Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
45 registered members (4WD, Bailes1992, antone, 2002 Maxima SE, bbhero, Amkeer, 5 invisible), 1,360 guests, and 15 spiders.
Topics301,732
Posts5,201,612
Members70,763
Cut wix 57035 #5338460 02/01/20 07:46 PM
cronk Offline OP
Was in service on a Briggs Vanguard v twin for 1 year. No issues noted. Combo valve in this filter, likely due to being too short for a separate bypass valve.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Cut wix 57035 [Re: cronk] #5338515 02/01/20 09:05 PM
53' Stude Offline
Nice cut and post smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Cut wix 57035 [Re: cronk] #5338552 02/01/20 09:40 PM
Ded Mazai Offline
I don't like the valve. Wouldn't buy this filter.
BRZ | M1 HM 5W-20, FU | PZ Synchromesh.
Re: Cut wix 57035 [Re: cronk] #5338622 02/01/20 11:02 PM
blupupher Offline
Man, that combo valve takes up half the filter space. One of the big reasons I don't like them.
Surprised to see a combo valve in a Wix branded filter, I thought those were only their low tier filters (Pro-Tec and Microgard).
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Cut wix 57035 [Re: cronk] #5338730 02/02/20 06:14 AM
B
bullwinkle Offline
B
Weird seeing a combo valve in a Wix Gold, thought that was usually SIlver, Pro Select, etc. That's on of the shortest filter media sections I've ever seen!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Cut wix 57035 [Re: cronk] #5338733 02/02/20 06:27 AM
Sayjac Offline
OPE application filter, small element, that said I'd say it got the job done. As for combo valve use, OPE application the reason, iirc at least one similar posted before. Wix/Napa Gold automotive/vehicle applications majority traditional thread end bypass, some dome.
For comparison, the B&S equivalent filter element posted here not much if at all bigger. Same member compared slightly longer Wix OPE to the B&S here. That Wix uses traditional thread end bypass and bigger element.
I use the Napa Gold 1348 for my Kohler engine application. The OP may not have room for the longer application though.
Thanks for c&p.
Re: Cut wix 57035 [Re: Sayjac] #5338760 02/02/20 07:14 AM
cronk Offline OP
Thanks for c&p.
You are right Sayjac, I don't have room for the taller 51348. This tractor has side covers over the engine that kind of restrict what filter i can use.
I actually found an in between size, but cant remember the part number. I am running the Amsoil equivalent right now, and will post pics when that gets changed in the spring.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
Re: Cut wix 57035 [Re: cronk] #5338778 02/02/20 07:37 AM
Sayjac Offline
I'm going to speculate the in between size is equivalent to Wix 51056 shown in previous link. Looks like it's somewhat longer than B&S but not as long as 5/1348.
Re: Cut wix 57035 [Re: Sayjac] #5338800 02/02/20 08:04 AM
cronk Offline OP
That looks like the one!
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
Re: Cut wix 57035 [Re: cronk] #5338857 02/02/20 08:55 AM
toneydoc Offline
My oil filter on my Briggs motor is not covered so it gets the Wix 51348
I suspect if you change the oil yearly that smaller filter is doing a fine job
1994 Jeep 167k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 8k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
