. But Ford only provides key codes to dealers currently for 2010+MY vehicles. I measure the cuts and use my decoder book to get the key cut code.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Don’t assume the ignition key will unlock the doors, or you may be locked out. [Re: atikovi] #5341221 02/04/20 07:34 PM
01rangerxl Offline
I think the ignition key on my 94 Ranger is one of those half cut keys, so maybe it can be made single key again.
