Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
76 registered members (brages, 4WD, Astro_Guy, 2002 Maxima SE, Bailes1992, 7 invisible), 1,485 guests, and 20 spiders.
Topics301,732
Posts5,201,619
Members70,766
Stens 120-738 hydro filter #5337143 01/31/20 08:45 AM
P
passgas55 Online Content OP
OP Online Content
P
I am going to change the transmission oil in the zero turn. It has the Hydro Gear ZT 3400 transmission. Hydro Gear 52114 is the filter number. I was going
with them for the filter but some of my research says their filter is made in China. I don't mind paying more for an OEM filter if made in the USA but China?
I have read most of Stens filters are made in the USA. Stens number is 120-738. From what I can tell the specs are the same . What filter would you use on a ZT 3400 transmission? In case you want to know I am using M1 15/50 for the oil.
Re: Stens 120-738 hydro filter [Re: passgas55] #5337163 01/31/20 09:12 AM
L
loneryder Offline
L
Have fun! Depending what mower you have, it can be a real pain to get to the fill hole. You have to open the fill hole to let the air our even if you are filling via the tanks. I have a Ferris with the 3400's and the fill plugs are covered by the frame.
Re: Stens 120-738 hydro filter [Re: loneryder] #5337268 01/31/20 10:54 AM
P
OP Online Content
P
From what I see the tank hose goes to inside top side and I see a allen head plug on very top. It looks easy to get to. I will let you know in a about 3 weeks or so. This seems opposite than most other people. Their tank is hook to the top while the bleed/fill is on the side. I plan on removing the wheels to make getting to the filter easier. I plan on pre filling the filters some which most videos do not show.
Re: Stens 120-738 hydro filter [Re: passgas55] #5338315 02/01/20 04:26 PM
J
JTK Offline
J
I didn't own my 2010 model year Cub Z-Force ZTR long enough to change oil and filters on the ZT2800's it had, but on those, the fluid drained when you removed the filters and the refill / level check plugs were on the sides (inboard, top). Just make sure you can get to and remove those refill plugs before you start. They were super tight on mine. In terms of filters, Stens has never steered me wrong. Probably nothing wrong with Chinese aftermarket ones either, it's just that you change these so rarely, I'd want a really good filter.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Stens 120-738 hydro filter [Re: passgas55] #5340261 02/03/20 07:19 PM
P
OP Online Content
P
Filters will be in Friday. The vents are on the top and it takes a 1/4" hex . At first I could barely fit a ratchet in but did not have room
to operate it. Got to looking at it. If I remove the latch setup for the seat, I could extend up the ratchet above the frame and I did remove the plugs.
Installed them back, put seat latch back and now it will be easy oil change later.
Re: Stens 120-738 hydro filter [Re: passgas55] #5345598 02/09/20 08:06 PM
P
OP Online Content
P
I did get to change the filters/oil Saturday. I used the over flow as the vent and filled on the top plug with a long funnel. Filled fast that way.
I do need to change the allen head to hex head next time. I did mess up one of the allen heads by trying to remove it at a slight angle. Don't do it. Next thing
is the the stens filters are eco core type filters. Was not expecting that but I think they should be good to go. I used the same filter socket that fits my Frontier truck.I think its a 65/67 from Walmart.
