Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
95 registered members (Al, bbhero, 4WD, AzFireGuy79, 2004tdigls, 55hambone, 8 invisible), 2,132 guests, and 39 spiders.
Topics306,027
Posts5,285,137
Members71,566
Page 1 of 3 1 2 3
‘16 Lexus GS350 vs ‘16 Lexus RX350 #5334879 01/28/20 07:19 PM
M
miden851 Offline OP
M
Hello there;
I was thinking what’s the community take on these used cars; I plan to replace my Mazda6 sometime in December/January 2020/21, with something nicer; my list is pretty long so I’d start with these two; I opt for this age because their facelift edition or all new generation at this production age
What to look for, and what are the strengths/weaknesses of the vehicles and what would you get; also, would anyone recommend F features on one these Lexuses; my budget will be in sub $25k
I’d thank you to all constructive opinions and suggestions!
2008 Mazda6i GT; @244K miles
2016 Honda CR-V EX-L; @57K miles
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5334919 01/28/20 08:25 PM
N
nthach Offline
N
Apples and oranges, the GS is a RWD(with optional AWD) mid-sized luxury sedan and the RX is a FWD(with optional AWD) mid-sized luxury SUV. I haven't spent enough time in a GS but the RX is more or less a more luxurious Highlander, which also shares its drivetrain and much of its chassis with the Camry and Sienna(the current RX hasn't switched over to TNGA).
The GS will be the sportier of the two, the RX isn't exciting but it's practical and reliable - which is why it's a best seller for Lexus. Both cars will have the 2GR engine, the RX uses a newer version with Atkinson cycle for better efficiency(and it's dangerously near the GS350's 306HP engine too!). The GS is comfortable, while it might not handle as well as a 5 Series or A6 it holds its own. Not too many issues from the 2GR-FSE/2GR-FXS, oddly enough the Tacoma version is having valve spring issues.
The F Sport package on both is mostly cosmetic - it does add some suspension and brake tweaks to the GS, while on the RX it adds on an LFA-style instrument cluster and different grille.
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5334927 01/28/20 08:36 PM
G
Gebo Offline
G
I will give you some advice. As you can see, I am an old model Lexus fan. Go to some Lexus forums (clublexus.com is really good) and do a lot of study of each of those models. You will see what the owners have to say.
Also, and what believe to me the best advice I can give you is to go the www.Lexus.com. Sign up as a member.
Then get the VIN's of the Lexus's you are looking at and enter them as your own vehicle. You will then be able to do a "Service History" and see any work that was done on them by Lexus. It will show you all the repairs that were made my their shops. Battery replacements, oil changes, brake jobs, coolant changes, warranty work, body work, etc. The last 3 Lexus I purchased had really good service records. It takes me about 6-9 months before I find a "perfect" one. I try to purchase from a Lexus Dealer. I primarily search the Lexus dealers in NC, TN, AL, GA, FL and SC. NC and FL have been my "honey holes."
Authentic service records are my #1 criteria along with a car that has lived its entire life in the SE USA.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5334934 01/28/20 08:42 PM
9
97prizm Offline
9
I sold Lexus vehicles for a while. 2016 was the first year for the facelift and all-new underpinnings. I know the biggest complaints are uneven ie not flat driver and passenger footwell. The Air conditioning was loud on early vehicles from what ive heard and the air con seats were a bit weak but seemed to be better later on. Heavily grungy seats were difficult to clean. Since 2016 was the initial year it was more a la carte, the 2017 added some standard features. The GS350 has a tiny backseat for its class and the 6 speed transmission is a little clumsy. The RWD version comes with an 8-speed transmission and is smoother but no dual clutch. It drives nice but see if you like the touch sensitive navigation. I had customers walk over it. It's reliable and relatively easy to take care of. Good luck.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5334963 01/28/20 09:29 PM
W
WagonWheel Offline
W
The GS requires premium fuel whereas the RX350 only requires regular.
link (Lexus)
2003 Honda Accord 2.4L 5AT - 153k miles
2006 Honda Odyssey 3.5L EX-L 127k miles (S-VCM)
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5335034 01/28/20 11:13 PM
J
JeffKeryk Online Content
Online Content
J
I have both cars, sorta anyway.
