Oil Consumption Check-in!
2015 Ford focus 1.0L ecoboost, 181K miles, zero oil consumption, OCIs every 5K miles at dealer with 5w-20 semi-syn
2004 Tacoma 3.4L V6, 235,000 Miles, No Consumption. 10w-30 Synthetic Changed between 6-7k
2018 rogue maxlife 0-20 no consumption
09 altima 1 qt per 1k, no matter what 5w or 10w30 I use. No oil consumption the first 700 miles then it turns into a pig. I'm trying castrol gtx in this car for the first time so who knows. Either way I've got a 30k engine to drop in when I get time.
2004 Nissan Quest VQ35DE 192,000 - maybe 1/4 after long highway run, but not always perceptible on dipstick.
1990 Nissan 300ZX VG30DE 110,000 - no consumption
2005 Ford Taurus OHV Vulcan 202,000 - no consumption
2003 Ford Excursion 7.3 PSD 223,000 - maybe 1/2 quart after towing 30' travel trailer.
2008 Subaru Outback 2.5 non-turbo, 186,500 miles, 1 quart every 2000 miles.
2003 Dodge Ram2500, 5.9 Cummins Diesel, 187,000 miles, no measurable consumption.
2001 Mazda Miata, no oil burning.
1992 Toyota Pickup, 22RE, 321,000 miles, no oil consumption between 3-4K mile OCI.
2007 Acura MDX - 3.7 V6 195k - 1/2 quart every 5k-6k miles.
2018 VW Tiguan 55k 2.0L Buddack? - under 1/4 quart(do not top) over 10k miles OCI
2001 F350 5.4 with 1997 F150 5.4 engine. 225k miles on engine. 1 quart every 1000 empty, can burn up to 1 quart every 100 miles if towing. I have played around with TCW3 in the gas at 640:1 and it has helped with towing consumption.
2000 Jeep 4.0 with 214K miles: No measurable consumption *or* leaks. I did the oil change in it like 2 years ago and it's still just as full as when I changed it.
2018 Forester: 26K miles. Maybe 1/2 pint over the course of the 6K mile OCI the one time I used M1. No measurable consumption on any other oil.
2006 IS350 56k miles, 0 oil consumption/leaks over 1 year OCI's
1988 325is 111k miles, 0 oil consumption/leaks over 1 year OCI's
1990 Pontiac Bonneville 3.8L. 135,000 1 quart every 2500
1966 Dodge Polara 383. 97,000 No consumption.
Wife's 2013 Chevrolet Equinox 2.4: 70,000 miles and burns about 1 quart in 2000 miles. Class action lawsuit letter says oil burning is a known issue, our VIN is eligible for repair if we're having excessive oil consumption, dealer says "too bad, so sad, you're not eligible despite what the letter from GM says".
My 2015 Honda Pilot: about 68,000 miles and burns... No noticeable amount in around 6,000 miles. Yet I have VCM which is supposedly known for oil consumption.
1977 MG Midget: Mostly drips in the catch pan down below because of a leaky valve cover and front crank seal. Maybe 1/2 quart a year. Maybe I should start dumping the catch pan into the Equinox to recycle
2009 Buick Lacrosse, 70k mile 3800 V6 pulled from a Grand Prix, only uses about 1 quart in 6000 miles.
2009 Prius, 169K - started to drink 1qt in 1500 miles. I used a round of MMO and engine flushes to get it down to 1qt/3K but with the most recent OCI with syn blend Kendall high mileage, I saw oil usage of 1qt/2K. I have VPBR for a 5-gK OCI with a FU and will try a piston soak next to get it up to 3-4K between top-offs. I'll use HM synthetics only. The car saw PP and M1 from new, except for a 1K OCI of QSGB and one with PYB.
2005 Toyota Sienna and Lexus LS430 with 143K and 56K on the clock - no consumption. The van is using PPUP D1G1 I had stashed and the LS is using Idemitsu Zepro. Both in 5W-30.
I'm keeping tabs on a friend's Forester he bought from his mom when she bough an Ascent - and it's the problem child 2012-2013 production FB series. I've changed oil on it a few times and it did drink Castrol Edge or Mobil Super Syn at the rate of 1qt/2500K. I have Idemitsu 0W-20 in it for the last 3 OCIs. The first one 1 topped off with a quart of Peak(Warren) around 4200 miles. The last two OCIs had no top offs. I think I will stay with Idemitsu on this engine or switch over to a Euro 0W-30/40.
2018 Ram Promaster 3.6 Pentastar 15K-no consumption
2015 Jeep GC 3.6 Pentastar 47K no consumption
2014 Toyota Camry 2.5lt 72K no consumption
2003 Jeep Wrangler 4.0lt 99k no consumption
2003 Chevy Silverado, 5.3L, 189K, no consumption over 6K oci's. Well, honestly, it did burn a bit of oil during one oil change...was M1 AFE 0W-30. Lost a quart over 6K miles. Went back to 5W-30 next change and the burning quit.
1990 c1500 5.7 160k 1/2 qt. 4000 OCI M1 10-30
2005 XB 120k 0 4000 OCI M1 10-30
Both vanilla.
2016 2500 HD 6.0 1100 miles don't drive it much 12 mo OCI. M1 10-30 vanilla.
Company truck = complete and udder piece of frigging JUNK. 111k cab off twice scattered rear end once gobbled up turbo once gut less JUNK. I wish it would catch fire and burn to the ground on the right of way one day. Who even cares how much oil it burns and leaks on the ground.
Trans Am used a quart about 5000 to 6000 miles.
The rest of them don't show any usage.
Mobil 1 in everything. The Trans Am get 10W-30, oil changes yearly or every 5000 to 6000 miles
Everything else get Mobil 1 5W-30
Malibu 2.0 LTG Turbo every 5000 miles
Silverado 6.0 every 3000 miles
Caprice 6.0 every 5000 miles
My records will say otherwise, but M1 AFE 0w-30 is what I used in my forester when it used a bit of oil. Never happened before, hasn't happened after.
2007 Cobalt SS Supercharged LSJ - No consumption. Changed per OLM or once a year. 150,000 hard miles.
2003 Dakota 4.7 - Usually have to top off once or twice. Few ounces. Hard miles - towing in mountains. Sometimes sees WOT uphill for minutes at a time with 5000 lbs of trailer behind it. 70,000 miles.
2006 Volvo Penta 5.0 - No consumption. Annual changes. 400 hours on motor. Average use, usually cruise at 3000 RPMs with some WOT blasts thrown in for fun. Always warmed up before driven hard.
2011 Cub Cadet V-Twin Kohler - Have to top off a few times a year. 330 hours. HARD use - always under load during hot summer. Mow a few acres at a time.
2015 Sno-Tek (Ariens) 208cc - rarely have to top off, if ever. Driveway is 30 x 150, also do yard plus second driveway of same size. Always gets up to temp each use.
Everything gets manufacturer spec' weight in full synthetic.
