Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
47 registered members (antone, 2002 Maxima SE, Bailes1992, bbhero, Amkeer, 6 invisible), 1,320 guests, and 16 spiders.
Topics301,732
Posts5,201,612
Members70,763
Need Help! Chrysler 200 dies without stalling! #5338034 02/01/20 09:45 AM
dwcopple Offline OP
Scenario: remote start car (factory), get in car, turn key to run, step on brake and attempt to shift to Reverse and car dies. Has also happened at a stoplight. No stumble, no warning lights, just cuts out dead. Restarts and drives fine.
Had new alternator and battery installed in July.
What is going on???
HELP!!!
2011 V6 fwd
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338038 02/01/20 09:47 AM
E
eljefino Offline
E
I'd look at the data stream to see if the computer sees the brake light switch status correctly.
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338054 02/01/20 10:16 AM
O
OVERKILL Offline
O
Just to be clear, is he taking the car out of gear at a stop light?
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338074 02/01/20 10:40 AM
Cujet Offline
The interlock prevents thieves from stealing "remote started" vehicles. You must take some action. Either turn the key to "on" in the case of an old-school setup, or push the "start button" or something similar.
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338080 02/01/20 10:49 AM
T
tcp71 Offline
T
That’s the Chrysler anti-carjack feature. My first instinct would be to replace the ignition switch. They can cause funky behaviour.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338153 02/01/20 12:08 PM
dwcopple Offline OP
Even if it happens at a stop light while driving?
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338244 02/01/20 02:33 PM
sloinker Offline
Change the fob battery or try the other fob with a fresh battery.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338349 02/01/20 05:16 PM
R
Rolla07 Offline
R
Happens to me sometimes when using remote start and get in, turn key and step on brake. You just need to turn key once inside snd wait a bit longer before stepping on brake and going in reverse.
What happens at a stop light? Engine just cuts out while you are holding down the brake or?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Need Help! Chrysler 200 dies without stalling! [Re: Rolla07] #5338444 02/01/20 07:24 PM
dwcopple Offline OP
Yep, waiting at stop light, go to press gas on green and it's dead, restarts immediately. The 2011 has keyed ignition, not push button either.
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338809 02/02/20 08:12 AM
Z
zzyzzx Offline
Z
What happens when you don't remote start the vehicle?
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5338996 02/02/20 11:22 AM
dwcopple Offline OP
UPDATE today: remote started car, got in, turned key to run, car dies. took out key and restarted car. Red "security" light (according to manual) blinks about twenty times, then a chime sound, and it turns off. Car drove fine after that. I did not remote start again and made 2 stops. Car had no issues or dying condition. Can a Chrysler garage scan the car and find out why the security light is blinking and the car dying then?
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5339028 02/02/20 12:04 PM
K
KrisZ Offline
K
A blinking security light usually means the security system has trouble reading the RFID signal from they key.
Do you have a second set of keys? Try using them and see if it persists. You may need a new key.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Need Help! Chrysler 200 dies without stalling! [Re: KrisZ] #5339939 02/03/20 11:08 AM
dwcopple Offline OP
two keys, fob built into the key. One is new, under a year old, and one is original.
Re: Need Help! Chrysler 200 dies without stalling! [Re: dwcopple] #5340001 02/03/20 12:48 PM
Z
zzyzzx Offline
Z
Turn the ignition switch on and off 3 times reasonably fast and check the odometer. Check YouTube for some videos on this.