Our 2018 RX450h is almost the perfect vehicle. Rock solid dependable and good mileage. So comfortable.
I run it in normal or sport mode to stiffen it up. You will love it. Perfect Costco car.
No one does hybrids like Toyota.
On a 100 mile drive on interstate 280, south of SF during a rain storm, the AWD performed flawlessly. Inspired confidence...
The 2013 GS350 F Sport will spoil you. It is a real performer; planted to the road.
Mileage is poor, brakes squeal when cold. The F Sport is much more car than the non F Sport.
The 2016 refresh apparently softened up the suspension just a taste.
The F Sport has staggered tire sizes; my car wears the expensive Michelin Pilots.
The GS is old school; no turbos, etc, kinda outdated as it was new for the 2013 year.
This is not a good winter car...
Both cars have outdated GPS; no Carplay / Andriod Auto.
Go to your dealer and drive both. I highly suggest you consider a CPO car for the warranty and services.
I think $25K might be a little weak for one of these cars; good luck.
Be warned - Lexus quality will spoil you.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5335037 01/28/20 11:20 PM
1
14Accent Offline
1
That's a pretty broad range of vehicle types... more like something you would have both of vs. one or the other.
That being said, assuming you're only buying one, I would take the RX350. It's an amazing overall value, very well built, and versatile. You don't need AWD in Georgia I assume, so that simplifies maintenance requirements. It will ride better than the GS, get close-to or equal-to fuel mileage of the GS, have similar repair/maintenance costs, and be much more versatile. Say you want to go out and buy a new 65" TV for the big game. Can you slide that bad boy in a GS? Nope. But an RX will handle it find, no need to have it delivered or borrow a car (I know, delivery service. I don't trust them on items like that).
My vote is for the RX, given the choices.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: 14Accent] #5335090 01/29/20 01:38 AM
L
Lolvoguy Offline
L
Generally, Lexus owners are able to refrain from making hasty decisions like buying grossly over-sized TV's to impress people they don't like.
That behavior is reserved more for the Dodge Durango/F150/Silverado group.
With that in mind, my vote goes for the GS!
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5335106 01/29/20 03:54 AM
W
Ws6 Offline
W
If a car works for you, and can commute your roads, 24/7/365, then the answer will always be "get the car ". Better handling, mpg, speed, you name it.
Lexus makes boring, if solid cars that hold up well. Pick your poison, and be prepared to be humbled by most any bmw/audi/honda/ nissan/anything really, in the speed dept.
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: Ws6] #5335123 01/29/20 05:49 AM
L
Lolvoguy Offline
L
Originally Posted by Ws6
... and be prepared to be humbled by most any bmw/audi/honda/ nissan/anything really, in the speed dept.
Have any info to back that statement?
Say "no" to Turbo!
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: Lolvoguy] #5335140 01/29/20 06:59 AM
W
Ws6 Offline
W
Well, it's as easy as looking up the performance data for a lexus 350 and then the others as mentioned in its class.
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5335289 01/29/20 10:13 AM
M
miden851 Offline OP
M
some great information here; I thank you all for your sound advice!
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5335294 01/29/20 10:18 AM
J
Online Content
J
As 14Accent posted, you kinda need both.
If you can have only 1, the RX is the sensible choice. FYI - I would only buy AWD for the stability.
For fun, the GS is a world class car. I would buy another, even with its faults.
Good luck.
2018 Lexus RX450h
2006 Acura TSX
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: miden851] #5335455 01/29/20 01:32 PM
I
irekm Offline
I
I own 13' GS Fsport AWD .
Great reliable car , 110K miles on it ,and the only thing that "broke" is battery , bought new one few months ago .
Being awd is great in all weather conditions, we drive a lot in snow and ice ,with good winter tires this thing is unstoppable. Its fuel mileage is kind of bad , on average worse than my 18' mustang GT .But then, no other unexpected expenses .
Re: ‘16 Lexus GS350 vs ‘16 Lexus RX350 [Re: irekm] #5335573 01/29/20 03:54 PM
M
miden851 Offline OP
M
so how much did they change the car between '13 vs '16, let alone esthetics?
Page 1 of 3 1 2 3
