Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
107 registered members (alchargo, Aquamania, 2015_PSD, 55hambone, ANokesPDX, 10ecfarmer, 16 invisible), 2,158 guests, and 20 spiders.
Topics303,501
Posts5,235,313
Members71,063
Page 2 of 2 1 2
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5337113 01/31/20 09:14 AM
N
Nitronoise Offline
N
I have been running 5w30 full synthetic quaker state QSUD in my gen sets with Briggs motors for years biggest run was a full week in 80-85 degrees F only stopping to refuel
My small one is 10 years old and still starts on the second pull m once a month
I do run them once a month for 15 to 20 minutes
07 Ford Freestyle 166K
06 Honda Acord EX 133K
02 Ford Tarus 123K
00 Buick Regal SC 144K
95 Goldwing 28K
Re: Oil recommendations for HD portable generator [Re: Nitronoise] #5337133 01/31/20 09:38 AM
A
ARCOgraphite Online Content
Online Content
A
What engine? My generac 5500 (?) has some "chinese honda copy" 390cc OHV
and that would start knocking with a PCMO oil when hot.
Are you sensitive to engine racket and performance devolving when overstressed?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5337149 01/31/20 09:53 AM
N
nascarnation Offline
N
In my experience none of this OPE stuff is developed with synthetic oils and any of the syns you put in are a bonus.
The stuff I've had fail is mechanical like broken exhaust valves, con rods, et unrelated to lube.
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5337359 01/31/20 02:06 PM
spasm3 Offline
I've been running amsoil HDD 5w30. I have some amsoil ame 15w40 , but I worry about pull starting that in winter weather.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Oil recommendations for HD portable generator [Re: ARCOgraphite] #5337574 01/31/20 06:41 PM
K
Kamele0N Offline
K
You both need to adjust valves on your generator(s)....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Oil recommendations for HD portable generator [Re: Nitronoise] #5337577 01/31/20 06:46 PM
A
Astro_Guy Offline
A
The suggestion of "run any 5w30 synthetic" is a "Fool's Choice"
I agree.
I have been running 5w30 full synthetic quaker state QSUD in my gen sets with Briggs motors for years biggest run was a full week in 80-85 degrees F only stopping to refuel.
I am glad to hear that you have have had a long string of success with what you are doing here, but one of these days your luck may run out. There is a reason for Briggs recommending 15W-50 for commercial applications, and it's been discussed at length here before. That reason is HTHS viscosity. Generators running at 3600 RPM with a heavy load sounds like a commercial application to me.
'01 Volvo V70XC, 251k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5337621 01/31/20 07:35 PM
T
tundraotto Online Content
Online Content
T
I'd (and do) run a 15W-40 HDEO on all ope....maybe if I had a snowblower, I would use a 5W-40 HDEO. It's cheap and I only have high ambient temperature and air cooled OPE to run so I run an affordable robust oil that I can afford to change every season at least once..
Re: Oil recommendations for HD portable generator [Re: tundraotto] #5337759 01/31/20 10:37 PM
A
Astro_Guy Offline
A
That's probably great advice for most OPE in hotter climates, but you would change your mind in a heartbeat if you ever had to pull start a snowblower with that oil at or below freezing. I had been running 15W-40 in my recently retired leaf vacuum with a 4.5 HP Tecuseh motor. Starting that thing below 40 degrees using that oil was challenging to say the least. I don't even want to think about pull starting a piece of OPE at 25 degrees with 15W-40 oil in the sump.
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5337843 02/01/20 01:56 AM
G
GMBoy Offline
G
I've run Mobil 1 10w/30 in my portable generator, my RV generator and all my OPE - no noise, no issues and I change yearly.
Re: Oil recommendations for HD portable generator [Re: Kamele0N] #5337961 02/01/20 09:15 AM
A
Online Content
A
Valves get tighter when hot and no loss of power so ... why Mr. K ?
I did have to adjust the valves on my new Toro 252cc snowthrower after about only 10 hours.
The ex. valve lash measured only 0.10mm and it should be 0.20mm ( 0.0008") !
I knew it needed something as The engine was spitting and popping when hot, had very loud exhaust and lost power
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5338318 02/01/20 05:29 PM
K
Kamele0N Offline
K
In your case I tought knocking means spitting....
Since in cars with EFI you have "knock sensor" wich controls pre-ignition
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5338459 02/01/20 08:43 PM
spasm3 Offline
Anyone see a downside to running amsoil HDD?
Re: Oil recommendations for HD portable generator [Re: NWGuy] #5342713 02/06/20 02:35 PM
R
repairman54 Offline
R
Full synth and adjust weight to operating temps. . -25f starts you better have a 0-30w in it, I've lifted the 7.5k off the ground with the recoil in -15 temps, no way it was starting with 5-30w in it. My Generac 10 kw gets 0-30w now to handle those temps along with a sump heater and a battery heater on a thermostat to kick on at 20f . My old Craftsman BS now lives in a slightly warmer climate and is on 5-30w diet to deal with 10f to 90f temps. .
John
Anything you say can & will be misquoted & used against you
'16 Equinox 3.6 AWD
'11 Tahoe LTZ
'15 2.5 Malibu
'17 Continental 2.7 twin turbo
FLHR
SkiDoo 1200's
Sea Doo GSX
Re: Oil recommendations for HD portable generator [Re: spasm3] #5344098 02/07/20 09:51 PM
cronk Online Content
Online Content
Seems like a good choice.
I have ran Amsoil ase 10w30 small engine in my generators for 10+ years as well.
Amsoil also just came out with a 5w30 small engine oil for cold weather use.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Page 2 of 2 1 2
