Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
Should i change my oil change routine ?
by M119 - 04/04/20 03:56 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
104 registered members (928, 2strokeNorthstar, atikovi, 2009Edge, 15 invisible), 2,561 guests, and 18 spiders.
Topics303,584
Posts5,237,758
Members71,094
Fluid Film or RP 342 #5337848 02/01/20 02:01 AM
M
mobilaltima Offline OP
M
I was given an old, but very heavy duty A frame made out of drill pipe that was used and is currently being used for a swing. Its so heavy that I needed a tractor with a bucket to move it. I had it sandblasted and painted, and the swing I had sanded down, touched up and repainted. I plan on giving it to my parents for their upcoming anniversary in July.
There are 2 holes drilled in the top pipe to allow eye bolts to be hung, to hang the swing from. That leaves the inside of the pipe exposed to rain and moisture. While I've had great success with Fluid Film, I've also heard great things about RP-342, never used it though. Which would be better to take a can and coat the inside of the pipe?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Fluid Film or RP 342 [Re: mobilaltima] #5337854 02/01/20 02:14 AM
Dave9 Offline
I suspect you are suffering from OCD. If the outside is painted, odds are anything that substantial will outlast your parents.
However if you're stuck on doing something, you don't at all need this level of expense. Mix some $3 tube of grease with enough gasoline to make it flow and dump it down in. You may think it won't get good coverage but neither will a spray can of anything over a significant distance and the main thing is to just give you an exercise to feel that you did something to quiet the OCD. wink
If you were making this for some truly important mission (long range space probe) and it's all you had to work with, I'd sooner flush it out with acid then use zinc heavy spray paint.
Re: Fluid Film or RP 342 [Re: mobilaltima] #5337913 02/01/20 07:37 AM
R
Railrust Offline
R
I’d say the RP-342 would be longer lasting/more durable, but the fluid film will weep better. I’d use the RP-342.
I use Fluid Film on my truck, but that’s only because I have a five gallon bucket of the stuff and can reapply it twice a year. It does work pretty good, but it washes away. You really have to drive it down a dusty road after and get that dirt mixed in to strengthen it a bit.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Fluid Film or RP 342 [Re: mobilaltima] #5337998 02/01/20 09:59 AM
G
Gearhead Offline
G
Another option is chainsaw bar oil. It’s tenacious & sticks like glue.
