Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
Should i change my oil change routine ?
by M119 - 04/04/20 03:56 AM
5 and 10 30 valvoline conv 1.49 a qt at TS
by Chesterr - 04/04/20 02:34 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
97 registered members (2009Edge, atikovi, Alfred_B, 2015_PSD, AlienBug, alchargo, 6 invisible), 2,970 guests, and 19 spiders.
Topics303,583
Posts5,237,727
Members71,094
Good choice for a cool white bulb to use in DRL #5340331 02/03/20 09:23 PM
R
randytrish Offline OP
R
I've recently purchased a 2011 Toyota Rav4 and want change the DRL bulbs. This Toyota uses the high beams for DRL's. I've changed out the low beams to LED's and want to switch out the highbeams/DRL to a simular light color as the LED's. I really don't want to pay $50 for silverstars. I've purchased two sets of the cool white halogens from ebay that are the same color as regular halogens. Any suggestions? Will HID's work with the reduced voltage when the DRL's are on? Thanks in advance,
Randy
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340341 02/03/20 09:30 PM
9
97prizm Offline
9
Not to rag, but aftermarket LEDs were never engineered for a halogen housing and just cause glare. No HID headlamps will NOT work as the bulb uses an arc and halide salts to run. They are always the full brightness. You can go with hir or halogen infrared bulbs which are the brightest halogen bulbs produced.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340343 02/03/20 09:33 PM
skyactiv Offline
My suggestion is to leave it stock and not waste money and time on such nonsense.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340474 02/04/20 02:34 AM
Dave_Mark Offline
I think having white DRLs and white headlamps is a very important part of owning a car. Nothing screams "I have a new car" like two pairs of white lights.
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340510 02/04/20 05:44 AM
AZjeff Online Content
Online Content
Our 2014 RAV4 uses the high beam bulb for DRL and I had short bulb life. Switched from the 9005s to 9011 HIR2 bulbs and quit using them as DRLs. Big difference in light output with the 9011s but not the cool white look. Wil LEDs run on reduced voltage?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340646 02/04/20 09:56 AM
R
R
I tried LED's and they wouldn't run on the reduced voltage. I want to keep DRL because I beleive they are a great safety feature. I wasn't aware of the HIR style bulbs. I may look into them for the light output and not worry about the cool white look. Thanks for the suggestions.
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340655 02/04/20 10:09 AM
M
mclasser Offline
M
I've seen people run aftermarket LEDs as DRLs and they have a weird flicker/strobe light effect.
As far as 9011s - They'll probably have reduced life being on as DRLs all the time.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340658 02/04/20 10:16 AM
F
frankbee3 Offline
F
If you have the time to read, I have found this website’s tech articles very helpful.
http://www.danielsternlighting.com/products/products.html
I am getting ready to swap bulbs on my Dodge pickup to the higher output normal color bulbs..
1992 Toyota Pickup
2001 Mazda Miata
2003 Dodge Ram 2500 Cummins
2008 Subaru Outback
Miscellaneous Yard tractors and lawn mowers
Re: Good choice for a cool white bulb to use in DRL [Re: randytrish] #5340708 02/04/20 10:59 AM
W
WhyMe Offline
W
can the DRL be turned off via the software? my 02 bmw could do that.
