VW Budack Cycle 2.0T - hugely unimpressed.
by pezzy669 - 02/16/20 01:13 PM
Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
102 registered members (928, 5AcresAndAFool, 10WSmuckers, 4WD, 762fermeandyou, 15 invisible), 2,553 guests, and 35 spiders.
Topics301,520
Posts5,197,199
Members70,712
Heating oil gelling. No addys work. #5338738 02/02/20 06:41 AM
N
Nayov Offline OP
N
I have tried both Howes and Lucas  anti-gel additives for my outdoor 275 heating oil tank (#2). They are designed for Diesel fuel , yes, but #2 and Diesel are kissing cousins, unless there  is an important difference I'm not aware  (actually Howes says OK for heating oil). They are both 100 per cent ineffective, even after following the directions exactly. The fuel still gels at about a bit below 20 F.
So I've given up, and had them deliver K1 (kerosine) but they could only squeeze in 64 gallons (supposed to be 50/50 to make it a winter blend).
For those of you with outdoor tanks, what do you do?
Surely something must work, or theses are simply snake oils.
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338741 02/02/20 06:46 AM
sloinker Online Shocked
Online Shocked
I think project farm did some testing and the Hot Shot Diesel secret worked best. I might be a little afraid of using it because of the unknown effects of the chemicals on the heater and breathing environment.
https://www.youtube.com/watch?v=n8gDN_6esfs
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338766 02/02/20 07:21 AM
A
Audios Offline
A
I bought an el cheapo magnetic block heater for my outdoor tank, hooked it up to a timer so it ran for about 3 hours and shut off for 1-2. Worked for a year til the heater rusted away. You can try double dosing, have you tried the 8 in 1 additive? Ive been using Wurth Anti-gel, my supplier had them for a steal by the case so Ive been adding one with each fill. Any anti gel will work as long as theres enough in the bottle to cover the fuel, most say 250-300 gallons per quart. Redline also makes a potent Anti Gel.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338768 02/02/20 07:26 AM
B
BigD1 Offline
B
Sounds like your tank has a lot of water. Howe's directions say to double dose it for the first three tanks.
When I drove long haul, Howe's never did let me down while other trucks were shutting down.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338780 02/02/20 07:38 AM
Driz Offline
Dump some kerosene in there. They used to sell and surely still do sell 50/50 mix for outside tanks. Thinning it with kerosene will take care of your furnace issues . Also check your filter. Those are also far better located inside. An old installer once told me that going from a 3/8 to half inch line helped as well.
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338788 02/02/20 07:43 AM
E
eljefino Offline
E
Gelling at 20 is unsat, you have some sort of contamination that's catalyzing this reaction. Water? Try switching oil dealers, maybe to some of that famous CN Brown "Red Shield".
Of course you have to thaw out this tank to burn through it. frown
How'd you get through previous winters? This one is comparatively mild.
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338815 02/02/20 08:16 AM
N
Nayov Offline OP
N
I got through by thawing out the line and the filter housing with hot water.The tank never gells up.For water, I tested it by using a water detecting paste and dipped it. But like I said, I've given up and had them deliver K1. It's just that's it's a bitter pill to swallow going to K1 because it is substantially more expensive and has a lower BTU output and was hoping one of these potions would work.
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338825 02/02/20 08:26 AM
AZjeff Offline
Originally Posted by Nayov
I got through by thawing out the line and the filter housing with hot water. The tank never gells up
Wouldn't heat tape and insulation work for this? Could you move the filter inside?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338854 02/02/20 08:52 AM
J
JohnG Offline
J
What Driz said. But you already knew that.
What you are most likely dealing with is Biodiesel. This is mostly destined for use in vehicles, so I have no idea how it got into your heating oil tank. Maybe some left in tanker from previous delivery. Make sure your dye concentration is correct, that actually helps a little to keep the fuel from gelling.
Truck stops may sell a different additive that you could try, but we've always relied on Kero as the most effective.
And heat tapes of course.
Diesel trucks have fuel heaters these days, so it's a known issue.
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338867 02/02/20 09:05 AM
SrDriver Offline
Add some #1 diesel (Kerosene) to your #2 diesel. You can find out the percentage from your fuel supplier - internet, etc.
At one time before moving south lived several years in Wisconsin and my grandmother had an outside fuel tank. This solved her problems and as I remember, the fuel company may have actually added #1 to their fuel upon delivery?
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338882 02/02/20 09:21 AM
Snagglefoot Offline
From Amazon: Easy Heat AHB 112 or equivalent. Place the thermostat against the filter and wrap the line with aluminized insulation. Any excess line tape against the front of the tank and cover with insulation. Snug as a bug in a rug. smile
If you want the job done right......do it yourself.
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338900 02/02/20 09:42 AM
I
incognito_2u Offline
I
Is your Fuel Oil company delivering “Bio” Fuel..........if they are, the gelling point for bio fuel is a lot higher than standard home heating oil ( don’t quote me but I think bio gels at 30 degrees as opposed to 15 degrees for regular oil.). You can still continue to use HOWES and LUCAS anti gel, but you have to double the dosage. So two bottles per every 320 gallons of fuel.
2006 Jeep Commander 3.7 V6 -115k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -87k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -89k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (QSUD5W30/XG3600)
Re: Heating oil gelling. No addys work. [Re: incognito_2u] #5338936 02/02/20 10:24 AM
Chris142 Offline
X2. That was my first thought.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Heating oil gelling. No addys work. [Re: Nayov] #5338997 02/02/20 11:23 AM
L
Linctex Offline
L
So I've given up, and had them deliver K1 (kerosene) but they could only squeeze in 64 gallons (supposed to be 50/50 to make it a winter blend).
64 gallons should be enough. Maybe adding Power Service additive will help?
Also - make SURE the fuel filter is inside the house. Filter outside is always a disaster.
A bigger filter (or 2-3 filters in parallel) will give you more surface area
Re: Heating oil gelling. No addys work. [Re: Nayov] #5339065 02/02/20 12:49 PM
CDX825 Offline
Double dose the Howes for the lowest temperature recommendation. Insulate the lines coming off the tank and if your filter is outside by the tank move it inside.
That's pretty warm for regular fuel to gel up at. Water will cause the same problem and it doesn't take much to make enough ice to stop the line up.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
