Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
45 registered members (Amkeer, bbhero, BlakeB, ArgleBargle, AZjeff, Bjornviken, 5 invisible), 1,131 guests, and 25 spiders.
Topics301,934
Posts5,205,768
Members70,801
Should I replace the timing chain? #5340004 02/03/20 12:52 PM
R
Redright9 Offline OP
R
After a lot of help and advice from members here (thank you everyone), I am going to do some to me major repair work on my '06 Chrysler 300C with the 5.7L. It has a small coolant seepage from the timing cover and the radiator cracked. So I am going to replace the radiator and reseal the timing cover. Since I am removing the water pump, replace that too. My next question is since I will be staring right at the timing chain and my car has 170k miles on it, should I replace the chain too? The only issue is the oil pump is in the way and I think i need to fully remove the oil pan to do this.. Anyone replace the timing set on a HEMI without dropping the pan? Or since it is not causing any problems, just reseal the cover and forget about it?
Thanks.
Re: Should I replace the timing chain? [Re: Redright9] #5340008 02/03/20 12:57 PM
J
Jimzz Offline
J
170k I would replace the full timing system.
And from looking at this video I don't think you need to remove the oil pan.
https://www.youtube.com/watch?v=8iiry9jMG0s
yup
Re: Should I replace the timing chain? [Re: Redright9] #5340014 02/03/20 01:02 PM
A
Al Offline
A
You also need to replace sprockets.
Re: Should I replace the timing chain? [Re: Redright9] #5340020 02/03/20 01:11 PM
R
R
I've seen this video, that is part what is giving me some of the confidence to do the job. The only problem, he doesnt show how he got the pump off. He took the bolts out, then next frame, its just removed. I read through the comments some and someone asked him if he was able to remove the pump without pulling the pan. He said he wasnt that lucky... So I still think I need to..
Re: Should I replace the timing chain? [Re: Redright9] #5340057 02/03/20 02:30 PM
M
madRiver Offline
M
If it were an actual maintenance item (like timing belt) then yes. However its a "lifetime" part and its functioning nope.
Re: Should I replace the timing chain? [Re: Redright9] #5340058 02/03/20 02:30 PM
supton Offline
Seems kinda early in life to change?
Can you check the tensioner and see if it is somehow indicating that the chain is worn?
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Should I replace the timing chain? [Re: Redright9] #5340060 02/03/20 02:34 PM
Cujet Offline
If you've maintained the vehicle well with frequent oil changes and quality oil, it's quite likely the chain is fine. Chains prefer about a 30 viscosity oil, so keep that in mind if you've been using 0W-20 oil.
The 5.7 is a very long life engine and there are many who get 400K+ out of them without ever changing the chain. Can you take it apart and assess the situation? Then purchase parts if necessary.
Re: Should I replace the timing chain? [Re: Jimzz] #5340064 02/03/20 02:43 PM
H
hatt Offline
H
Looks pretty simple and shouldn't be expensive to do. I'd change it since you're already going to be into the engine.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Should I replace the timing chain? [Re: Redright9] #5340067 02/03/20 02:54 PM
R
R
I feel the vehicle has been properly maintained since new. It was my fathers before I acquired it. According to the last oil analysis they say the same. I posted it here, and it said the engine is wearing remarkably well. I am not experiencing any issues with the car other than slight coolant seepage and the crack in the radiator. It was a simple since I'm there should I.. Or should I stop the bleeding since I am already throwing a lot of since I'm there parts in....
Re: Should I replace the timing chain? [Re: Redright9] #5340076 02/03/20 03:10 PM
A
Audios Offline
A
I normally wouldnt get involved but book time is only showing an additional 1.5 hours between timing cover and chains, so it doesnt seem like its a big job. They do say remove oil pan to take the pump off, which adds either 3.5 or 6 hours depending on AWD. If you can sneak it, and especially if theres wear, Id swap it out. However the pan job would definitely make me think. prokets are recommended in the book also, not sure if its a necessity or not. Looks like chain and sprockets come out together.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Should I replace the timing chain? [Re: Redright9] #5340109 02/03/20 04:07 PM
N
nthach Offline
N
A timing chain on a pushrod engine lives an easier life than a OHC one - shorter and much more simple drive. The tensioner and guide rails are more of a concern than the chain itself. On some cars - more so German ones, timing chain, tensioner and rail replacement is a fact of life.
I'd take a look-see, see if there's irregular wear or cracks/chips on the guide rails, the tensioner appears to be in good shape with no oil leaks or hyperextension of the plunger or pushrod. If it makes you feel better, replace everything as a set.
Re: Should I replace the timing chain? [Re: Redright9] #5340291 02/03/20 07:50 PM
Dinoburner Offline
If both sprockets are metal and the chain tension/play is in tolerance lt should be OK. Myself, I would change them.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Should I replace the timing chain? [Re: Redright9] #5340384 02/03/20 09:28 PM
clinebarger Offline
The pan has to be lowered to remove the pick-up tube bolt. The Tensioners do break on these.....The plastic shoe anyway.
2001 Chevy Camaro L92/4L80E
Re: Should I replace the timing chain? [Re: Redright9] #5340590 02/04/20 07:45 AM
Hootbro Offline
If you are more than half way into what would be a timing job replacement, do it especially if you plan to keep it long term.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: Should I replace the timing chain? [Re: madRiver] #5340731 02/04/20 10:25 AM
A
Anduril Offline
A
I used to follow that logic and I didn't replace the primary chain and tensioner when I did the secondaries on my XTerra at approximately the same mileage as OP. A year later the primary tensioner failed and I had to open everything back up.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
