Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
46 registered members (4WD, Bailes1992, antone, 2002 Maxima SE, bbhero, Amkeer, 5 invisible), 1,362 guests, and 15 spiders.
Topics301,732
Posts5,201,612
Members70,763
Quick chirp on startup and between gears #5339528 02/02/20 08:26 PM
J
jayjr1105 Offline OP
J
6 speed Manual, the Mazda from my sig makes a quick chirp during startup. It's a 2 month old serpentine belt. I can reproduce the issue when dropping the clutch more abruptly than usual. Suspension? Belt? Tensioner?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Quick chirp on startup and between gears [Re: jayjr1105] #5339534 02/02/20 08:33 PM
G
GSCJR Offline
G
Check the tension.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 156KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 176KM
Re: Quick chirp on startup and between gears [Re: jayjr1105] #5339541 02/02/20 08:41 PM
danez_yoda Offline
which belt brand?
Re: Quick chirp on startup and between gears [Re: jayjr1105] #5339542 02/02/20 08:42 PM
J
J
Dayco W gold
Re: Quick chirp on startup and between gears [Re: jayjr1105] #5339592 02/02/20 10:07 PM
G
GMBoy Offline
G
Check the tensioner
Re: Quick chirp on startup and between gears [Re: jayjr1105] #5339821 02/03/20 08:28 AM
DrDanger Offline
I had a squeak with a new serpentine belt. TBH it was when on full steering lock and/or starting from a stop. Tensioner was ok and belt was running straight.
No wobbles. I sprayed a bit of silicone on the belt with the car running. A few weeks later I forgot all about it.
Re: Quick chirp on startup and between gears [Re: jayjr1105] #5339995 02/03/20 12:32 PM
F
FT92 Offline
F
had that happen to my honda accord...just put new napa belts on and 3 months later ,chirping on start up...everything was good, took the belts of just to see and no chirping on start up ...went to oreilys auto and replaced belts all is good ...still don't know why they started to act up...maybe a bad new belt ? I don't know
Re: Quick chirp on startup and between gears [Re: FT92] #5340026 02/03/20 01:19 PM
J
J
Thanks, I didn't think to remove it and see if it goes away. I can make it happen 10 times out of 10 in reverse if I drop the clutch a bit fast.
