Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
117 registered members (007, 4WD, 2K2AcuraTL, 762fermeandyou, 53' Stude, 92saturnsl2, 12 invisible), 1,686 guests, and 16 spiders.
Topics303,305
Posts5,233,623
Members71,038
2017 Toyota Tacoma maintenance issues #5339268 02/02/20 05:24 PM
007 Online Content OP
OP Online Content
My daughters boyfriend has a 2017 Toyota Tacoma with 60 K. He went to get the vehicle checked at the local Toyota dealer and they recommended the following as the vehicle was running a bit rough.
1. Cabin air filter ($56)
2. Air filter ($28)
3. AC refresher ($80) - have no idea what this is.
4. Induction system cleaning ($140) - have no idea what this is.
5. Fuel injection cleaning ($100)
Seems rather expensive as most can be done in my driveway including using some good fuel system cleaner.
Ideas,comments?
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339280 02/02/20 05:36 PM
T
TTK Offline
T
Then do it in your driveway.Since you said most, what would be left?
2010 Volvo V70-3.2
Current Fill:Mobil 1 AP 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339303 02/02/20 05:56 PM
02SE Offline
Just a money grab.
Check the engine air filter and cabin air filter, and buy new ones from walmart or wherever if dirty. The AC doesn't need anything unless it's not working right, in which case it should still be under warranty.
Induction cleaning and fuel system cleaning should really just be called wallet siphoning. Buy top tier gas and the D4S system will keep things clean.
IIRC the 2GR FKS calls for a 60k replacement interval on the spark plugs. Something they apparently didn't mention.
Tell him to find another Toyota dealer.
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339312 02/02/20 06:08 PM
J
John_K Online Content
Online Content
J
Googled AC refresher, it's stuff to clean evaporator and vents. Kit 00289ACRKT is about 35 bucks. Some dealers had it for quite a bit less.
2009 Mercury Grand Marquis, 8 cyl auto, 96xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 100xxx miles, Maxlife/OEM Filter
Current oil stash: 447 qts.
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339321 02/02/20 06:12 PM
M
MParr Offline
M
Money grab.
Air filters need changing every 30,000 miles. Take a look. It’s at 60,000 miles so, it probably needs an air filter.
Cabin air filters need changing every 20,000 miles. This won’t affect the engine’s performance.
At 60,000 miles, it probably needs a set of spark plugs.
If the A/C is functioning properly, it doesn’t need any refrigerant.
Pour a bottle of Chevron Techron in the fuel tank and fill with 93 octane and run it. Do that after changing the plugs.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
2014 F-150 4x4 Now: Pro DS 5W20 & Motorcraft FL-500s
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339326 02/02/20 06:18 PM
dblshock Offline
I buy the air filters from Aisin on ebay bout 1/3 less than the low Toyota price, same filters.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339345 02/02/20 06:40 PM
dawgn86 Offline
Clean the TB and mass air flow sensor
2019 Acura MDX
2019 Ford F150
2007 Acura MDX
2016 Volvo XC90
2013 Toyota Tacoma PreRunner
Re: 2017 Toyota Tacoma maintenance issues [Re: dblshock] #5339384 02/02/20 07:11 PM
P
painfx Offline
P
Aisin air filters?? Can you provide a link?
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339401 02/02/20 07:25 PM
dblshock Offline
My bad they're Denso
Denso filters
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339408 02/02/20 07:32 PM
dblshock Offline
Denso cabin filters
cabin filter
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339522 02/02/20 09:23 PM
M
madeej11 Offline
M
Probably about $120 job if you can DIY vs close to $400 at the dealer. Driveway is a good option in Florida.
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339665 02/03/20 01:53 AM
J
JLTD Offline
J
1, 2, and 3 won't cause rough running. Agree with finding another dealer.
Lates.
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339753 02/03/20 07:56 AM
supton Offline
That stuff can be done in the driveway; I wonder if the throttle body needs a cleaning and/or new plugs. "Running rough"? Like poor idle, poor mpg or poor power?
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339809 02/03/20 09:12 AM
G
Gebo Offline
G
Wow! Are there any other Toyota dealers near by? You are correct in you being able to do this in your driveway.
If the plugs are supposed to be replaced at 60K per owner's manual, I would do that.
I would also clean the throttle body and the mass air flow sensor. Make sure you use the appropriate cleaner as the MAF requires a special cleaner just for MAF's. YouTube it.
Start using a "top tier" gasoline and a few tanks of that will clean up the fuel system. If anxious, you could use a bottle of Techron or something similar. I would use the cleaner
before I changed the plugs. That's just me.
I only use Toyota OEM filters and plugs from a dealer. There are too many fakes. If I were to go online for purchase, I'd make sure they were coming from a Toyota/Lexus dealer.
Like on eBay, there is a Toyota dealer in Winston Salem NC, Modern Toyota and I know they are legit.
You can cause yourself problems if you get a cabin air filter that is more restrictive than the OEM. It "could" inhibit air flow circulation.
Is the Taco showing any codes?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2017 Toyota Tacoma maintenance issues [Re: 007] #5339957 02/03/20 12:28 PM
OP Online Content
Part numbers?
