Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
35 registered members (blufeb95, bbhero, Black_Thunder, avi1777, ArrestMeRedZ, 14Accent, 4 invisible), 1,035 guests, and 22 spiders.
Topics301,683
Posts5,200,452
Members70,756
Coyote filter comparison and possible problem #5336490 01/30/20 02:45 PM
A
advocate Offline OP
A
Comparing these filters for my 2018 5.0 coyote. I typically use the Fram Ultra and have never had any issues with them. This time though I used some of my recent stash of Champions from rock auto’s clearance sale. The issue comes from the gasket though. On these filters it’s much thicker and wider then the other filters. I’m wondering if the gasket impedes on the oil opening as showed in the picture. My reasoning for this is that I’ve developed a leak after a cold snap. Leaving puddles where I park it. I swapped out the filter with another champion and the leak continued. Then I changed it out for a motorcraft which I don’t like at all but I figured it might be going to the dealer anyways... well the leak stopped. The dealer wasn’t able to find a leak after a dye test. Are these wide gaskets which are the same outside diameter but smaller inside diameter causing an issue being that close to that oil opening causing a leak? I’m baffled...
Weights on the filters for fun:
Fram Ultra 313 grams
Motorcraft 292 grams
Champion 343 grams
9084988A-30FD-45B3-B7D6-4F8FE846601D.jpeg32C96FCB-2C57-434D-91CE-7E78B0193389.jpeg21349EE2-3DE3-4E7D-83BA-BF13692B3DE3.jpeg
Re: Coyote filter comparison and possible problem [Re: advocate] #5336493 01/30/20 02:52 PM
L
Leo99 Offline
L
I'd stop using the Champion filters.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Coyote filter comparison and possible problem [Re: Leo99] #5336505 01/30/20 03:09 PM
J
JLTD Offline
J
Yup, along with the mantra: "don't fall for sale prices on cheap filters from RockAuto" (they're on sale for a reason)
Lates.
Re: Coyote filter comparison and possible problem [Re: Leo99] #5336521 01/30/20 03:27 PM
K
kstanf150 Offline
K
Whew !!! That was a tuff decision 🤔🤔🤔🥴🥴🤣🤣
Re: Coyote filter comparison and possible problem [Re: advocate] #5336527 01/30/20 03:32 PM
cb_13 Offline
Well that is disappointing. I had considered buying a few of those discounted Champion filters myself as they appeared to be decent filters from the dissection posts here about a year ago.
Re: Coyote filter comparison and possible problem [Re: advocate] #5336540 01/30/20 03:50 PM
O
oldhp Offline
O
I would clean that whole area around the filter gasket imprint. Put a new oil filter on. Drive it 25'ish miles and recheck for leaks. Are those the oil cooler lines?
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Coyote filter comparison and possible problem [Re: advocate] #5336582 01/30/20 04:29 PM
K
krismoriah72 Offline
K
I had a leak on my Champion that i installed on my 5.3 chevy. I always tighten by hand only. I took an oil filter wrench and got another half turn that i wouldnt have gotten by hand.. leak gone.
Re: Coyote filter comparison and possible problem [Re: advocate] #5336612 01/30/20 04:58 PM
A
advocate Offline OP
A
I think I’ve sworn myself off of the champions. Though the one that was leaking on me to start with looked great when I cut it open. Very well constructed filter for the money. But I can’t have them leaking on me. I tried to hand tighten it a little more. Still had drips so I changed the filter with another champion. Cleaned thoroughly and still had leaks for a few days before putting on a different kind of filter which seemed to stop the leak.
Those are cooler lines oldhp.
I’m going to be monitoring for usage/leaks over the next while and hopefully it’s solved. If so I have a place to put the bulk of champions that I bought. Which sucks because they are such a nice looking filter. For me though they aren’t cutting it. Back to Fram Ultras I think.
Re: Coyote filter comparison and possible problem [Re: advocate] #5337062 01/31/20 06:57 AM
gotnogunk Offline
I had the same problem with the champion on my F150 3.7 v-6. I may try one more a little tighter.
2018 Cadillac XTS 3.6
2014 Ford F150 3.7 supercrew
Re: Coyote filter comparison and possible problem [Re: advocate] #5337147 01/31/20 08:52 AM
A
advocate Offline OP
A
Maybe if I really torqued it on there it wouldn't leak, but it would be a pain to get it off when it's oil change time. I use the same moderate force that I always use when putting one on. But the gasket is a lot thicker and wider then other filters for this application, maybe they need brute force? I'm just chalking this up to a lesson learned and writing an apology letter to my Fram Ultra filters for cheating on them. I hope they take me back!
Re: Coyote filter comparison and possible problem [Re: advocate] #5337178 01/31/20 09:32 AM
F
Farnsworth Offline
F
I wouldn't blame the Champion filters without more facts, but that's me. Federal Mogul, Fel Pro, knows how to make gaskets.
Re: Coyote filter comparison and possible problem [Re: advocate] #5338124 02/01/20 11:32 AM
A
advocate Offline OP
A
I really hate to lay the blame. But I tried two of them. Both left puddles where I parked. Changed to another brand and it’s not leaking a drop. I really like their construction especially after cutting one open. But they aren’t working for me. Maybe they need to be installed way tighter. Or looser... this is the only filter I’ve ever have to leak out of the gasket.
Re: Coyote filter comparison and possible problem [Re: advocate] #5338132 02/01/20 11:44 AM
T
tundraotto Offline
T
From the pictures it looks like the wider Champion gasket can lay over the oil feed hole on the right in your 3rd picture. The other filters gaskets are narrower and probably dont overlap that opening. Putting it on 'farmer tight' would probably fix the problem....It's a shame because as you said the Champion filters really do look first rate....just this compatibility problem. Luckily you have another 2 options there.
Re: Coyote filter comparison and possible problem [Re: advocate] #5338352 02/01/20 05:17 PM
Z
ZeeOSix Offline
Z
How much are you tightening the filter after the base gasket makes first contact? 3/4 turn or ??
I wouldn't use the thicker gasket filters just because it does look like the thicker gasket goes over the filter mount oil feed hole some.
Re: Coyote filter comparison and possible problem [Re: advocate] #5338399 02/01/20 06:31 PM
A
advocate Offline OP
A
Once it really slows down I usually give a good 1/4-1/2 turn. I had first tried tightening the filter but the leak continued. So I swapped to another one and gave it a good 3/4 turn once snug. Still leaked. Keep in mind that this happened after a really cold couple of weeks. I had no leaks for 3000 kms on this interval. Then it started leaving puddles. With a different filter on now it hasn’t dropped any on the ground. Maybe these just don’t like the cold. I have a motorcraft on for the rest of this interval. Then I’ll be using strictly fram ultras like I usually do.
