PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
112 registered members (4WD, AdditiveOCD, ArrestMeRedZ, Al, 762fermeandyou, 9 invisible), 1,921 guests, and 20 spiders.
Topics302,057
Posts5,208,266
Members70,826
Anxiously awaiting analysis report #5339450 02/02/20 07:15 PM
Cmobile Offline OP
Recently found I was about 10-12oz or so low on coolant. Searched all over but could not find a leak. I began to think my 03 suburban was plagued by the dreaded cracked head which apparently leaks into an oil passage.?.
So I ordered a Blackstone kit with TBN confident they can let me know if I have glycol contamination in my oil.
The suspense was/is killin me, (currently waiting for the postman to deliver my sample to Blackstone) so I rented a coolant pressure tester. Took a while at 16lbs, but a small leak finally revealed itself on the DS radiator tank, drip,,,,,drip,,,,drip. Wohoo, I thought.
Then, OCD grabbed my mind and took me right down a rabbit hole, what if the radiator tank trans cooler was leaking too!?! So I ordered the Acustrip ATF Glycol test strips. (Coolest thing really) trans fluid does not appear to have glycol contamination according to the test strip reading. Wohoo,,, again.
So now, I'm awaiting the Blackstone results. Really hoping no contamination of oil.
Just had to share this with somebody who appreciates this sorta stuff.
Friends give me the deer in the headlight look crzy
1996 GMC K2500 290k miles
2005 Hyundai Santa Fe
2001 Grand Cherokee
2003 Chevy Suburban
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339465 02/02/20 07:33 PM
Donald Offline
Use NAPA next time for a UOA. $16.
2015 Ford F-250 w/Powerstroke
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339489 02/02/20 07:55 PM
discountdon Offline
consider using WIX Oil Analysis kit for $12.47 - both NAPA & WIX use ALS Labs
amazon link here
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339621 02/02/20 10:48 PM
Cmobile Offline OP
I'll keep that in mind. Great price!
I sent the Blackstone sample in their bottle. USPS said no problems when I dropped it off last Tuesday. However, it missed it's expected delivey of Friday. Tracking said it was on time, however, Saturday, USPS site still said on time Friday before 8PM delivery.
Now tracking just says DELAYED.
Maybe I should have put in a small box and paid for shipping myself.
2001 Grand Cherokee
2003 Chevy Suburban
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339629 02/02/20 11:03 PM
clinebarger Offline
Only a small percentage of 706 Castech casting heads were affected, I haven't seen a cracked one in a LONG time.
Your oil will have a brown tint to it if the castings were leaking!
2001 Chevy Camaro L92/4L80E
Re: Anxiously awaiting analysis report [Re: discountdon] #5339701 02/03/20 04:49 AM
T
Triple_Se7en Offline
T
amazon link here
Lots of bad reviews on never receiving results with the mailed Wix Kits .
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
04' Chevy Colorado Castrol 0W40 & Wix
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339718 02/03/20 05:42 AM
Donald Offline
I have found that mailing a sample to any company that handles UOA in the round container they provide delays it several weeks if not a month. It must sit on the postmasters desk while he thinks about how to cancel the postage stamps with a flat cancel rubber stamp. Even the tracking was never accurate.
I still do it if the UOA is for oil that has been changed and the UOA is for verification. But if I am waiting on UOA results for some reason then always put their container in a box or envelope.
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339804 02/03/20 08:00 AM
Cmobile Offline OP
Thanks Donald
2001 Grand Cherokee
2003 Chevy Suburban
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339837 02/03/20 08:51 AM
Chris142 Online Content
Online Content
I bet it's your water pump to block gaskets.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Anxiously awaiting analysis report [Re: Cmobile] #5339903 02/03/20 10:26 AM
Cmobile Offline OP
Previous owner had water pump/T stat replaced, flush, head gasket, throttle body, intake gaskets, MAF, and a bunch of other things to the tune of $4k. I"m blessed to have the reciepts.
That was done Demenber of 2017.
The mileage was148k. Now at 163k. I bought it at 154k.
I didnt see any leaks at or near the water pump.
I hope the radiator leak I found was the only leak.
2001 Grand Cherokee
2003 Chevy Suburban
Re: Anxiously awaiting analysis report [Re: Cmobile] #5347649 02/11/20 08:58 PM
Cmobile Offline OP
Update:
Got the radiator changed, replaced all hoses and plastic GM heater core fittings, coolant temp sensor and bled system. All seems good so far.
The glycol test strips indicating no coolant in the transmission, AND the Blackstone oil analasys I got back today stating no coolant in the engine oil is a huge relief.
I'm a self proclaimed member of the Junky Car Club of America (Google it), so I'm glad to not have to put a lot of money into this vehicle or purchase a newer one. (No pmts for me, thanks)
Here are the UOA
Attached PDF document
2001 Grand Cherokee
2003 Chevy Suburban
