GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
2015 Forester - whine/Rough at specific RPM
by MoneyJohn - 02/19/20 09:06 AM
Brake hum when backing up after a rain storm
by vortex - 02/19/20 08:54 AM
TorchHypnosis, Tgibson, GardenStateAudi, Strommen95, Idaholewis
70748 Registered Users
115 registered members (1978elcamino, andreigbs, 28oz, 750IX, 01rangerxl, 4WD, 13 invisible), 2,375 guests, and 25 spiders.
Topics301,659
Posts5,200,107
Members70,748
winter tires vibrate #5336664 01/30/20 05:46 PM
T
tomcat27 Offline OP
T
for the winter I got a set of Hankook icept iz2's on new American Racing wheels. bad vibration above 50. 5 times back to DT, 2 road force balances, same problem, although slightly better each time. at least two of the wheels had 12+ weights on them!!!
they finally replaced the tires with Michelin winter tires. the vibration is better, but still noticeable at 50 and very annoying above 70. am I expecting too much?!?!?!? tomorrow they will check for runout on the wheels. Honestly, I am tired of all this and would prefer to return them "DT style".
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: winter tires vibrate [Re: tomcat27] #5336666 01/30/20 05:48 PM
E
edyvw Offline
E
Go to Costco if you are member and pay for balancing.
That is what I do after visit to DT. I have Michelin X-Ice2 on my Toyota and they are smooth as butter.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: winter tires vibrate [Re: tomcat27] #5336676 01/30/20 05:59 PM
H
hemitom Offline
H
I would be looking at the rims then.
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: winter tires vibrate [Re: tomcat27] #5336686 01/30/20 06:11 PM
W
WhyMe Offline
W
are they hubcentric wheels?? if not they need to be tightened off the ground with no pressure on the tires. found this out on my old outback with uni wheels.
Re: winter tires vibrate [Re: tomcat27] #5336789 01/30/20 07:46 PM
H
HangFire Offline
H
There ya go.
Various musings: http://hangfire.net
Re: winter tires vibrate [Re: HangFire] #5336846 01/30/20 09:08 PM
R
rubberchicken Offline
R
There ya go.
A problem with the wheel should have been revealed by the road force balancing, correct ?
Re: winter tires vibrate [Re: tomcat27] #5336861 01/30/20 09:22 PM
R
Rand Offline
R
Take it to a dealer have them road force balanced.. if that fixes it good.
if wheels or tires are bad go back to DT and have them make it right.. probably can get it paid for in this case by their corp. office.
all 3 DT I have been to their roadforce balancer guy has no clue. and I say that nicely.
comes out worse than their regular balance.
Winter tires can be balanced quite well.. its a tire or wheel issue. are they hubcentric? if not tighten in air.
I'm guessing bad tires.
then I see you had 2 sets..
that makes me think bad person running the machine or wheels.
Re: winter tires vibrate [Re: tomcat27] #5336884 01/30/20 09:52 PM
B
BHopkins Offline
B
I've never had an out of balance vibration issue with my snow tires. But then, I've never mounted them on aftermarket wheels. I always buy used OEM wheels.
That said inexpensive winter tires are notorious for requiring a lot of weights to balance. It's surprising to hear that you are still feeling vibration with the Michelin tires. That's what makes me wonder if it has to do with the aftermarket wheels.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: winter tires vibrate [Re: rubberchicken] #5336886 01/30/20 09:55 PM
H
HangFire Offline
H
There ya go.
Off center mounting, out of round, or massive imbalance of the wheels is not going to be fixed by road force balancing, no. Revealed? Only if the operator knows what they are doing.
Re: winter tires vibrate [Re: tomcat27] #5336894 01/30/20 10:03 PM
Danno Online Content
Online Content
Had same issue at Costco. Turned out to be a bent steel wheel, no amount of balanced would fix that.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: winter tires vibrate [Re: tomcat27] #5336953 01/31/20 12:10 AM
G
geeman789 Offline
G
Same vibration after a tire change means the problem is likely the WHEELS. Cheap aftermarket wheels ( and I would definitely put most American Racing wheels in that category ) often have more runout than a factory wheel, and often NEED to be properly road force balanced for a smooth ride.
Unfortunately, most shops don't properly road force balance a wheel / tire assembly because it takes way too much time. Ideally, you spin and measure each wheel with no tire mounted, locating the LOW spot on the wheel. Then you mount the tire, put the assembly back on balance machine, spin and measure, to find the stiff spot on the tire. Then you break down the tire / wheel assembly, ROTATE the tire on the wheel to match the stiff spot on the tire with the low spot on the wheel. Then you balance the assembly ...
This just took 3 to 4 times as long as a regular mount and balance. Most shops only road force balance on come backs, and many techs have never done a TRUE road force balance, because, well, it just takes too long.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: winter tires vibrate [Re: tomcat27] #5337061 01/31/20 06:52 AM
CapriRacer Offline
^^ X2.
Most tire techs don't know how to operate a RoadForce machine.
What we don't know here is if the tech used the dynamic balance setting or the static balance setting. Did he match mount the tire to the wheel? And what force values did he get?
We also don't know which car is involved - some cars are incredibly sensitive.
Further, the wheel could require a hub ring to center it properly - and even then, the tech has to be careful to snug up the wheel so he doesn't pull the wheel off center.
And my guess is that the problem is that last one. My recommendation is for the OP to take one of the wheels off and see if it is hub centric or not by putting the loose wheel back on the hub and seeing if he can move it around - getting a feel for how much slop there is. I'd also see if the wheels require a hub ring by going to the website.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: winter tires vibrate [Re: tomcat27] #5337115 01/31/20 08:14 AM
T
Traction Offline
T
Another thing to check, that I have seen many times after somebody puts aftermarket wheels on their car, is some domestic vehicles have a couple rotor retaining clips over the studs to hold the brake rotors on during assembly. The aftermarket wheels do not have a recess to clear them, and it will cock the wheel slightly making them wobble.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
