0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
Castrol GTX Magnatec
by David1 - 04/04/20 04:03 AM
Should i change my oil change routine ?
by M119 - 04/04/20 03:56 AM
5 and 10 30 valvoline conv 1.49 a qt at TS
by Chesterr - 04/04/20 02:34 AM
Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
26 registered members (David1, bachman, AurionX2, dervdave, dishdude, 3 invisible), 1,199 guests, and 19 spiders.
Topics303,562
Posts5,237,392
Members71,086
Aiming headlights after changing bulb? #5336352 01/30/20 12:10 PM
M
mclasser Offline OP
M
I replaced one burnt out Philips 9012 bulb with another Philips 9012. Driving around, I noticed it was pointing higher and creating glare off street signs. I parked against a flat wall and the new bulb was indeed aimed higher, causing a scattered pattern. I made sure it was seated correctly and aimed it down to match the other side. With the old bulbs, the aim was perfect.
I've never had to re-aim after changing a bulb before. Have you guys encountered such a thing?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Aiming headlights after changing bulb? [Re: mclasser] #5336358 01/30/20 12:15 PM
Chris Meutsch Offline
If it changed after you changed it, it sounds like an install issue. I've never had this.
2005 Honda CR-V EX, 282k and ready for the retirement home. Make me an offer!
Re: Aiming headlights after changing bulb? [Re: Chris Meutsch] #5336361 01/30/20 12:18 PM
daman Offline
x2
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Aiming headlights after changing bulb? [Re: mclasser] #5336404 01/30/20 01:25 PM
H
hallstevenson Offline
H
The way modern bulbs lock into their sockets, there's next to no movement in the socket possible. You had to have moved the entire assembly in the process (by accident).
Re: Aiming headlights after changing bulb? [Re: mclasser] #5336445 01/30/20 02:29 PM
J
JeffKeryk Offline
J
Yeah, make sure it is sitting flush in the headlamp.
If so, Youtube has some videos on headlight alignment.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Aiming headlights after changing bulb? [Re: mclasser] #5336466 01/30/20 03:10 PM
I
Imp4 Offline
I
Make sure it's installed correctly.
Or maybe you got a bulb with a manufacturing defect.
Eliminate these easy checks before you start to try to turn those rusty aiming screws.
Good luck! cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Aiming headlights after changing bulb? [Re: Imp4] #5336555 01/30/20 05:02 PM
B
barryh Offline
B
Yes I've experienced a small but noticeable alignment change after replacing a bulb. In my case the beam was pulled to the near side. Checked several times that it was correctly seated and tried the bulb on the other side but the change persisted, I suspect a seating issue would produce a much bigger change in beam alignment. I should have returned it as faulty but it could just as easily have been the original bulb that was faulty. The filament must have to be positioned to very fine tolerances.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (MB oil 229.5 5W40)
Re: Aiming headlights after changing bulb? [Re: mclasser] #5336670 01/30/20 06:53 PM
E
eljefino Offline
E
That's pretty weird. I'd get before and after pics and email phillips- they may hook you up with a replacement. They don't make junk.
