Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
47 registered members (ArgleBargle, Amkeer, bbhero, BlakeB, AZjeff, bmod305, 5 invisible), 1,174 guests, and 25 spiders.
Topics301,934
Posts5,205,768
Members70,801
Off-vehicle injector cleaning - worth it for PM? #5340640 02/04/20 08:53 AM
T
Touring5 Offline OP
T
I've read about people removing their fuel injectors and having them cleaned/reconditioned by specialists. I'm wondering if it is something to consider for a vehicle that isn't exhibiting problems, but may be old and/or high mileage?
The cost of the service doesn't seem prohibitive at all, and I have read accounts where PM like this (or even replacing a MAF, preemptively) made a significant improvement.
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340647 02/04/20 08:59 AM
J
jeepman3071 Offline
J
It wouldn't be worth the hassle unless you are experiencing problems. If you must, run some Techron or other injector cleaner through the fuel tank. You could potentially cause issues by taking something apart that is working well.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340653 02/04/20 09:07 AM
T
TurboLuver Offline
T
I imagine Trav will chime in on this and give you some direction.
2015 Lexus GS350 F Sport RWD
2008 Civic SI
1999 GMC Suburban K2500
1997 Jeep Cherokee Country
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340714 02/04/20 10:02 AM
A
ARCOgraphite Offline
A
I would say if fuel mileage, cylinder balance and low end torque are good ....
The would be absolutely no need.
I've had injector damage by bad fuel on ford 4 cylinders where they never recovered.
I just traded the vehicle.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340729 02/04/20 10:20 AM
P
porterdog Offline
P
Put this square into the FWIW category.
Several years ago my aging 911 was exhibiting some high load/high rpm misfire. During the diagnostics for that I pulled out the injectors and sent them for cleaning. At the time, the car was 27 years old and had ~145k miles on it. During my ownership it always got BP or Shell premium fuel. (ETA: I did also use Redline SI-1 every 12-18 months)
The injector cleaning service found them to be in-spec, and while the cleaning did improve the spray pattern some there was no real change in their fuel delivery when compared to before cleaning.
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340753 02/04/20 10:45 AM
F
ford46guy Offline
F
Maybe look into the pressure canisters for cleaning fuel injectors?
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340775 02/04/20 11:06 AM
T
Trav Offline
T
It depends on a lot of things. Some injectors have bad filters inside that no amount of in tank or rail chemicals will get rid of, the filter must be replaced, the only thing that happens is the deposits get pushed through into the injectors.
Some old style units are made of iron and brass and are prone to corrosion when used with ethanol laced fuels. Some DI injectors actually burn the filters right out and drop particles down into the nozzles.
There is no single answer to your question. Tell me the year, make and model and engine info and I can give better info.
This is an example of a clogged filter, they tried to clean them through the rail, it didn't work. The flow was poor at best, new filters and a good cleaning brought them back to 100%. Lack of primary fuel filter maintenance and dirty fuel can contribute to this.
[Linked Image]
An example of a very expensive DI unit, these need to be dismantled to access the filter under the nozzle, not a cheap job but 1/4 the price of a new one. This engine no longer ran on all cylinders.
[Linked Image]
[Linked Image]
[Linked Image]
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5340834 02/04/20 12:28 PM
B
brages Offline
B
FWIW, years ago I had a 1998 Maxima that developed a problem that sounded like a classic leaky fuel injector. It would start then immediately die, then require a couple of seconds of cranking and start with a cloud of black smoke.
I took it to a mechanic who did some kind of fuel injector clean on it and it totally fixed the problem.
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Trav] #5341146 02/04/20 06:27 PM
T
Touring5 Offline OP
T
Primarily, I was wondering about my 1999 528i (120k miles). Engine seems to run fine (at least as well as it did when I bought it with 80k). I try to do as much PM as possible (ie: cooling system, belts, etc.). The car does see periods of little use and the fuel doesn't get used up like a daily driver, that's for sure.
P.S. Thanks to all who've weighed in.
FIRST LAW OF DEBATE
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Trav] #5341681 02/05/20 09:53 AM
B
BMWTurboDzl Offline
B
[Linked Image]
Q: Are DI injectors becoming unservicable?
435i
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5341687 02/05/20 10:00 AM
T
Trav Offline
T
These are an older style long pintel Bosch unit. They are definitely dirty and effecting performance, you just don't feel it as they all get dirty and keep running smoothly. People usually attribute this to the engine is "just getting old" but in reality, if the compression is good and the engine is in good shape there is no reason for reduced power.
I usually get quite a bit more flow out of these, you notice it at higher rpm's. These are yours, the first picture is 3 cleaned and 3 as they came in, the second are the finished ones. I got about 20% more out of a few and all had a better spray pattern.
[Linked Image]
[Linked Image]
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5341706 02/05/20 10:28 AM
supton Offline
Hmm, makes me wonder. My '99 5S-FE has always had a wonky idle, a rough one, that plugs didn't fix--but it's done that for 80k and has happily chugged along. Albeit only at 31mpg, seems a bit low. Bought used so I have no idea if it's lost power or not (I don't think it ever had much to begin with).
Quick look seems to come up with Denso 23250-74100; don't need CA emissions. https://www.injectorplanet.com/products/denso-1955005580
I think my laptop still works, so I might have a working version of Techstream. I should poke around and see if I can find injector balance, not even sure what it'd be under.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Off-vehicle injector cleaning - worth it for PM? [Re: supton] #5341874 02/05/20 01:08 PM
T
Trav Offline
T
Regardless of who does the cleaning I advise against getting re hash jobs, clean yours instead. These guys buy them in barrels and dig like ones out, some may have low miles and others high. Cleaned up they work but the cores can be sketchy.
I rather dig a set from the bone yard that has lower miles and still wet with fuel and clean those if the ones in the car are very high milers or defective for some reason.
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5342168 02/05/20 07:15 PM
spasm3 Offline
Trav, have you seen many of the mazda DI injectors needing service? I have the 2.5G non turbo.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Off-vehicle injector cleaning - worth it for PM? [Re: Touring5] #5342384 02/06/20 03:01 AM
F
Falcon_LS Offline
F
I have two sets of injectors for every vehicle I own; the factory set and a flow matched set. As part of preventive maintenance, whenever I do a tune up, the old injectors are packaged and sent to Trav for cleaning and inspection. He cleans them on an ASNU machine, replaces the basket filters, individually inspects the injectors for flow and spray pattern, seals them up for storage, packages and mails them back to me.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
