1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
26 registered members (Best F100, 53' Stude, Amenhotep, Aichiguy, Bjornviken, 5 invisible), 1,225 guests, and 18 spiders.
Topics301,933
Posts5,205,762
Members70,801
heavy guage wire strippers? #5339594 02/02/20 10:09 PM
M
motor_oil_madman Offline OP
M
So do they have wire strippers that will strip the jacket off of a cable? Say like 16 gauge all the way to 8 gauge? SO and SJT rated cable? I know a lot of people take a razor blade and cut around it carefully, but I find it hard to believe an electrician would do this.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339595 02/02/20 10:10 PM
M
M
Then once you get the jacket off just use regular wire strippers to strip the smaller wires.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339602 02/02/20 10:20 PM
T
tcp71 Offline
T
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339607 02/02/20 10:30 PM
U
user52165 Offline
U
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy. It's inherent virtue is the equal sharing of misery.
Winston Churchill.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339617 02/02/20 10:43 PM
Saleen0679 Offline
Search for cable sheath stripper/cutter. The tool scores the outside jacket so it can be pulled off.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339619 02/02/20 10:48 PM
M
mk378 Offline
M
On large cable it's very common to cut carefully with scissors or a knife-- this is why experts are paid big bucks.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339624 02/02/20 10:54 PM
M
maxdustington Offline
M
I've seen more than one electrician strip wires with an Olfa but the appropriate tool is a cable knife.
Klein yellow strippers can strip pretty thick stuff, no? If not, you can always just strip them with a smaller gauge stripper if you are careful.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339631 02/02/20 11:16 PM
Dave9 Offline
Even with a stripper, it is not so straightforward to get the outer sheath off if it has multiple conductors because the # of them and type of insulation used, determines the total outer diameter. A stripper is just intended for a single conductor of gauge X.
You can still get a user-adjustable cable stripper tool, but then have to pay attention to how you adjust it for each particular task, and in the gauges you're talking about, will usually still need a more traditional stripper tool to do the individual conductors. Here's a video showing the basic principle:
https://www.youtube.com/watch?v=AWgl_pUSVes
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339636 02/02/20 11:25 PM
M
M
Might as well just use a pipe cutter. lol I was doing it with a razor blade cutting half of it then bending it to rip it open some then cutting the other half from the inside out (so I don't cut the conductors) to cut the rest of it off.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339761 02/03/20 07:05 AM
T
Trav Offline
T
I use one of these..
https://www.amazon.com/Greenlee-182...5&qid=1580735232&s=hi&sr=1-1
Edit: Posted a less expensive version of the one I bought. This is the one.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339762 02/03/20 07:05 AM
J
JLawrence08648 Offline
J
Many use Lineman's pliers.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339834 02/03/20 08:46 AM
E
eyeofthetiger Offline
E
As you said, a razor blade. More specifically, a utility knife with a fresh razor blade. Under 14 AWG, I use these:
[Linked Image from images-na.ssl-images-amazon.com]
And I often use the next larger stop in order to prevent cutting any wire. I have strippers of every other style, and this cheap little thing is my favourite.
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339836 02/03/20 08:49 AM
M
M
That doesn't look like that will remove the jacket
Re: heavy guage wire strippers? [Re: eyeofthetiger] #5339935 02/03/20 11:04 AM
F
FT92 Offline
F
yep I have one of those myself, my go to almost always
Re: heavy guage wire strippers? [Re: motor_oil_madman] #5339981 02/03/20 12:13 PM
Dan55 Offline
If you want to strip SO or SJO, use a sharp razor knife and lightly score the outside rubber jacket and bend it till it cracks. If the first cut is not deep enough, do it again lightly until it detaches, then remove the outside jacket. Then use a pair of wire strippers to trim the stranded conductors, they usually go up to #10 AWG. These go down to #8 AWG https://www.amazon.com/dp/B0002RI4U4/ref=twister_B06WGR5WDC?_encoding=UTF8&psc=1
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
