Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
Bama65, wjamyers, L00btech, Lucase483, Chaucha
70791 Registered Users
74 registered members (AZjeff, askani79705, bbhero, atikovi, 87sammy, Astro14, 7 invisible), 1,552 guests, and 25 spiders.
Topics301,853
Posts5,204,049
Members70,791
Pressurized Well Tank & Digital Control #5335153 01/29/20 06:33 AM
G
GON Online Content OP
OP Online Content
G
Every ten years I replace my pressurized well tank as part of preventive maintenance. I have super iron water and I simply replace all the hardware from the pump inlet to the iron filter.
Pricing new tanks this morning at Menards and came across this :
Water Worker® Plumb n Run; 44 Gallon Pressurized Well Tank & Digital Control
Model Number: HT44-PNR Menards® SKU: 6913385
Not sure if I am reading this correctly- seems to imply it may increase water pressure in homes with private wells. My water pressure is not so good.
Has anyone seen/ used this type of pressure tank?
The Water Worker® Plumb 'n' Run system combines city-like water pressure utilizing an existing pump. It’s the perfect alternative to complicated, expensive and difficult to install VFD systems. Pre-assembled and ready-to-run, it’s the ultimate combination of quality, savings and performance
City-like water pressure from existing submersible or jet pumps. Maintains 10 psig differential for smooth, consistent flow.
Digital Control allows accurate pressure settings up to 80 psi.
Well Tank carries a 5 year warranty
Digital Pressure control carries a 2 year warranty
Simple 4-wire setup, auto adjusts to 115 or 230 VAC and remains idle if wired improperly
The pressure control protects the pump with built in diagnostics for rapid cycling, low water and improper voltage.
Well Tank is NSF® International Standard 61 listed for clean safe drinking water
Pre-assembled with: Digital Pressure Control, Mounting Bracket, Brass Tank Tee, Copper Tubing, Compression Fittings, Relief Valve, Drain Assembly, Press Sleeves
The well tank is assembled with a heavy duty diaphragm and polypropylene liner that separate the water from the steel and air side of the pressure tank
IncludesWell Tank and Water Worker Digital Control
Durable composite tank stand
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335165 01/29/20 06:59 AM
Donald Offline
Sounds like more on/off cycles for your pump which will wear it out faster.
2015 Ford F-250 w/Powerstroke
Re: Pressurized Well Tank & Digital Control [Re: Donald] #5335190 01/29/20 07:27 AM
cpayne5 Offline
That was my first thought, too, but then I saw this in what the OP posted.
Quote
The pressure control protects the pump with built in diagnostics for rapid cycling...
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335195 01/29/20 07:33 AM
M
mk378 Offline
M
There's no magic here other than the 10 psi differential which means steadier pressure at the expense of more pump starts. Mechanical switches are 20 psi differential. "Protection from rapid cycling" means really rapid cycling as would happen with tank failure.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335203 01/29/20 07:45 AM
G
OP Online Content
G
Thanks for the replies Gents.... I will stay with the standard tank. I am going to get the largest size I can buy, I have the room and seems the way to go if omne has the room.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335208 01/29/20 07:51 AM
W
WyrTwister Offline
W
Sounds like 99% marketing . But I am guessing . I am on city water .
Wyr
God bless
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335218 01/29/20 07:58 AM
Donald Offline
If you really want consistent water pressure then a pressure regulator should be installed. Most appliances like washing machine and dishwasher fill by volume not by time.
Most people just use well water without issue.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335283 01/29/20 09:08 AM
W
walterjay Offline
W
Do not buy. I have dealt with a few of those and they do not deliver what people expect. Use a traditional well tank, the larger the better and have the pressure set at 40-60 psi. These are not magic bullets for low pressure. And as stated before your pump will have more on off cycles and will wear out quicker.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335356 01/29/20 10:54 AM
1
1978elcamino Offline
1
People have been using pressure tanks in well systems for decades. If there was really a better mouse trap for something so simple I personally think multiple options would have been on the shelves years ago. If more stable pressure is what your looking for why dont you get a really large tank? On my system I have a really large tank and a 2hp pump. During a shower I cant feel the pump cycle even with the laundry going, dishwasher running and toilets flushing.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335364 01/29/20 11:04 AM
G
OP Online Content
G
Thanks again for the very informative replies.
The well is 300 feet deep, not the greatest construction I have been told. I do not know the size of the submersed pump, it was replaced four years ago while i was oversees.
I like the idea of installing a very large pressure tank. I have the room. The only issue- is there any risk my pump HP is to small for the 128 gallon tank?
Re: Pressurized Well Tank & Digital Control [Re: 1978elcamino] #5335428 01/29/20 12:09 PM
Donald Offline
The better mouse trap was the bladder tank vs the huge tank that you filled with air every so often.
The pumps last for a long time and get damaged by lightning and cycles. My Dad had a small nursery and used the submersible pump for our house for watering all the trees. It was an oversize pump for a house. He would turn it on in April and off in Oct and between those times just keep moving the section being watered. Never any problems.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335453 01/29/20 12:30 PM
M
mk378 Offline
M
There's no such thing as tank too large, if you don't mind the cost and space. It can help with a small pump because you have a reserve of water in the tank.
It's also possible to tee multiple tanks together. This may interest someone who is so concerned about tank failure that he engages in pre-emptive replacement. If valves are used on each tank a bad one could be valved off.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335471 01/29/20 12:51 PM
F
Fitter30 Offline
F
Why would you spend $720 on this tank when the same brand of tank is $247 and you can adjust the pressure switch with the same setting.
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335522 01/29/20 01:59 PM
B
benjy Offline
B
how are your water supply pipes??? i say this as my girlfriends well fed house has poor pressure + gets pinholes in her old copper lines so thinking of replacing them with 3/4 plastic made for house water as its inside diameter is similar to 1/2 copper + very EZE + cheap to glue fittings. the size of your lines can be an issue as well!
Re: Pressurized Well Tank & Digital Control [Re: GON] #5335538 01/29/20 02:19 PM
sloinker Offline
I would contemplate a very large non-pressurized holding tank utilizing a pump down circuit to minimize the sump pump cycling. I would use a pressurized tank fed from the holding tank set @ 50psi or so. If you have the room and topography the holding tank could be placed on a hill above the house or on a tower like an old farm.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
