Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
33 registered members (97prizm, BlueOvalFitter, Blkstanger, Aichiguy, 74Widebody, 2 invisible), 1,032 guests, and 20 spiders.
Topics301,813
Posts5,203,174
Members70,784
Crack above oil filter mount,Honda Accord? #5338127 02/01/20 11:39 AM
A
aquariuscsm Offline OP
A
I'm still trying to chase down this oil leak on my Accord. I had it up on ramps, poking around with a flashlight and saw this. The area I'm referring to is that spiderweb looking "cracking" right above the oil filter mounting area (you can see the oil pooling up right below it). Is this in fact cracking or is it just cheap aluminum casting? Is this a removable part or is the the engine block? What's the possibility of this being cracks, causing the oil leak? I see no oil seepage from that spiderwebbing though. What would this repair entail,if in fact it does need repairing?
[Linked Image]
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338131 02/01/20 11:42 AM
M
mattd Offline
M
Looks like casting marks in the oil pan if the picture is upside down?. Leave it be unless you see leaks coming from it. If you do, replace the oil pan. It’s sealed with hondabond.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Crack above oil filter mount,Honda Accord? [Re: mattd] #5338149 02/01/20 12:02 PM
A
A
I took that picture from the top looking down,with the hood open.
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338163 02/01/20 12:20 PM
I
Imp4 Offline
I
That is a casting cold shut. Typically located at the farthest point from the casting pouring cup and sprue. Localized cooling of the metal results in a skin forming on the cast material. When the casting fills out and solidifies, the cold shut is visually detectable versus the rest of the casting. Use google to educate yourself further.
As long as the condition is not excessive or egregious, no harm or reduced performance will result. That is what you have in this case.
Carry on.
Cheers!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338192 02/01/20 12:58 PM
H
hallstevenson Offline
H
Did you post about this before ? I seem to recall posting a link to the replacement part previously. Remembering more now, I recall Googling about this and it's not an uncommon leak point with the gasket between this housing and the engine. Look here, https://www.bernardiparts.com/Honda...;area=2&section=1&assembly=20325, at parts 14 and 21. (3) bolts hold this housing in place.
That said, those markings aren't anything to be concerned about as there's clearly no oil seeping out. The wall thickness on that part is probably 6-10 mm thick.
Re: Crack above oil filter mount,Honda Accord? [Re: hallstevenson] #5338197 02/01/20 01:03 PM
A
A
Yeah I'd posted about the oil filter mount,but this was the first time I've noticed those cracks in the aluminum and it freaked me out.
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338230 02/01/20 02:01 PM
F
Farnsworth Offline
F
File the suspected crack just a little. If a crack it goes deeper than near the surface.
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338249 02/01/20 02:40 PM
M
mk378 Offline
M
That "cracked" appearance is common on Honda blocks and it doesn't mean it is cracked.
If the oil is really coming out there (rather than running down from somewhere higher up, like the valve cover), you would replace the two o-ring style gaskets that seal the filter mount to the block.
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338314 02/01/20 04:25 PM
T
tig1 Offline
T
Yep! Those are not cracks as already stated. Very common in cast aluminum.
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338342 02/01/20 05:04 PM
T
Trav Offline
T
Use a dye in the oil and look for leaks with a black light.
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338470 02/01/20 08:07 PM
2
2010Civic Offline
2
If it isn't leaking I wouldn't worry about it.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Crack above oil filter mount,Honda Accord? [Re: 2010Civic] #5338485 02/01/20 08:25 PM
dishdude Online Content
Online Content
I think that's the problem, he is trying to track down a leak.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5338664 02/02/20 12:23 AM
clinebarger Online Content
Online Content
Replace the 2 O-rings on the oil filter adapter, Just hope it's not the Bedplate that's leaking (The silicone seal right above the filter adapter) as it's major repair.
[Linked Image from i.imgur.com]
2001 Chevy Camaro L92/4L80E
Re: Crack above oil filter mount,Honda Accord? [Re: aquariuscsm] #5339062 02/02/20 12:49 PM
A
A
Thanks everyone for the replies! Yep,I was freaked out a lil.
Re: Crack above oil filter mount,Honda Accord? [Re: Farnsworth] #5339432 02/02/20 06:56 PM
A
AC1DD Offline
A
NO! If it doesn't appear to be leaking leave such things alone. It's a common and not problematic result of metal casting in this case.
