Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
19 registered members (3311, Compagnion, blufeb95, bbhero, BlakeB, Cdn17Sport6MT, 2 invisible), 902 guests, and 16 spiders.
Topics301,684
Posts5,200,467
Members70,756
TBN D2896 vs D4739 #5340725 02/04/20 10:12 AM
STIcandy Offline OP
Just had a VOA done by OAI/Polaris. The TBN was tested using the D4739 protocol and tested roughly 2 points lower than Motul tested with the D2896 protocol.
Reading on Polaris' own website it says that the D2896 protocol should be used for new oil samples and the latter for used oil.
My thinking is other that testing to see if the TBN from the manufacturer is correct, it really doesn't matter. In fact I would probably argue it's better to test the virgin and used samples in the same protocol in order to actually see the useful life of the engine oil and how long the TBN actually takes to diminish to the end of its serviceable life.
Would I be correct?
Re: TBN D2896 vs D4739 [Re: STIcandy] #5341041 02/04/20 04:48 PM
M
madeej11 Offline
M
Did you contact OAI-Polaris to ask why they tested using the alleged wrong protocol? Amsoil, who are affiliated with Oil Analysers use D2896 to get their +12 tbn yet most VOA's don't show this number, they usually show mid 9's. Strange... Your question: I would agree if you start with one test method you should end with the same method. You were wondering how long the tbn would last but I don't think that's a cut and dried answer, too many variables to cover.
Re: TBN D2896 vs D4739 [Re: madeej11] #5341314 02/04/20 09:01 PM
STIcandy Offline OP
Yeah maybe I'll contact them tomorrow and see why the test it like that.
