Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
28 registered members (Bjornviken, Bighorn2500, Best F100, 53' Stude, Amenhotep, Aichiguy, 4 invisible), 1,194 guests, and 18 spiders.
Topics301,934
Posts5,205,764
Members70,801
RA key fob for me? #5340030 02/03/20 01:41 PM
paulri Offline OP
I recently broke the rim of the key fob for my highlander, where it connects to my key chain. It still functions just fine, locking & unlocking the doors.
I found this on Rock Auto: https://www.rockauto.com/en/moreinf...%2BsZZwW9Rf7Lq7jKhEUTR1PruQBjtmyyLF%2BPV
Now all I need to do is get a new case--the battery & the insides are working just fine. So will this do what I want? Or would I still have to take it somewhere to get it programmed for my car?
Please keep in mind I have never transferred the innards of one fob to another; I'm assuming this can be easily done by a newbie. If this isn't the case, let me know.
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: RA key fob for me? [Re: paulri] #5340038 02/03/20 01:48 PM
T
tcp71 Offline
T
Open it like you are changing the battery. The insides just fall out.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: RA key fob for me? [Re: paulri] #5340063 02/03/20 02:38 PM
Donald Offline
However this is a Dorman product so who knows the quality or fit.
But the guts should come out pretty easy.
2015 Ford F-250 w/Powerstroke
Re: RA key fob for me? [Re: paulri] #5340084 02/03/20 03:31 PM
Dave9 Offline
I would look around my office for a very thick paperclip, or a round clasp type paper binder, or roam a hardware store for a metal loop even if it's just a little stainless steel washer. Come to think of it, I probably have some spare lanyards lying around, like those that used to come with USB flash drives, etc, with a little metal loop on the end that would be ideal, or off a mini maglite flashlight or some other keychain widget.
I'd use an abrasion/sanding tool, like sandpaper or a file or a bench grinder, to grind away the keyloop portion still attached to the casing, and then make slots in the keyfob casing in that area to slip in the replacement metal loop. Making sure I didn't cause a fit issue with the circuit board inside, I'd secure the loop in place with epoxy on the inside, after cleaning the case and loop with alcohol.
Re: RA key fob for me? [Re: paulri] #5340093 02/03/20 03:39 PM
drtyler Offline
Those have worked for me as well, to replace the original Toyota cases that broke. Nothing to it.
Those break too, only a little sooner, but they are a lot less $$ than buying from Toyota.
Re: RA key fob for me? [Re: paulri] #5340105 02/03/20 04:01 PM
Z
zzyzzx Offline
Z
You can buy just a case.
Re: RA key fob for me? [Re: Dave9] #5340113 02/03/20 04:13 PM
T
tcp71 Offline
T
To save $5???!! Or as a project?
Re: RA key fob for me? [Re: paulri] #5340124 02/03/20 04:21 PM
A
atikovi Offline
A
Re: RA key fob for me? [Re: paulri] #5340163 02/03/20 05:17 PM
paulri Offline OP
Thanks, I just ordered it. Under $10 including shipping.
Re: RA key fob for me? [Re: Dave9] #5340329 02/03/20 08:22 PM
M
maxdustington Offline
M
Bench grinder lol. Alcohol prep thumbsup
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: RA key fob for me? [Re: paulri] #5342990 02/06/20 06:47 PM
paulri Offline OP
Just arrived today and old innards are currently inside new RA key fob with new lithium battery. Working fine. Thanks for the replies.
Just to see how much I could save, I called the local Toyota dealer and I was quoted over $100 for a new key fob, plus whatever the service dept would charge to program it. But to his credit, the guy on the phone advised me to just get an aftermarket unit like I did.
