Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Is this a legit website or a virus download?
by atikovi - 02/16/20 09:18 AM
K&N pro vs Napa gold
by Toh1 - 02/16/20 09:16 AM
Car loan questions
by pbm - 02/16/20 08:52 AM
What adhesive to attached these used emblems?
by atikovi - 02/16/20 08:49 AM
2006 Accord electrical problem
by greenjp - 02/16/20 08:12 AM
Wheel hub designs
by Snagglefoot - 02/16/20 08:07 AM
91 10% ethanol or pure 91 gas??
by dbvettez061 - 02/16/20 07:47 AM
Add "like" option for BITOG posts like facebook
by danez_yoda - 02/16/20 07:18 AM
2010 Toyota FJ
by TRDPRO85 - 02/16/20 06:56 AM
Can Engine Oil Help Prevent Carbon Build Up?
by buster - 02/16/20 06:11 AM
Craftsman 4 ton floor jack
by mirvingm - 02/16/20 05:50 AM
Experience with the Ram 3.0 diesel
by dlundblad - 02/16/20 05:16 AM
Is Fuel system cleaner efficient??
by Omar_Eltahan - 02/16/20 05:16 AM
This is a good example of engineering today.
by Exhaustgases - 02/16/20 04:25 AM
rob1715, mirvingm, AdditionalD, egon, Stinky123
70712 Registered Users
95 registered members (aba4430, 762fermeandyou, 97prizm, Ada_Potato, 01VFR, 2015_PSD, 7 invisible), 2,612 guests, and 37 spiders.
Topics301,518
Posts5,197,148
Members70,712
Piston Velocity and Position #5337744 01/31/20 09:16 PM
MolaKule Offline OP
Global Moderator
Global Moderator
For this two-part problem we're going to use my 4.3L Vortec V6 in this example.
Data: The engine's crankshaft is rotating at 1000 RPM. The Piston Stroke is 3.48 inches.
To simplify the problem somewhat, neglect any connecting rod angles (for now). The usual Piston Stroke Length Ls and crank radius r, as in Ls = 2*r applies.
Q1: What is the maximum velocity of any one of the pistons in Inches/Sec.?
Q2: At what position in the cylinder will the piston attain its maximum velocity?
This Question is not open to any Engineering Discipline or Physics Discipline.
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
Re: Piston Velocity and Position [Re: MolaKule] #5337939 02/01/20 07:29 AM
Astro14 Online Content
Online Content
How about reformed Astrophysics majors?
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Piston Velocity and Position [Re: MolaKule] #5337952 02/01/20 07:56 AM
B
buck91 Offline
B
Wouldn't this just be [ (stroke length) * (4) * (rpm) ] / 60 seconds = inches/seconds?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Piston Velocity and Position [Re: buck91] #5337971 02/01/20 08:31 AM
MolaKule Offline OP
Global Moderator
Global Moderator
This question is similar to the chainsaw tooth velocity question:
https://www.bobistheoilguy.com/foru...7793/chainsaw-tooth-velocity#Post4707793
Hint: You can use one of the online calculators: http://www.softschools.com/science/physics/calculators/rpm_to_linear_velocity_calculator/
The centerline of the crankshaft is directly below the cylinder.
Re: Piston Velocity and Position [Re: MolaKule] #5337980 02/01/20 08:35 AM
MrMoody Offline
Assuming the centerline of the cylinder intersects the centerline of the crank, it seems fairly simple but maybe I'm missing something.
If the stroke is 3.48, then so is the diameter of the big end circle. The circumference would be 3.48 x pi = ~ 10.933 inches. At 1000 rpm, that would be 10933 in/min ÷ 60 = 182.22 in/s, which would also be the maximum piston speed at 90° crank position. At 90°, the piston would be exactly halfway through its travel.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Piston Velocity and Position [Re: MrMoody] #5338036 02/01/20 09:46 AM
MrMoody Offline
I haven't looked at any links or google, but I don't think this is quite right, but getting it right would require knowing the rod length to do some trigonometry.
(NA) Re: Piston Velocity and Position [Re: MrMoody] #5338041 02/01/20 09:54 AM
MolaKule Offline OP
Global Moderator
Global Moderator
We're keeping it simple which is why I stated that we will neglect the crank angle for now.
Quote
(NA) Re: Piston Velocity and Position [Re: MolaKule] #5338088 02/01/20 10:58 AM
W
walterjay Offline
W
The piston will be at the center point of its travel for max velocity. As for the other I cannot answer.
(NA) Re: Piston Velocity and Position [Re: walterjay] #5338093 02/01/20 11:04 AM
MolaKule Offline OP
Global Moderator
Global Moderator
(NA) Re: Piston Velocity and Position [Re: MrMoody] #5339094 02/02/20 01:19 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Assuming the centerline of the cylinder intersects the centerline of the crank,...
Thanks to all who participated.
MrMoody and Astro14 (in absentia smile ) had the correct answers. thumbsup
This was another problem in the conversion of radial velocity to linear velocity as in,
Vlinear = Omega*radius as two hints were given.
To simplify the problem we assumed no effect of crank angle/rod/piston-pin relationships, which meant the piston is seeing only reciprocating, linear travel. Simplification also meant the connecting rod was very long so crank angles did not enter into the problem.
At 0 degrees Top Dead Center and at 180 degrees Bottom Dead Center, and with the crankshaft rotating clockwise, the piston motion is virtually zero.
At 90 degrees and at 270 degrees, the piston is halfway down or up the cylinder, respectively, and it is at these positions in which the piston velocity is maximum, or 182.22 inches per second.
For the next QOTD, we will include crank angle.
