Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
76 registered members (Avery4, bbhero, 2003f7, ABomb369, Astro14, 2010Civic, 8 invisible), 1,398 guests, and 26 spiders.
Topics303,463
Posts5,235,609
Members71,074
Page 3 of 4 1 2 3 4
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337092 01/31/20 08:46 AM
H
Highboy Offline
H
Get a remote starter. Press button 10 minutes before you leave and make sure you left the heater on the night before and you’re good to go.😎
2006 Scion tC ST/Oem filter
2008 Scion tC ST/Oem filter
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
2019 Subaru WRX
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: Highboy] #5337102 01/31/20 09:00 AM
G
Gebo Offline
G
This would solve your problem. Works like a charm on my 4Runner. Like Highboy said, make sure the defrost was left on the night before. HA!
Changing oil weight ain't gonna do anything. I would make sure the coolant is full. You could replace thermostat as that would be cheap if you do it yourself. Just make sure you get a
Nissan OEM.
But, what you are describing sounds perfectly normal. All of my cars warm up at different rates. The GX470 is the quickest (my wife's) and the LS400 takes the longest. I'm gonna replace the thermostat in the LS400 the next coolant change as it has never been changed. It may not being fully closing. IDK?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: Highboy] #5337138 01/31/20 09:42 AM
A
ARCOgraphite Offline
A
Fuel waster and environmentally BAD BAD BAD.
But the lazy, careless solution. for ME ME ME!
Nothing personal HB - just my general observation of this north american species of "human"
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: Gebo] #5337164 01/31/20 10:16 AM
A
atikovi Offline
A
GD this country is getting soft. Heaven forbid we feel a little cold for 5 minutes in the morning.
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: ARCOgraphite] #5337177 01/31/20 10:31 AM
H
Highboy Offline
H
What’s the Difference between sitting in the car or pressing a button and then going to the car. He still letting it warm up.
2019 Subaru WRX
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: Highboy] #5337186 01/31/20 10:45 AM
A
atikovi Offline
A
Nothing. Letting it idle to warm up is the problem. Wasting gas not moving, diluting the oil with a rich fuel mixture among others.
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: Highboy] #5337196 01/31/20 10:53 AM
W
Wolf359 Online Content
Online Content
W
The difference is that he's cold sitting in the car and if you press a button. The car is warm when you get in. Still a waste of fuel both ways. Getting in and driving it will warm it up much faster than waiting at idle and it doesn't waste fuel.
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337257 01/31/20 11:47 AM
J
JMJNet Offline
J
I think the t-stat is slow aka weak.
For replacement, please buy a stealership t-stat for your car, NOT stant from part store.
  • 2017 Toyota Sienna
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337291 01/31/20 12:14 PM
J
JoelB Offline
J
Saying cold start and 30 degrees together makes me chuckle.
Mine: 2020 Corolla SE
Factory fill
OE Filter
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337316 01/31/20 12:50 PM
Z
zorobabel Offline
Z
Seems normal OP.
Get in the car, start the engine, put on your hat, gloves and seatbelt, then drive gently (not sure what you can do with that CVT to keep rpms around 2000 with a light throttle).
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: JoelB] #5337337 01/31/20 01:30 PM
O
OilUzer Offline
O
I've heard you guys and people in AK go out swimming in the lakes and rivers when it's 30F outside. Fairbanks was -40 a few weeks ago. shocked2
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337356 01/31/20 02:04 PM
V
Villalobos Offline
V
Idling with a load on the battery is not ideal.
2000 Suburban 250k
2014 MKX 100k
2015 IS250 50k
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337391 01/31/20 03:03 PM
H
hallstevenson Offline
H
Glad to see the majority of responses coming from folks with actual experience with "cold" temperatures (50º F ain't cold !!). You know, those folks who think a car can be parked outside overnight in 15-30º F, possibly with rain or snow mixed in, and you get in your car, start it, put on your seat belt, and go ! Yeah, doesn't happen...
Sounds like the car is operating completely normal.
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337598 01/31/20 07:10 PM
B
BucDan Offline
B
The most idling you should do is when the RPM drops down, that's it. Just go after that. My reasoning is that it is to let the oil circulate a bit, then when the idle drops, it's sufficient for driving and maintaining wear protection.
Just don't be the guy that, on a cold start, starts the car, and goes immediately without waiting 30 seconds, let alone 3 seconds.
It's gotten down to 40F here in the winter, cold as heck! Even then, at minimum I let the idle drop first.
2013 Audi S4 6MT - 45K miles
- OCI every 5K miles
- Motul X-cess 5w-40
- Mann OEM oil filter
Re: Maxima 2009, takes long to warm up at 30F, switch to 0w30? [Re: mahanddeem] #5337753 01/31/20 10:30 PM
J
jqgz Offline
J
You should do a grille block. Start by blocking off a portion and go from there. Less cold air flow with the same heat generated will result in faster warm up.
Page 3 of 4 1 2 3 4
