plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
88 registered members (benjy, b1amgm47, 1978elcamino, aquariuscsm, alex_at, A_User55555, 7 invisible), 2,473 guests, and 18 spiders.
Topics301,907
Posts5,205,185
Members70,798
Pentosin Dot 4LV in a G37x? #5340133 02/03/20 04:40 PM
G
GZRider Online Content OP
OP Online Content
G
The left rear caliper has stuck on a few occasions after bad weather trips and both rears have pretty significant corrosion (base sliding cast iron calipers) so I ordered a pair of Raybestos R-line replacements, new Akebono ASP pads and 2L of the Pentosin Dot4 LV fluid based on the thinking the car might see -20f this winter but now I am a bit concerned I made a mistake going with a LV fluid for this application. Any insights would be appreciated.
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5340136 02/03/20 04:45 PM
N
nthach Online Content
Online Content
N
DOT 4LV will work just fine. I have it in most of the cars I maintain. It's a must on newer cars calling for DOT 4LV, but since it's less viscous than regular DOT 3/4 it can translate to more transparent ABS operation.
I've noticed a change in the brake pedal for the better in one case.
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5340145 02/03/20 05:00 PM
H
hallstevenson Offline
H
Pentosin says it's fully backwards-compatible with regular DOT4 and DOT3 and can even be mixed. I have some myself that I planned to use to exchange the fluid in my wife's Fusion (which specs DOT4 LV) and was going to use it in my G35X as well.
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5340147 02/03/20 05:01 PM
G
OP Online Content
G
Thanks guys! I have a bad habit of overthinking this stuff.
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5340162 02/03/20 05:14 PM
H
H
Just to reassure you (more):
Quote
NOTE: Low viscosity brake fluid can be used in vehicles that do not require a low viscosity fluid; however, standard DOT 3 or 4 brake fluid should not be used for top off in vehicles that require a low viscosity brake fluid. This action will reduce the low temperature properties and decrease the safety performance of the fluid.
http://www.pentosin.net/f_brakefluid.asp
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5340437 02/03/20 11:02 PM
slacktide_bitog Offline
You did not make a mistake using LV smile
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5341854 02/05/20 12:49 PM
G
OP Online Content
G
New parts installed and the LV fluid works great in the G at warm temps, improved pedal modulation and feel over 1 year old Valvoline 3/4. Thanks again to all that replied.
Re: Pentosin Dot 4LV in a G37x? [Re: GZRider] #5342066 02/05/20 05:24 PM
Chuckh Offline
I use that in my Passat. Sure it is expensive but it is the same stuff the VW dealer sells relabeled. I am not sure if I could use non LV fluid but I am happy with my brakes the way they are anyhow and would not switch from using that. Unless you have a strange car that takes some weird special fluid you can use the LV. Some people might say using that is overkill but I have a feeling they are the ones who have a beat up old clunker that barely runs!!
