Forums Migration
Please read this thread
How to tell what engine mount is gone.
by mossietheno1 - 07/10/20 04:28 AM
Raybestos Specialty Rotors
by The Critic - 07/10/20 03:33 AM
Castrol Euro at Walmart, but which one?
by Impatient - 07/10/20 12:48 AM
Car Stereo Upgrade
by montero1 - 07/09/20 11:55 PM
GM 1.4T Hengst vs UFI housing
by hardcore302 - 07/09/20 10:56 PM
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
gas cans, nato style
by BeerCan - 07/09/20 06:24 PM
07 Mustang Fuel Pressure Sensor error
by Barkleymut - 07/09/20 06:21 PM
2007 Hyundai veracruz 0w40?
by Envoyguy - 07/09/20 06:19 PM
How bad is it?
by Averroes - 07/09/20 05:29 PM
various vintage oil filters cut apart
by dogememe - 07/09/20 05:26 PM
LCD burn in? Seriously?
by Klutch9 - 07/09/20 04:12 PM
TurbodogTodd, TNVOL, lowon, 907Lynette, mckaskie
71903 Registered Users
44 registered members (Bailes1992, 87sammy, Astro14, Amkeer, 77GrandPrix, 4WD, 7 invisible), 885 guests, and 33 spiders.
Topics307,673
Posts5,315,375
Members71,900
Fram 3614 need shorter filter #5338005 02/01/20 10:06 AM
L
locomaster1969 Offline OP
L
Hello. Does anyone know of the next couple sizes that are shorter than a 3614?
1986 Yamaha Venture
2010 Honda Accord
2006 Dodge 3500
Small engine sales and repair
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338009 02/01/20 10:13 AM
H
Hombre909 Offline
H
Google is your friend, well sort of...
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338023 02/01/20 10:27 AM
MrMoody Offline
8172, 8170 I think that's about it.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338051 02/01/20 11:12 AM
spasm3 Offline
wix 51394
3614 is 3.34 inches high thread is 3/4-16 bypass 12psi
wix 51394 is 2.97 inches high thread 3/4-16 bypass 8-11psi
Donaldson 502024 is 2.56 inches high, thread 3/4-16 bypass 11-16psi NO ADBV
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338059 02/01/20 11:23 AM
slacktide_bitog Offline
4967
Re: Fram 3614 need shorter filter [Re: slacktide_bitog] #5338083 02/01/20 11:50 AM
MrMoody Offline
Originally Posted by slacktide_bitog
4967
If it will fit & seal at the base: the diameter and gasket are smaller.
Re: Fram 3614 need shorter filter [Re: MrMoody] #5338323 02/01/20 05:35 PM
4967
Oh.
I thought the 4386 and 4967 had the same gasket diameter as the 3614
I thought people on here installed 3614's and even 3600's on cars that spec 4386/4967
Re: Fram 3614 need shorter filter [Re: slacktide_bitog] #5338339 02/01/20 06:00 PM
MrMoody Offline
It's not a lot of difference. Many applications will fit and seal, it depends on the mount. I know they work on our Toyota.
Re: Fram 3614 need shorter filter [Re: MrMoody] #5338348 02/01/20 06:15 PM
B
Bettez88 Offline
B
What he said 👆🏻👆🏻👆🏻
PH8172 -smaller
https://www.fram.com/parts-search/P...CmUQBoQAUASAHAIwDsATNogDbVY10P0K3OsMC6QA
PH8170 smallest
https://www.fram.com/parts-search/P...CmUQBoQAUASAHAIwDsADNogDbVY10P0K3OsMC6QA
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338510 02/01/20 10:04 PM
53' Stude Offline
Slacktide: the 4386 is just smidge longer than 4967 filter. Same base plate.
I run 3614 and 3600's on my Camry
2009 Toyota Camry LE
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5339481 02/02/20 08:47 PM
BlueOvalFitter Offline
What about the PSI setting? Does it matter?
2007 F150, XL, 4.2 V6
5W30 Amsoil Signature Series Oil
NAPA GOLD 1516 Oil Filter
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5340631 02/04/20 09:44 AM
DudeNiceRide Offline
Check your gasket landing on the vehicle to make sure you don't make a messy / costly mistake.
- PH4967 is 2.9" tall with gasket 2.21"/2.48" ID/OD, 12psi relief valve, 2.66" OD, 3/4-16 thread
- PH3614 is 3.3" tall with gasket 2.45"/2.76" ID/OD, 12psi relief valve, 3.01" OD, 3.4-16 thread
(Source: FRAM.com website)
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5340638 02/04/20 09:50 AM
Here is the PH4967 gasket laid on top of the PH3614 per the dimensions on FRAM's site. There's only 0.03" of overlap.
[Linked Image]
