Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
34 registered members (bbhero, 3311, blufeb95, ArrestMeRedZ, carlprop, 4 invisible), 999 guests, and 22 spiders.
Topics301,684
Posts5,200,462
Members70,756
Drivetrain vibration in 1966 Corvair #5339239 02/02/20 03:57 PM
007 Offline OP
My good buddy has a 1966 Corvair and has some over 55 mph vibration issues. He has 14" OLD style Crager wheels with 205/70 14 BFG TA Radials. This is the second set of new tires he has purchased in less than a month hoping to alleviate his issue with no luck. Tire installer sold him on the second set of more expensive tires thinking that was the problem but it was not. Any ideas??
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339243 02/02/20 04:03 PM
R
Rand Offline
R
Road force balancing should be able to confirm or rule out tires/wheels.
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339251 02/02/20 04:07 PM
SubieRubyRoo Offline
Have the shop take the tires off and spin the rims first and check for bent ones, and also how far out of balance the rim itself is. Does it feel like it's in the front, rear, or both? If only one end, swap both tires front to back and see if the vibration follows the swap, or if it stays. That will tell you if its wheel/tire related or some other drivetrain/bearing issue.
De omnibus dubitandum.
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339260 02/02/20 04:20 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Get a vibration analysis app for your smart phone - I use a free one called VibrationAnalysis. Take a reading at actual 60MPH and another at a recorded actual speed where the vibration is worst.
Verify your tire size’s true rpm/mile rating. From there all it takes is math to determine what in the drivetrain is causing the worst vibration.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4891490/1
Knowing what frequency you’re truly feeling will be helpful.
You’ll get something like this if it’s legit wheel and tire:
[Linked Image from i.imgur.com]
And this when fixed:
Note the y axis.
When you know the number of tire RPMs/mile, and are at 60MPH, so its one mile per minute, the math starts to get easy.
Since the diff ratio is known, if its that, it will be mathematically the harmonic that is the ratio multiplier of the tire RPM, or more specifically Hz (oscillations/sec).
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339270 02/02/20 04:28 PM
007 Offline OP
Thanks for the feedback guys. My buddy is very frustrated and does not want to throw good money after bad.
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339307 02/02/20 05:01 PM
Passport1 Offline
I had a '65 Corvair Corsa 180 turbo, 4 speed with a factory limited slip transaxle. Loved that car. Ran it in many gymkhanas until the engine surrendered. It was shod with 14" Michelin X tires.
The only vibration I remember it generated was from my overheated girlfriend in the passenger seat.
1992 940 Volvo turbo 320K
2006 Saab 9-3 86k
2007 Suzuki Burgman
2012 Suzuki Kizashi
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339332 02/02/20 05:25 PM
N
Neely97 Offline
N
In high school ( in the late 60s )my friend had a Corvair.
He found that added weight really helped it’s handling.
He had a hundred lbs of barbell weights in the trunk, I remember because he borrowed them from me and never returned them .
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339338 02/02/20 05:30 PM
T
Trav Offline
T
Check the U joints and anything else connected to the drive axles, these types of components are a common cause of vibration.
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339370 02/02/20 06:00 PM
I
Imp4 Offline
I
With a vehicle of that age, it could be nearly any part of the drive train or suspension.
Unless your buddy has replaced the rubber bits within the past 5 years you've got to assume they're worn or dry rotted or both.
There's likely a lot of work to do here.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Drivetrain vibration in 1966 Corvair [Re: Trav] #5339404 02/02/20 06:28 PM
G
GSCJR Offline
G
+1
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 156KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 176KM
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339420 02/02/20 06:45 PM
DuckRyder Offline
Do the only Cragers have those slotted holes and oblong washers?
Got any stock wheels?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Drivetrain vibration in 1966 Corvair [Re: DuckRyder] #5339460 02/02/20 07:28 PM
E
eljefino Offline
E
This is what I was thinking.
Re: Drivetrain vibration in 1966 Corvair [Re: 007] #5339509 02/02/20 08:07 PM
P
Papa Bear Offline
P
widman would know ....
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: Drivetrain vibration in 1966 Corvair [Re: DuckRyder] #5339648 02/02/20 11:49 PM
clinebarger Offline
Those "Uni-Lug" wheels were junk when new, Aftermarket Duplex-washered lug nuts were also trash without Uni-lug wheels thrown in the mix.
If one dismounted the tires & put a dial indicator too these Cragers on the car...I guarantee excessive runout would be found!
2001 Chevy Camaro L92/4L80E
Re: Drivetrain vibration in 1966 Corvair [Re: GSCJR] #5339672 02/03/20 01:20 AM
Cdn17Sport6MT Online Content
Online Content
+1
If memory serves, the rear half-shafts do not telescope... on the '65 and later (specifically). Meaning that they act as the upper wishbone... or link... and they run in compression. Like how the first few Corvette Stingrays were.... I guess, all the way up to the early 90's ??? The U Joints have to be in good nick. Same as the Jaguar IRS.
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
