GON
$100 Site Donor 2024
Every ten years I replace my pressurized well tank as part of preventive maintenance. I have super iron water and I simply replace all the hardware from the pump inlet to the iron filter.
Pricing new tanks this morning at Menards and came across this :
Water Worker® Plumb n Run; 44 Gallon Pressurized Well Tank & Digital Control
Model Number: HT44-PNR Menards® SKU: 6913385
Not sure if I am reading this correctly- seems to imply it may increase water pressure in homes with private wells. My water pressure is not so good.
Has anyone seen/ used this type of pressure tank?
The Water Worker® Plumb 'n' Run system combines city-like water pressure utilizing an existing pump. It's the perfect alternative to complicated, expensive and difficult to install VFD systems. Pre-assembled and ready-to-run, it's the ultimate combination of quality, savings and performance
City-like water pressure from existing submersible or jet pumps. Maintains 10 psig differential for smooth, consistent flow.
Digital Control allows accurate pressure settings up to 80 psi.
Well Tank carries a 5 year warranty
Digital Pressure control carries a 2 year warranty
Simple 4-wire setup, auto adjusts to 115 or 230 VAC and remains idle if wired improperly
The pressure control protects the pump with built in diagnostics for rapid cycling, low water and improper voltage.
Well Tank is NSF® International Standard 61 listed for clean safe drinking water
Pre-assembled with: Digital Pressure Control, Mounting Bracket, Brass Tank Tee, Copper Tubing, Compression Fittings, Relief Valve, Drain Assembly, Press Sleeves
The well tank is assembled with a heavy duty diaphragm and polypropylene liner that separate the water from the steel and air side of the pressure tank
IncludesWell Tank and Water Worker Digital Control
Durable composite tank stand
