what ceramic brake pads should i choose?
by apollo18 - 02/19/20 05:21 PM
school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
118 registered members (4WD, 55hambone, 1978elcamino, 53' Stude, 97prizm, 9 invisible), 2,314 guests, and 19 spiders.
Topics301,661
Posts5,200,168
Members70,751
Page 1 of 3 1 2 3
Change now or wait a bit? #5337434 01/31/20 03:05 PM
W
wbwanzer Offline OP
W
I bought a new '19 Kia Sorento with the 3.3 NA V6 engine in December. I now have 19xx miles and will probably have 2000 by Monday afternoon. The manual calls for 5W-30, API SM or above, ILSAC GF-4 or above, ACEA-A5 or above. The manual doesn't specify synthetic (unless those requirements indicate that it's synthetic), so I don't know if it came with synthetic from the factory. I'll guess not. I've already purchased some CARQUEST (by Amalie) full Synth 5W-30 D1G2, SN Plus GF-5 oil. My question is, should I change out the factory oil this Monday when it's predicted to be near 60 degrees and vehicle will have 2000 miles, or wait another month when I'll have approximately 3000 miles on factory fill and hopefully find a warm day then. My driving is roughly 60% short trips and 40% highway. Severe usage schedule calls for oil change at 3750. So, change now, closer to 3000, or it doesn't matter?
Thanks
Re: Change now or wait a bit? [Re: wbwanzer] #5337439 01/31/20 03:09 PM
STIcandy Offline
I would have changed the factory fill by 1,000 miles
Re: Change now or wait a bit? [Re: wbwanzer] #5337451 01/31/20 03:21 PM
J
JLTD Offline
J
60°F sounds like a good temperature day for an oil change, and I'm a fan of early first changes so IMO go for it!
Lates.
Re: Change now or wait a bit? [Re: wbwanzer] #5337463 01/31/20 03:32 PM
T
tundraotto Online Content
Online Content
T
ACEA A5 oils are also available;
Pennzoil Platinum 5W-30
Castrol Edge EP 5W-30
Mobil 1 'vanilla' 5W-30
the carquest is not.
Re: Change now or wait a bit? [Re: tundraotto] #5337481 01/31/20 03:55 PM
W
wbwanzer Offline OP
W
Does ACEA A5 make it synthetic? Should I take the CARQUEST back and get one of those you have listed? D1G2 is pretty good oil, no?
Kia seems to be hooked up with Total Quartz. Don't know much about them. Synthetic??
Re: Change now or wait a bit? [Re: wbwanzer] #5337485 01/31/20 04:00 PM
T
tiger862 Offline
T
Change at normal oil change time. Never seen proof of early oil change saving engines.
Tiger862
2018 Grand Caravan
Re: Change now or wait a bit? [Re: wbwanzer] #5337498 01/31/20 04:17 PM
L
Leo99 Offline
L
Thanks
I've never seen any data that says it matters. My vote is "doesn't matter". Why do you think you're severe usage?
Do you meet this criteria:
Repeated short distance driving.
Driving in dusty conditions or sandy areas.
Extensive use of brakes.
Driving in areas where salt or other corrosive materials are being used.
Driving on rough or muddy roads.
Driving in mountainous areas.
Extended periods of idling or low-speed operation.
Driving for a prolonged period in cold temperatures and/or extremely humid climates.
More than 50% driving in heavy city traffic during hot weather above 90 degrees Fahrenheit.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Change now or wait a bit? [Re: STIcandy] #5337499 01/31/20 04:20 PM
Malo83 Offline
X2 thumbsup
Re: Change now or wait a bit? [Re: wbwanzer] #5337506 01/31/20 04:30 PM
T
Online Content
T
Nothing says that ACEA A5 oils have to be synthetic - but I dont know of any conventional oils that meet the standard.
ACEA A5B5-10
ACEA A5/B5 oils are Upper Mainline lubricants. They are designed for use in high performance gasoline and light duty diesel engines that are specifically designed to use a low viscosity oil. These oils may be unsuitable for use in some engines.
ACEA A5/B5 oils are typically low HTHS (≤3.5cP) SAE 5W-30 based on API Group III base oils. The main physical and chemical requirements for ACEA A5/B5 are shown below:
Requirement Method Unit Limit
HTHS viscosity CEC L-36-A-90 cP ≥ 2.9 and ≤ 3.5
Sulphated Ash ASTM D874 %wt ≤ 1.6
Phosphorus ASTM D5185 %wt Report
Sulphur ASTM D5185 %wt Report
Evaporation loss (NOACK) CEC L-40-A-93 % ≤ 13
Total Base Number ASTM D2896 mgKOH/g ≥ 8.0
The low HTHS (≤3.5cP) required by ACEA A5/B5 limits the number of additional performance claims that can be coupled with ACEA A5/B5.
Re: Change now or wait a bit? [Re: wbwanzer] #5337510 01/31/20 04:31 PM
I
Imp4 Online Content
Online Content
I
Changing it now, or 1000 miles ago, or in another 1000 miles will result in zero difference over the life of your vehicle.
Whenever you choose to change it, up to the OEM recommended interval, will only result in you feeling better about the situation. It will have no material impact on the life of the vehicle.
This stuff just isn't that complicated, no matter what the naysayers will purport.
Carry on!!!
cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Change now or wait a bit? [Re: tiger862] #5337519 01/31/20 04:42 PM
K
ka9mnx Offline
K
Agree...
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Change now or wait a bit? [Re: wbwanzer] #5337590 01/31/20 06:02 PM
B
BucDan Offline
B
Make it easier on yourself, Drive it to 5000 miles, change it, and then change it every 5k miles after. Easy numbers, easy to remember, easy cadence. Use synthetic, why not at this point in 2020 no matter if the manual says to use synthetic or not?
2013 Audi S4 6MT - 45K miles
- OCI every 5K miles
- Motul X-cess 5w-40
- Mann OEM oil filter
Re: Change now or wait a bit? [Re: BucDan] #5337596 01/31/20 06:08 PM
Marco620 Offline
That's fair. I changed factory oil at 5k.
15' Civic 1.8 i-vtec 310,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Change now or wait a bit? [Re: wbwanzer] #5337600 01/31/20 06:11 PM
T
Triple_Se7en Offline
T
I changed my 2020 Kia Soul X-Line at 1600 miles. I decided to wait a little longer for full synthetic thou. So I opted for Pennzoil Gold Syn Blend instead. That will get kicked to the curb at 4000 miles. Then I will upgrade it to Mobil-1 full synthetic and change it every 4K, which is easier to remember than every 3750 (Severe Service)
Using Carquest Full Synthetic this OCI is fine. I recommend (many others here too) to use OEM HyunKia oil filters. (Both dealers offer the exact same one for 3.3).
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: Change now or wait a bit? [Re: wbwanzer] #5337624 01/31/20 06:38 PM
W
walterjay Offline
W
I would change it now. Going forward every 4,500 miles. This is a GDI engine so use synthetic.
Page 1 of 3 1 2 3
