Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
Horsepower in Various Modes
by Al - 06/01/20 11:39 AM
ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
43 registered members (AndyB, AlaskaMike, Arcoril, Avery4, 7 invisible), 1,608 guests, and 46 spiders.
Topics306,044
Posts5,286,327
Members71,593
94 Cavalier. Problem with brakes. #5340258 02/03/20 08:15 PM
W
wtd Offline OP
W
This morning my fiancée tells me that she can smell something hot and that the left side wheel was getting very hot after driving. This morning I take it for a short drive and it's not hot. I take it for a longer drive and it gets very hot.
I go back home and take the wheel off and the outer brake pad is worn down to the pad depth indicator while the inner one is fine. I just put pads on this car 17,000 miles ago. I try to retract the piston with a large C clamp but no go. With the brake line hooked up, the piston would not go back down.
I end up replacing both calipers since they are very cheap in price, the rotors since the one you could tell got very hot, the brake pads, and the rubber brake hoses. She has had this car for almost 80,000 miles and the calipers and brake lines had never been replaced. The left brake line had a small crack in it so I figured I would just replace them even if it wasn't leaking.
I get everything back together and while it doesn't get screaming hot like it was, it is still getting warm on that side when the passenger side is cool to the touch. After the car sat for a little while, the caliper was pretty hot and so was the rotor so something is still not right.
The car brakes straight. I've been doing brakes for years and while I have experienced a stuck caliper on a previous vehicle, after I replaced the caliper and hose, I didn't have any more problems.
So what else should I be looking at that could be causing this slight pad drag? Thanks for any ideas or suggestions.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: wtd] #5340274 02/03/20 08:36 PM
M
mk378 Offline
M
If the master cylinder piston doesn't come all the way back when no one is pressing the brake pedal, pressure can build up and cause drag. Check if there is pressure build up when the system is warm after a drive by putting the clamp on and try to retract, then crack open the bleeder to see if that relieves it. This could be a simple as adjusting the brake light switch back a little.
One pad wearing more than the other means the slide pins are sticking but since you replaced everything that has probably been resolved.
Re: 94 Cavalier. Problem with brakes. [Re: wtd] #5340282 02/03/20 08:43 PM
E
eyeofthetiger Offline
E
I would start by manually compressing the caliper slightly. Check for any sticking or binding of the caliper on the guide pins. With a brand new caliper and guide pins, it should move easily.
Re: 94 Cavalier. Problem with brakes. [Re: mk378] #5340293 02/03/20 08:51 PM
MrMoody Offline
Good test. 25 year old brake hoses? Make fun of me if you like, but I've had brake hoses swell shut when they got that old, like arteriosclerosis, then the pistons couldn't retract. Same symptoms.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: 94 Cavalier. Problem with brakes. [Re: mk378] #5340304 02/03/20 09:04 PM
E
eljefino Offline
E
I had this problem with my mercedes w123. Notably, the brake pedal had zero play, felt like stepping on a block of wood. Your muscle memory will notice that something's off.
Re: 94 Cavalier. Problem with brakes. [Re: mk378] #5340306 02/03/20 09:06 PM
W
wtd Offline OP
W
If the brake light switch needed adjustment, wouldn't both sides be dragging?
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: eyeofthetiger] #5340314 02/03/20 09:10 PM
W
wtd Offline OP
W
The new guide pins were moving smoothly. After I had gotten everything bolted on except for the wheels, I tried moving the rotors on both sides. The driver's side did drag more than the passenger side. I thought that everything would work itself out after taking it on a test drive.
I will try manually compressing the calipers and see what happens. Probably won't happen tomorrow since it's supposed to snow and be cold.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: MrMoody] #5340316 02/03/20 09:11 PM
W
wtd Offline OP
W
Both front rubber brake hoses were replaced with new ones so I don't think it's that.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: eljefino] #5340318 02/03/20 09:12 PM
W
wtd Offline OP
W
The brake pedal does have play In it so it's not like stepping on a block of wood. It feels normal to me.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: wtd] #5340323 02/03/20 09:20 PM
MrMoody Offline
Ah, should have read more carefully.
Re: 94 Cavalier. Problem with brakes. [Re: wtd] #5340344 02/03/20 09:33 PM
O
OILJUNKIE Offline
O
I think you misunderstood your fiancee she said,"you were hot"
Re: 94 Cavalier. Problem with brakes. [Re: OILJUNKIE] #5340367 02/03/20 09:56 PM
W
wtd Offline OP
W
LOL. That is definitely not what she said. I sprained my ankle after putting tools up in the shed to finish off this day and she barely acknowledged that. Granted she just go off work from working overtime but after working on her car all day, you would think she would be more appreciative.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: wtd] #5345974 02/10/20 10:09 AM
W
wtd Offline OP
W
I finally did try manually pushing the piston back in and it went in fine without having to crack open the bleeder valve. I rechecked and the caliper slides fine.
She drove it into town the other day and while the wheel did not get hot, you could smell the brake material when she got back. At this point all I can figure out is that something could be wrong with the master cylinder that is not allowing the pads to retract all the way.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 94 Cavalier. Problem with brakes. [Re: wtd] #5345999 02/10/20 10:36 AM
Silverado12 Offline
That is possible^^^ and what others said make sure the pedal is coming all the way back when you release the brakes. I had this issue with an old S-10 V-8 swap that someone switched it from power to manual brakes. It drove me nuts trying to figure it out as I have never heard of this before. Lesson for me learned not to work on someone else's cobbled up job.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 94 Cavalier. Problem with brakes. [Re: Silverado12] #5346735 02/10/20 10:59 PM
W
wtd Offline OP
W
The pedal is coming back up because I adjusted the brake switch like it said in the service manual and I pulled the pedal up until the brake switch quit clicking. It wouldn't go up any farther anyway.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
