Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
113 registered members (53' Stude, 2003f7, 2015_PSD, 2004tdigls, 4WD, 750IX, 7 invisible), 2,065 guests, and 18 spiders.
Topics301,900
Posts5,204,981
Members70,798
Start up noise #5338589 02/01/20 10:21 PM
G
gj Offline OP
G
Start up noise that quickly goes away due to the oil filter? .
2019 Mitsubishi Mirage . Currently 9500 miles . Dealer used Pennzoil synthetic and it's hard to see but it looks like a Pennzoil filter . Not sure if it was The platinum or ultra platinum . 0w20 .
Didn't notice it in warmer weather .
Going to start doing my own oil changes . Considering Wix XP , Purolator Boss , Motorcraft oil filters . 0W20
Oils I'm considering is Quaker State Ultimate , Pennzoil Ultra Platinum , Havoline DS .
Thanks
Re: Start up noise [Re: gj] #5338595 02/01/20 10:33 PM
R
Rygrego Offline
R
If the noise is approximately 2 seconds and happens primarily at cold start I would suspect a variable valve timing actuator. If it continues get it fixed while under warranty. It can stretch a timing chain over time. This problem is very common with quite a few manufacturers, most of which are Japanese companies.
Re: Start up noise [Re: gj] #5338596 02/01/20 10:36 PM
M
mpgo4th Online Content
Online Content
M
The 4 cylinder Mitsubishi's I've worked on had vertically mounted filters. That shouldn't have anything to do with startup noise.
Re: Start up noise [Re: gj] #5338601 02/01/20 10:45 PM
chainblu Offline
The Mirage is a 3 banger and the filter is horizontal. A silicone ADBV is essential. I've had good luck with just an orange Fram, but any of the 3 you listed should be fine.
Re: Start up noise [Re: gj] #5338620 02/01/20 11:00 PM
CR94 Offline
Is the oil pressure OK?
2011 Toyota Prius now at 109K
Re: Start up noise [Re: CR94] #5338643 02/01/20 11:34 PM
G
gj Offline OP
G
No way to know , no gauge . thinking about getting the autool readout thing. Bought new.
Thanks
Re: Start up noise [Re: gj] #5338684 02/02/20 01:50 AM
T
Triple_Se7en Offline
T
gj
I've never seen a stand-alone Mitsubishi Dealership. What other vehicle brands are part of this dealership?
I've also never met a Pennzoil oil filter that wore a silicone ADBV. Do your own oil changes and make sure the oil filter wears a red silicone ADBV.
Curious! What did the dealer charge you for the Pennzoil Synthetic Oil Change?
Trolled Here? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
Re: Start up noise [Re: gj] #5338798 02/02/20 08:03 AM
A
ARCOgraphite Online Content
Online Content
A
2 -3 seconds racket = normal and fine.
This is the time it takes for oil pressure to build.
ADBV do not maintain oil pressure!
My wifes crostrek sounds like the TC is sawing through the front cover for a minute - at least.
You want a smoother runnning engine with less racket? Drain out 1/2 qt and replace with GTX Magnetec 5W30.
Works wonders - like a magic elixir - even on super premium european real synthetic oils
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Start up noise [Re: gj] #5338817 02/02/20 08:17 AM
L
littleant Offline
L
Was it making noise before the oil and filter change
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Start up noise [Re: ARCOgraphite] #5338819 02/02/20 08:21 AM
T
T
Drain out 1/2 qt and replace with GTX Magnetec 5W30. Works wonders - like a magic elixir - even on super premium european real synthetic oils
We agree to disagree.
3 seconds racket not normal
ADBV choices do racket-matter
Re: Start up noise [Re: chainblu] #5338827 02/02/20 08:27 AM
M
Online Content
M
Thanks for the info, sincerely. My Mitsubishi knowledge is limited.
Re: Start up noise [Re: Triple_Se7en] #5338839 02/02/20 08:37 AM
A
Online Content
A
So ever single one of my chain cars over the past 15 years was defective?
Not Buying it. A Lifetime of experience says otherwise
But Filter choice and Oil choice can make a big difference in engine startup and operation - I DO agree
Re: Start up noise [Re: mpgo4th] #5338869 02/02/20 09:06 AM
MrMoody Offline
This is a myth. The engine galleries & hydraulic systems can drain back through the filter no matter which way it's facing. The only difference is whether the filter itself also drains.
My GTO has a vertical filter mounted on the bottom alongside the oil pan. It will clatter if the ADBV isn't working.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Start up noise [Re: Triple_Se7en] #5339161 02/02/20 02:38 PM
M
Mad_Hatter Offline
M
On some engines it can be considered "normal", especially in cooler weather. It can take a few seconds to charge the tensioners. This is the case with my Kia and nearly 170k miles later I've still got the same OE T/C (knock on wood)... and the same start-up ruckus for a few seconds. I'll admit I was skeptical of Kia's explanation and "guarantee" it wouldn't adversely effect the t/c life but I gotta say, thus far they've been right. Like Arco.. the proof is in the pudding.😉
Re: Start up noise [Re: gj] #5339170 02/02/20 02:45 PM
T
T
Tensioner noise on his Mitsubishi? Wonder if there's histories on it making noise cold, but not warm.
As soon as the OP mentioned jobber-like Pennzoil oil filter, I put the blame on it. That's the first place I'd look to see if a better filter quiets those cold startups.
