The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
39 registered members (1WildPig, 74Widebody, 3311, 69GTX, ArrestMeRedZ, 4 invisible), 1,055 guests, and 17 spiders.
Topics301,682
Posts5,200,441
Members70,756
Fram extra guard #5340812 02/04/20 11:47 AM
B
Bettez88 Offline OP
B
Let’s be honest, can the extra guard be pushed past 10k miles? I know the mileage rating usually is just for warranty purposes. I’d be using them on clean engines only run on full synthetic from their first oil change.
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Fram extra guard [Re: Bettez88] #5340828 02/04/20 12:16 PM
K
kschachn Offline
K
Let's be honest, are you contemplating actually doing this or are you just posting a completely hypothetical question for discussion purposes?
Clogging of the media isn't the only concern for a long OCI.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Fram extra guard [Re: Bettez88] #5340874 02/04/20 01:19 PM
H
hallstevenson Offline
H
Fram says it's good for "OE recommended intervals". You can be sure that they looked at all intervals spec'd from all, regular manufacturers (GM, Honda, etc but probably not the less common ones), tested it, and are confident it will work fine. Then they build a safety factor in as well.
Are you suggesting that Fram is lying or giving misleading info ?
Re: Fram extra guard [Re: Bettez88] #5340904 02/04/20 01:59 PM
B
bullwinkle Offline
B
On a Fit or Corolla, with 0W20 and a CLEAN, non-slugged engine, I would say yes-but I would run one for a factory length OCI, cut it open (or send it to a member here who can), and see what it catches & what condition it’s in. I run Ultras for 20K-but I didn’t run the FIRST one that far!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Fram extra guard [Re: Bettez88] #5340905 02/04/20 01:59 PM
M
Matagonka Offline
M
Depending on the engine size and oil pressure. I would not!
2018 Mazda 3 Touring HB 2.5
Re: Fram extra guard [Re: Bettez88] #5340910 02/04/20 02:09 PM
M
MParr Offline
M
Let me be honest, I won’t run an Extra Guard on my ZTR. If you want to go 10,000 miles, at least pick the Tough Guard.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
2014 F-150 4x4 Now: Unk & Motorcraft FL-500s
Re: Fram extra guard [Re: Bettez88] #5341000 02/04/20 04:01 PM
B
Bettez88 Offline OP
B
Not a hypothetical question here, seems like most Honda minders end around 12000 miles. Would that be pushing the extra guard?
Re: Fram extra guard [Re: MParr] #5341003 02/04/20 04:02 PM
53' Stude Offline
Well, I have a tough guard on my Camry that is being repaired and it has 26k on it. Yes I do have guts crzy
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Fram extra guard [Re: Bettez88] #5341011 02/04/20 04:21 PM
CR94 Offline
Not likely, assuming a clean engine and non-adverse conditions. What are you imagining might happen?
2011 Toyota Prius now at 109K
Re: Fram extra guard [Re: Bettez88] #5341072 02/04/20 05:21 PM
H
H
Honda knows the longest interval that their system will indicate (or they'll override it in software to make it drop to "0" quicker) and they're comfortable with that number. They don't require any special oil filters either. In fact, their minder is designed to specify changing only the oil (leaving the filter in place), an Ax service, or changing the oil and filter, a Bx service.
Re: Fram extra guard [Re: hallstevenson] #5341603 02/05/20 07:54 AM
B
Bettez88 Offline OP
B
Correct, so there’s no reason I couldn’t use an extra guard on a Honda running the minder then
Re: Fram extra guard [Re: Bettez88] #5341956 02/05/20 02:31 PM
BlueOvalFitter Offline
This is a very good Q?
I just recently received an EG-3600 oil filter along with some 5W30 Signature Series Amsoil. I will be using the 3600 with the Amsoil to AT LEAST 10K miles and am wondering can the 3600 go that distance.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Fram extra guard [Re: MParr] #5342207 02/05/20 08:04 PM
D1dad Offline
I’ll use Fram in my zero turn and push mower. They’re 1/3 the price of a dealer filter.
Re: Fram extra guard [Re: D1dad] #5342481 02/06/20 07:02 AM
T
tundraotto Offline
T
Me too...
But what kind of push mower has an oilfilter?
Re: Fram extra guard [Re: tundraotto] #5342493 02/06/20 07:21 AM
B
buddylpal Offline
B
Me too...
Some John Deere push mowers had oil filters up until about 10 years ago. No idea about today though.
A couple GM's and a Hyundai.
