The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
39 registered members (1WildPig, 74Widebody, 3311, 69GTX, ArrestMeRedZ, 4 invisible), 1,055 guests, and 17 spiders.
Topics301,682
Posts5,200,441
Members70,756
'96 Saturn SC2 fuel pump stuck. #5340423 02/03/20 10:34 PM
daves66nova Offline OP
10 month old Bosch fuel pump, I believe. Only about 3 hours run time. i have it parked at work. The last time that I let it sit, I banged the tank a little and the pump loosened. This time I let it sit for a few months and It stuck. I banged the tank a lot and nothing. I 'm guessing the gas gummed up the rotor. Can I add a strong dose of an additive to loosen up pump? I don't want to go through the hassle of dropping tank again. Thanks.
THIS SPACE FOR RENT, PLEASE PM ME.
Re: '96 Saturn SC2 fuel pump stuck. [Re: daves66nova] #5340436 02/03/20 10:59 PM
clinebarger Offline
It's done & will most likely cause issues from now on.
2001 Chevy Camaro L92/4L80E
Re: '96 Saturn SC2 fuel pump stuck. [Re: daves66nova] #5340445 02/03/20 11:23 PM
Spktyr Online Content
Online Content
Ethanol-laced gas gummed up the pump from sitting, pump damaged itself internally (by trying to turn when it was stuck) and is now suspect. Replace the pump and Stabil/Startron the fuel when the vehicle is going to sit, or better yet start and drive it every week.
Re: '96 Saturn SC2 fuel pump stuck. [Re: daves66nova] #5340520 02/04/20 05:23 AM
A
atikovi Offline
A
You got a defective pump. The gas had nothing to do with it. Cars sit a lot longer without having fuel pump problems. Get a new one under warranty.
Re: '96 Saturn SC2 fuel pump stuck. [Re: daves66nova] #5340749 02/04/20 10:43 AM
B
bullwinkle Offline
B
^AK & I agree on something! Take it back & get another one under warranty-you did the job once already, you should know all the shortcuts to changing it. If you keep the gas tank full, there'll be less condensation to cause problems.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: '96 Saturn SC2 fuel pump stuck. [Re: atikovi] #5340804 02/04/20 11:39 AM
Online Content
I have seen aftermarket pumps get gummed up after sitting just a couple months - it depends on how much fuel was in the tank, etc.
Either way - if it wasn't defective before, it is now and it has to be replaced.
Re: '96 Saturn SC2 fuel pump stuck. [Re: atikovi] #5341703 02/05/20 10:26 AM
A
Anduril Offline
A
I let a car sit for 3 years, fuel pump and everything else was fine.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: '96 Saturn SC2 fuel pump stuck. [Re: Anduril] #5341741 02/05/20 11:14 AM
A
atikovi Offline
A
Same here for much longer than that.
