Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
104 registered members (2strokeNorthstar, atikovi, 928, 2015_PSD, 2003f7, 11 invisible), 2,461 guests, and 17 spiders.
Topics303,586
Posts5,237,785
Members71,094
2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI #5340537 02/04/20 07:19 AM
STIcandy Offline OP
This is the first UOA I have personally submitted. It was taken on my Brother In-Laws 2017 WRX. 127,221kms on odometer 9,457km OCI. Let's see if I read this correctly please correct me if I'm wrong anywhere.
The iron seems to be relatively low, being a boxer motor it is most likely wear metals from the crankshaft/thrust bearings.
Aluminum is more than likely Cylinder/piston materials and the copper is going to come from the cooler on this car.
Silicon would be dirt contamination, air filter was dirty and changed at this OCI.
OAI says TBN is slightly low; maybe, but it's not even half the value of the starting TBN. I say it's still well within specs.
I'm surprised they "estimated" the fuel dilution @ >1%. I thought this is where OAI/Polaris shines over Blackstone. This was also a point of interest for me as this engine has been known to be a fuel diluter in earlier years. He is however running a Cobb stage 1 map on the car, maybe the fuel mapping is improved there. Either way with the cST @ 11.4 it doesn't seem to me like fuel dilution is an issue.
Overall, I'm pretty impressed with the results. I'm thinking increasing the OCI to 15,000kms should not be an issue with normal driving (no track use).
Any input?
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340553 02/04/20 07:40 AM
P
parshisa Offline
P
just call them and ask to do the test for fuel dilution. happened to me in the past - they won't do the test unless the viscosity is substantially low/high or out of grade. They keep a sample for a month so you can call them and request the test to be done.
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: parshisa] #5340593 02/04/20 08:51 AM
STIcandy Offline OP
Do you think it's necessary looking at the viscosity?
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340617 02/04/20 09:20 AM
J
Jackson_Slugger Offline
J
Yeah this, it's still on the thicker side of a 5W-30...
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340630 02/04/20 09:40 AM
P
parshisa Offline
P
This was also a point of interest for me as this engine has been known to be a fuel diluter in earlier years. [b][/b][u][/u] - to me it's not, but I though it is for you
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: parshisa] #5340635 02/04/20 09:46 AM
STIcandy Offline OP
just call them and ask to do the test for fuel dilution happened to me in the past - they won't do the test unless the viscosity is substantially low/high or out of grade. They keep a sample for a month so you can call them and request the test to be done.
Sorry don't get me wrong, I'm not questioning you. I was more surprised they didn't properly test for fuel dilution without being asked but I'm not particularly concerned because the viscosity is still quite strong. I would be more inclined to contact them for an exact measurement if it appeared to be shearing.
Thanks for the heads up though. In the future, I will be sure to ask them for actual reading if I'm concerned.
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340641 02/04/20 09:53 AM
P
parshisa Offline
P
No worries mate. That’s what i used to do - in a comment box on the submission form i’d specify to run fuel dilution test, that way I don’t have to call them and ask again
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340648 02/04/20 09:59 AM
B
bluesubie Offline
B
TBN is fine IMO as this oil starts at 6.0. As parshisa mentioned, OAI doesn't automatically test fuel via GC unless the oil is out of grade. Viscosity is actually very good so don't read too much into their comments. I would just ask them to test fuel via GC if you're curious.
Is this a Cobb Off The Shelf tune or an e-tune/protune? Any other mods?
'20 Subaru Outback Onyx XT | Idemitsu 0W-20 dexos 1 G2
'04 Subaru Forester 2.5XT | Castrol Edge 0W-40
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: bluesubie] #5340651 02/04/20 10:03 AM
STIcandy Offline OP
Completely stock other than the Cobb OTS stage 1 running petro 94 octane fuel. BTW what's GC?
Anybody have any reservations on bumping the OCI up another 5000 kms and retest? Seems like a waste to change the oil this soon.
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: parshisa] #5340715 02/04/20 11:05 AM
STIcandy Offline OP
Good idea. I'll remember that going forward and request it on all my UOA's. Is there a technical term for the test I should request?
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340728 02/04/20 11:20 AM
P
parshisa Offline
P
Fuel Dilution GC (gas chromatography) Test. They should know what it is anyway regardless how you call it lol
Re: 2017 Subaru WRX Motul xclean EFE 5W-30 2 months 9457kms/5876 mi OCI [Re: STIcandy] #5340758 02/04/20 11:50 AM
STIcandy Offline OP
Thanks 👍🏻
