Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
47 registered members (bbhero, antone, 2002 Maxima SE, Amkeer, 6 invisible), 1,283 guests, and 17 spiders.
Topics301,732
Posts5,201,612
Members70,763
Installed new Detroit Truetrac rear end. #5337782 01/31/20 10:14 PM
domer10 Offline OP
Changed the rear diff fluid on my Jeep last month, and few small chunks of metal came out along with drain plug just covered in metallic slime. Came with factory LSD but clutch style, and they are notorious for slowly degrading or actually degrading pretty fast, especially if you don’t change diff fluid.
But after a week, I love it, smooth from start....and after testing it out it some deep snow, 4x4 not even needed. If anyone ever thinking of changing over with jeeps....don’t hesitate. Also upgraded diff cover. Second picture is one of the chunks that came out, about 3 total that size.
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337794 01/31/20 10:52 PM
Chris142 Offline
Is that like a detroit locker?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Installed new Detroit Truetrac rear end. [Re: Chris142] #5337798 01/31/20 11:02 PM
domer10 Offline OP
Yes!
2001 Toyota 4Runner
Re: Installed new Detroit Truetrac rear end. [Re: Chris142] #5337800 01/31/20 11:05 PM
domer10 Offline OP
Actually a bit different I believe the Detroit locker is a bit more aggressive with both wheels spinning at the same time where this has a bit more bias, and is it better on road where as a true locker is a bit more rougher on the road. Like when turning the true track will send a bit less power to outside wheel.
2001 Toyota 4Runner
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337801 01/31/20 11:08 PM
clinebarger Offline
Acts like a Torsen diff, Uses torque biasing helical gears. But in a different arrangement than a Torsen.
Have a Eaton TruTrac in my Camaro's Dana 60.....Love it!
2001 Chevy Camaro L92/4L80E
Re: Installed new Detroit Truetrac rear end. [Re: Chris142] #5337804 01/31/20 11:12 PM
domer10 Offline OP
And is not a e-locker where it’s open until you hit a button, pretty sure the locker was selectable.
2001 Toyota 4Runner
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337806 01/31/20 11:13 PM
domer10 Offline OP
https://m.youtube.com/watch?v=8IA9DVnkIaI Starts getting into detail at 137...only 2.37 clip.
2001 Toyota 4Runner
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337807 01/31/20 11:15 PM
spasm3 Offline
East coast gear rebuilt the rear in my avalanche, with a trutrac. Works great. They recommended a 140 gear oil for towing.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Installed new Detroit Truetrac rear end. [Re: spasm3] #5337811 01/31/20 11:26 PM
domer10 Offline OP
I actually did a lot of research and I ended up using red line they say not to use a synthetic but I did a lot of research 75/90. And found along o people on fourms using it for years, even Eaton isn’t sure themselves.
2001 Toyota 4Runner
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337872 02/01/20 02:26 AM
M
montero1 Offline
M
I had true tracs, front and rear in both of my TJs, both worked fine. Now with the Rubicon, don't need them. Still, keep up with the fluid changes, I remember changing the fluid in my last one (rear) and after 10k, it was black and thin as oil, with no exposure to water, but some off roading.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 V-Star 1300 Deluxe (Hers)
'13 VFR1200F
'14 Porsche Cayman
'16 Harley Electra Glide Limited
'18 GMC Canyon Denali (Hers)
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337897 02/01/20 05:57 AM
E
Egg_Head Online Content
Online Content
E
I installed a Power Trax Lock Right in the rear of my CJ-7, never need to lock the front hubs in the snow and makes the steering response better for it.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
1978 K-5 Blazer 400ci
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337949 02/01/20 07:54 AM
B
buck91 Offline
B
Eaton seems to be of the old school as they recommended running dino on my Eaton Posi 9.75 as well. Generally they take the approach than dino runs cooler but I believe on the TT difs they claim that synthetic may be "too slippery" and alter the torque biasing. The fears do not seem to play out based on real world experience, though.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Installed new Detroit Truetrac rear end. [Re: domer10] #5337955 02/01/20 08:01 AM
Chris142 Offline
Ah. I have a very aggressive Detroit locker in my F250. It clangs,bangs and eats rear tires like they are free. But it's good to have in the mud at the dump or out in the desert with a trailer full of off road vehicles.
Re: Installed new Detroit Truetrac rear end. [Re: Chris142] #5338063 02/01/20 10:31 AM
O
OVERKILL Offline
O
My SRT has an electric locker in the rear (which I have no control over) not sure who makes it, but it's very transparent.
Re: Installed new Detroit Truetrac rear end. [Re: Chris142] #5338252 02/01/20 02:42 PM
B
bullwinkle Offline
B
Weirdly, my '04 E-350 6.0 PSD work van had a factory locker in it that worked fine when cold, but if you took it on a long interstate run it would crack & pop going around corners and make turning somewhat difficult. The aftermarket Eaton in my F-450 has yet to have any trouble.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
