Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
Tgarst, Predator35001819, Markapuu, jds59, JimMorrison
70728 Registered Users
133 registered members (ABerns, 92saturnsl2, 2010Civic, Aero540T, antonmnster, 12 invisible), 2,138 guests, and 26 spiders.
Topics301,588
Posts5,198,635
Members70,728
Filter Bypass Pressure... Why doesn't this matter? #5340721 02/04/20 10:10 AM
A
ad244 Offline OP
A
Hey BITOGers,
I've got a question that ive been wrestling with lately. If an incorrect filter is used with the incorrect bypass pressure, wouldn't that potentially allow unfiltered oil to circulate the engine? If my Toyota specs a filter that has a 20 lb bypass spring but I use a filter with a 10 lb bypass spring, wouldn't that defeat the filtration? Or am I not understanding this correctly?
And if so, why is this not a thing we actively worry about?
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340736 02/04/20 10:32 AM
B
bullwinkle Offline
B
It does matter, but in testing done here by member Jim Allen years ago, it's not as big a deal as one thinks, except in very low temperatures & high viscosity oils. Some GM & Subaru filters need that 20+ PSI bypass, though!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340740 02/04/20 10:36 AM
Chris142 Online Content
Online Content
The bypass is a pressure differential across a plugged filter. A clean(er) filter will have the same engine oil pressure on both sides of the filter. As it plugs up or with very thick oil the bypass will open @ the set pressure. Remember that the engine bearings are what makes the pump build pressure to pump through. Not the filter.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340778 02/04/20 11:09 AM
R
ragtoplvr Offline
R
A filter that is not plugged the odds of the bypass opening is low, and most oil will still flow thru the filter. Filtered oil in the sump is already pretty clean, so there are few particles large enough to cause damage to begin with. Then said particle would have to be in the unfiltered fraction of the oil flow and go to a critical area. Avoiding higher RPM even when the engine is cold reduces the chance the filter will bypass. In the old carburetor days, fast idle used to be up to 2K RPM in some cases, and you might have to rev it higher a few times to keep it running. Odds of a filter bypass was higher then. The fuel injection motors seldom exceed 1200 RPM at idle when cold. If you start and drive off in the cold, if you try to keep minimum throttle opening in the first few minutes the bypass should not open. If you are like my neighbor, and start up, back out and then gun it cause he is going to be late to work, again. Yes, you might open the bypass. I would imagine most filters never bypass.
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340782 02/04/20 11:11 AM
A
ad244 Offline OP
A
Thanks for the explanation guys
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340787 02/04/20 11:18 AM
G
Gebo Offline
G
This is one reason I only use OEM filters on my cars and OPE.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: Gebo] #5340809 02/04/20 11:46 AM
paulri Offline
But if I get an aftermarket filter that is specified for my engine, then why worry? If the filter manufacturer is doing more than just matching the threads, they are making sure that the filter does meet the OEM specs for bypass, also, aren't they?
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: paulri] #5340829 02/04/20 12:20 PM
A
ad244 Offline OP
A
I'd say a good portion of the time we dont know the filters that we use are actually spec'd for our engine. Just that they install correctly. The pressure could be different was my concern.
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340843 02/04/20 12:40 PM
F
Farnsworth Offline
F
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340846 02/04/20 12:46 PM
F
FordBroncoVWJeta Online Content
Online Content
F
The Fram spec'd for my Jetta is 12 PSI. The oem one is 36 PSI. No way would I put a 3x different filter on my car.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340855 02/04/20 12:57 PM
G
geeman789 Offline
G
Subaru specs a high 23 psi for their oil filters. Fram does not make a Subaru specific Ultra filter for the Subaru, but lists the generic Asian fit 6607 or 7317, with a 13 psi by-pass.
Why would a large corporation list a lower psi by-pass filter for that application if there was any chance of damage to the engine as a result ? Answer ... there is no chance of engine damage. The lower psi by-pass simply opens slightly earlier, and slightly more frequently, than the higher psi valve. Meaning your oil gets fully filtered 96 % of the time, versus 98% of the time with the higher by-pass.
On cold winter days, with cold thick oil, ALL filters by-pass for at least a few minutes. It doesn't seem to hurt anything.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340872 02/04/20 01:17 PM
paulri Offline
From one website (http://oilfilterdata.com/index.php), i just found that the Fram EG3614 that fits both engines in my sig, is 12 PSI bypass. The Wix equivalent is 8-11. I could not find the Toyota oem filter specs.
Thanks for bringing this up--one more thing for us to obsess on cool
I would hope that the aftermarket filter companies would give us a filter that is similar to the OEM specs, although as you said we just don't know (unless the specs are published).
Does anyone know of Toyota OEM filter bypass pressure? My filter is the 90915-YZZD1.
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: ad244] #5340926 02/04/20 02:35 PM
Donald Offline
I always use a filter that is spec'ed for the vehicle/engine. Never just one that screws on properly.
2015 Ford F-250 w/Powerstroke
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: FordBroncoVWJeta] #5340943 02/04/20 02:54 PM
L
LotI Offline
L
Possibly lack of interest for that application. VW can’t decide on cartridge or spin-on filters!
My application is a 22psi bypass and the Fram XG12060 has so far been in very low production. New GM engines since 2013 have needed this bypass since they take the oil pressure reading from the galleys, not the pump. iirc, Subaru does the same, hence the higher bypass spec.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: Filter Bypass Pressure... Why doesn't this matter? [Re: paulri] #5340951 02/04/20 03:04 PM
F
Farnsworth Offline
F
It’s 12-14 I read that a few years ago somewhere from Toyota. The Toyota and Fram for Toyota have very similar bypass valves. You can actually put the Fram valve into a Toyota filter and vice versa. The pressure by hand feels the same. I tried it once.
Unrelated but while searching I ran across this video from Toyota. I see a .01 mm filtration claim or 10 microns. Not by the multi pass test they just say it. Actually they say less than 10 microns which has to mean essentially 10. Still it’s less.
https://m.youtube.com/watch?v=j15x1umneYI
