Hi,
A good friend has an issue with his overflow (? don't know the correct name, but it's above the fuel cap seal so it's for rainwater around the filler opening) tube of the fuel tank on a 2007 Kawasaki Z750.
A few months ago, he noticed that the water won't go down in there, so he used some chemical sink declogger and a wire, and it was eventually sorted out.
Now, the tank is leaking through the tube, there's a mild spot of fuel on the ground coming from the rubber pipe attached to the tube.
Did someone here been there and fixed that ?
TIA,
Super
TIA,
Super
