New motorhome, what to use
by another Todd - 04/07/20 05:35 PM
OEM parts... what does it mean to you?
by brages - 04/07/20 03:47 PM
Summer rubber
by OVERKILL - 04/07/20 03:29 PM
Danica Patrick's Indycar: horsepower advantage?
by IMSA_Racing_Fan - 04/07/20 03:15 PM
Internet Issues
by The Critic - 04/07/20 02:48 PM
(4) 255/40/19 Hercules Raptis R-T5 $400
by WylieCoyote - 04/07/20 01:38 PM
Ecogard HE cabin filter
by UG_Passat - 04/07/20 01:04 PM
Missing Wife
by 02SE - 04/07/20 12:53 PM
GDI Rod Bearings
by Triple_Se7en - 04/07/20 12:38 PM
Chromebook & HP M15W laser printer
by Donald - 04/07/20 12:14 PM
Amsoil refines their own oil?
by SVTCobra - 04/07/20 12:12 PM
Favorite Honda Acura filters
by JeffKeryk - 04/07/20 11:09 AM
Samsung Quitting LCD Business
by SubLGT - 04/07/20 10:59 AM
Moisture inside double pane glass doors.
by Cujet - 04/07/20 09:51 AM
When did mechanics start using rubber gloves?
by atikovi - 04/07/20 09:33 AM
Gearless ratchet
by Farnsworth - 04/07/20 09:22 AM
Troy bilt Zero turn hydrostat fluid?
by racin4ds - 04/07/20 09:20 AM
Bad experience with Monroe strut assembly
by sasilverbullet - 04/07/20 09:16 AM
Hitachi CG22EASSLP
by passgas55 - 04/07/20 09:03 AM
mmich187, Voq, bigboychunky, maleesha2000, baker269
71121 Registered Users
101 registered members (762fermeandyou, 77GrandPrix, 53' Stude, 2002 Maxima SE, 2003f7, 2oldtommy, 5 invisible), 2,593 guests, and 17 spiders.
Topics303,729
Posts5,240,866
Members71,121
Fram 3614 need shorter filter #5338005 02/01/20 10:06 AM
L
locomaster1969 Offline OP
L
Hello. Does anyone know of the next couple sizes that are shorter than a 3614?
1986 Yamaha Venture
2000 Honda Accord V-6
2004 F-150
Small engine sales and repair
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338009 02/01/20 10:13 AM
H
Hombre909 Offline
H
Google is your friend, well sort of...
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338023 02/01/20 10:27 AM
MrMoody Offline
8172, 8170 I think that's about it.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338051 02/01/20 11:12 AM
spasm3 Offline
wix 51394
3614 is 3.34 inches high thread is 3/4-16 bypass 12psi
wix 51394 is 2.97 inches high thread 3/4-16 bypass 8-11psi
Donaldson 502024 is 2.56 inches high, thread 3/4-16 bypass 11-16psi NO ADBV
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338059 02/01/20 11:23 AM
slacktide_bitog Offline
4967
Re: Fram 3614 need shorter filter [Re: slacktide_bitog] #5338083 02/01/20 11:50 AM
MrMoody Offline
Originally Posted by slacktide_bitog
4967
If it will fit & seal at the base: the diameter and gasket are smaller.
Re: Fram 3614 need shorter filter [Re: MrMoody] #5338323 02/01/20 05:35 PM
4967
Oh.
I thought the 4386 and 4967 had the same gasket diameter as the 3614
I thought people on here installed 3614's and even 3600's on cars that spec 4386/4967
Re: Fram 3614 need shorter filter [Re: slacktide_bitog] #5338339 02/01/20 06:00 PM
MrMoody Offline
It's not a lot of difference. Many applications will fit and seal, it depends on the mount. I know they work on our Toyota.
Re: Fram 3614 need shorter filter [Re: MrMoody] #5338348 02/01/20 06:15 PM
B
Bettez88 Offline
B
What he said 👆🏻👆🏻👆🏻
PH8172 -smaller
https://www.fram.com/parts-search/P...CmUQBoQAUASAHAIwDsATNogDbVY10P0K3OsMC6QA
PH8170 smallest
https://www.fram.com/parts-search/P...CmUQBoQAUASAHAIwDsADNogDbVY10P0K3OsMC6QA
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5338510 02/01/20 10:04 PM
53' Stude Online Content
Online Content
Slacktide: the 4386 is just smidge longer than 4967 filter. Same base plate.
I run 3614 and 3600's on my Camry
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5339481 02/02/20 08:47 PM
BlueOvalFitter Offline
What about the PSI setting? Does it matter?
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5340631 02/04/20 09:44 AM
DudeNiceRide Offline
Check your gasket landing on the vehicle to make sure you don't make a messy / costly mistake.
- PH4967 is 2.9" tall with gasket 2.21"/2.48" ID/OD, 12psi relief valve, 2.66" OD, 3/4-16 thread
- PH3614 is 3.3" tall with gasket 2.45"/2.76" ID/OD, 12psi relief valve, 3.01" OD, 3.4-16 thread
(Source: FRAM.com website)
Re: Fram 3614 need shorter filter [Re: locomaster1969] #5340638 02/04/20 09:50 AM
Here is the PH4967 gasket laid on top of the PH3614 per the dimensions on FRAM's site. There's only 0.03" of overlap.
[Linked Image]
